Asterisk versions 1.2.24 and 1.4.10
betateilchen
Grandstream-Guru
30 Jun 2004
The Asterisk development team has released Asterisk versions 1.2.24 and 1.4.10.
Version 1.2.24 is the final 1.2 release that contains normal bug fixes. The 1.2 branch will only be maintained with security fix releases from now until it is completely deprecated.
Version 1.4.10 contains numerous bug fixes for things all over Asterisk, as well as a fix for a security issue. The security issue only affects users of
chan_skinny and is documented in ASA-2007-019.
http://downloads.digium.com/pub/asa/ASA-2007-019.pdf
Another set of noteworthy changes in version 1.4.10 include many fixes for the IAX2 channel driver. Special recognition goes out to the developers over at Wimba (http://www.wimba.com/) for their dedication to tracking down numerous complicated issues in the 1.4 version of chan_iax2. Thank you very much Mihai, Steve, and Pete!
These releases are available for download from the following location:
http://downloads.digium.com/pub/telephony/asterisk/
Thank you very much for your support!
Es hätte mich ja gewundert, wenn es anders geworden wäre... :lach:
Zwei Tage spätern feiern wir die Geburt von 1.4.10.1
2007-08-10  Russell Bryant <[email protected]>
	* Asterisk 1.4.10.1 released.
2007-08-10 15:20 +0000 [r78995]  Russell Bryant <[email protected]>
	* include/asterisk/lock.h: The last set of changes that I made to
	  "core show locks" made it not able to track mutexes unless they
	  were declared using AST_MUTEX_DEFINE_STATIC. Locks initialized
	  with ast_mutex_init() were not tracked. It should work now.
2007-08-10 14:15 +0000 [r78951-78955]  Joshua Colp <[email protected]>
	* main/file.c: Don't bother having the core pass through or emulate
	  begin DTMF frames when in an ast_waitstream. It only cares about
	  the end of DTMF.
	* configs/queues.conf.sample: (closes issue #10422) Reported by:
	  bhowell Add note to sample configuration about module load order
	  and how it can cause perfectly good queue members to be marked as
	  invalid.
2007-08-10 13:24 +0000 [r78936]  Christian Richter <[email protected]>
	* channels/chan_misdn.c, channels/misdn/ie.c,
	  channels/misdn/isdn_msg_parser.c: fixed a bug with the useruser
	  information element. We send them now also in the disconnect
	  message.
2007-08-09 23:47 +0000 [r78907]  Mark Michelson <[email protected]>
	* apps/app_voicemail.c: Improved a bit of logic regarding
	  comma-separated mailboxes in has_voicemail. Also added some
	  braces to some compound if statements since unbraced if
	  statements scare me in general.
2007-08-09 23:10 +0000 [r78891]  Steve Murphy <[email protected]>
	* Makefile: This fixes bug 10416; thanks to mvanbaak for the pretty
	  output
2007-08-09 22:03 +0000 [r78826-78860]  Mark Michelson <[email protected]>
	* apps/app_voicemail.c: Removing some extra debug code I left in my
	  last commit
	* apps/app_voicemail.c: Quite a few changes regarding IMAP storage.
	  1. instead of using inboxcount as the core message counting
	  function, we use messagecount instead. This makes it possible to
	  count messages in folders besides just INBOX and Old. 2.
	  inboxcount and hasvoicemail now use messagecount as their means
	  of determining return values. 3. Added a copy_message function
	  for IMAP storage. Unfortunately I don't have the means to test
	  it, but it seems like a pretty straightforward function. 4.
	  Removed a #ifndef IMAP_STORAGE and matching #endif from
	  leave_voicemail for a couple of reasons. One, we want to support
	  copying mail to multiple IMAP boxes, and two, IMAP was broken
	  because a STORE macro had been moved into this section of code.
	* channels/chan_sip.c: I broke canreinvite...Now I'm fixing it. I
	  put some new code in the wrong place and so I've reverted the
	  canreinvite section to how it was and put my new code where it
	  should be.
2007-08-09 17:58 +0000 [r78717-78778]  Russell Bryant <[email protected]>
	* apps/app_voicemail.c: add a comment to indicate that inboxcount
	  for ODBC_STORAGE needs to be fixed to support multiple mailboxes
	* apps/app_voicemail.c: Fix subscriptions to multiple mailboxes for
	  ODBC_STORAGE. Also, leave a comment for this to be fixed for
	  IMAP_STORAGE, as well. I left IMAP alone since I know MarkM was
	  working on this code right now for another reason. This is broken
	  even worse in trunk, but for a different reason. The fact that
	  the mailbox option supported multiple mailboxes is completely not
	  obvious from the code in the channel drivers. Anyway, I will fix
	  that in another commit ...
	* apps/app_meetme.c: Fix a problem with the combination of the 'F'
	  option to pass DTMF through a conference and options that use
	  DTMF to activate various features. The problem was that the BEGIN
	  frame would be passed through, but the END frame would get
	  intercepted to activate a feature. Then, the other conference
	  members would hear DTMF for forever, which they didn't seem to
	  like very much. (closes issue #10400, reported by stevefeinstein,
	  fixed by me)
2007-08-08 19:29 +0000 [r78646]  Jason Parker <[email protected]>
	* doc/jabber.txt: Fix mogs email address.
2007-08-08 18:16 +0000 [r78575-78620]  Mark Michelson <[email protected]>
	* apps/app_voicemail.c: Fixed some compiler warnings so that
	  compiling with dev-mode and IMAP storage would not have any
	  errors. This section of code may get changed again shortly since
	  my change uncovers a rather silly bit of logic.
	* apps/app_queue.c: Changing a bit of logic so that someone will
	  NEVER exit the queue on timeout unless they have enabled the 'n'
	  option. This commit relates to issue #10320. Thanks to
	  jfitzgibbon for detailing the idea behind this code change.
2007-08-08 13:51 +0000 [r78569]  Joshua Colp <[email protected]>
	* configs/sip.conf.sample: (closes issue #10335) Reported by:
	  adamgundy Update sip.conf to include another scenario where
	  directrtpsetup will fail.
2007-08-07  Russell Bryant <[email protected]>
	* Asterisk 1.4.10 released.
da lache ich erst wenn die 1.2.24.1 bzw. 1.2.25 draußen ist.
britzelfix
Thomasbetty
