Asterisk + Voicemail
Xaxis
23 Jun 2007
Hallo leute. Hab da nen kleines problem, und zwar mit Voicemail wie der titel schon aussagt. Und zwar gehts darum wenn eine voicemail eingeht, dass diese mir dann per mail geschickt wird. Schön und gut, nach nen paar problemen habe ich es hinbekommen das sendmail ansich funktioniert, die emails kommen bei mir an, nur aus asterisk heraus kommt keine nachricht bei mir nicht an.
Hier ein auszug aus meiner voicemail.conf
; Voicemail Configuration
; NOTE: Asterisk has to edit this file to change a user's password.  This does
; not currently work with the "#include <file>" directive for Asterisk
; configuration files, nor when using realtime static configuration.
; Do not use them with this configuration file.
[general]
; Default formats for writing Voicemail
;format=g723sf|wav49|wav
format=wav|gsm
; WARNING:
; If you change the list of formats that you record voicemail in
; when you have mailboxes that contain messages, you _MUST_ absolutely
; manually go through those mailboxes and convert/delete/add the
; the message files so that they appear to have been stored using
; your new format list. If you don't do this, very unpleasant
; things may happen to your users while they are retrieving and
; manipulating their voicemail.
; In other words: don't change the format list on a production system
; unless you are _VERY_  sure that you know what you are doing and are
; prepared for the consequences.
; Who the e-mail notification should appear to come from
[email protected]
;[email protected]
; Should the email contain the voicemail as an attachment
attach=yes
; Maximum number of messages per folder.  If not specified, a default value
; (100) is used.  Maximum value for this option is 9999.
maxmsg=9999
; Maximum length of a voicemail message in seconds
maxmessage=300
; Minimum length of a voicemail message in seconds for the message to be kept
; The default is no minimum.
;minmessage=3
; Maximum length of greetings in seconds
;maxgreet=60
; How many milliseconds to skip forward/back when rew/ff in message playback
skipms=3000
; How many seconds of silence before we end the recording
maxsilence=10
; Silence threshold (what we consider silence: the lower, the more sensitive)
silencethreshold=128
; Max number of failed login attempts
maxlogins=3
; User context is where entries from users.conf are registered.  The
; default value is 'default'
;userscontext=default
; If you need to have an external program, i.e. /usr/bin/myapp
; called when a voicemail is left, delivered, or your voicemailbox
; is checked, uncomment this.  It can also be set to 'smdi' to use
; smdi for external notification.  If it is 'smdi', smdiport should
; be set to a valid port as specified in smdi.conf.
externnotify=mail [email][email protected][/email] -s VoiceMail
;smdiport=/dev/ttyS0
; called when a voicemail password is changed, uncomment this:
;externpass=sendmail -t [email][email protected][/email]
; For the directory, you can override the intro file if you want
;directoryintro=dir-intro
; The character set for voicemail messages can be specified here
;charset=ISO-8859-1
; The ADSI feature descriptor number to download to
;adsifdn=0000000F
; The ADSI security lock code
;adsisec=9BDBF7AC
; The ADSI voicemail application version number.
;adsiver=1
; Skip the "[PBX]:" string from the message title
;pbxskip=yes
; Change the From: string
fromstring=The Asterisk PBX
; Permit finding entries for forward/compose from the directory
;usedirectory=yes
; Voicemail can be stored in a database using the ODBC driver.
; The value of odbcstorage is the database connection configured
; in res_odbc.conf.
;odbcstorage=asterisk
; The default table for ODBC voicemail storage is voicemessages.
;odbctable=voicemessages
; Change the from, body and/or subject, variables:
;     VM_NAME, VM_DUR, VM_MSGNUM, VM_MAILBOX, VM_CALLERID, VM_CIDNUM,
;     VM_CIDNAME, VM_DATE
; Note: The emailbody config row can only be up to 512 characters due to a
;       limitation in the Asterisk configuration subsystem.
emailsubject=[PBX]: Neu Nachricht ${VM_MSGNUM} in der  mailbox ${VM_MAILBOX}
; The following definition is very close to the default, but the default shows
; just the CIDNAME, if it is not null, otherwise just the CIDNUM, or "an unknown
; caller", if they are both null.
emailbody=Hallo ${VM_NAME}:\n\n\tjust wanted to let you know you were just left a ${VM_DUR} long message (number ${VM_MSGNUM})\nin mailbox ${VM_MAILBOX} from ${VM_CALLERID}, on ${VM_DATE}, so you might\nwant to check it when you get a chance.  Thanks!\n\n\t\t\t\t--Asterisk\n
; You can also change the Pager From: string, the pager body and/or subject.
; The above defined variables also can be used here
pagerfromstring=The Asterisk PBX
pagersubject=New VM
;pagerbody=New ${VM_DUR} long msg in box ${VM_MAILBOX}\nfrom ${VM_CALLERID}, on ${VM_DATE}
; Set the date format on outgoing mails. Valid arguments can be found on the
; strftime(3) man page
; Default
;emaildateformat=%A, %B %d, %Y at %r
; 24h date format
emaildateformat=%A, %d %B %Y at %H:%M:%S
; You can override the default program to send e-mail if you wish, too
mailcmd=/usr/sbin/sendmail -t
; Users may be located in different timezones, or may have different
; message announcements for their introductory message when they enter
; the voicemail system. Set the message and the timezone each user
; hears here. Set the user into one of these zones with the tz= attribute
; in the options field of the mailbox. Of course, language substitution
; still applies here so you may have several directory trees that have
; alternate language choices.
; Look in /usr/share/zoneinfo/ for names of timezones.
; Look at the manual page for strftime for a quick tutorial on how the
; variable substitution is done on the values below.
; Supported values:
; 'filename'    filename of a soundfile (single ticks around the filename
;               required)
; ${VAR}        variable substitution
; A or a        Day of week (Saturday, Sunday, ...)
; B or b or h   Month name (January, February, ...)
; d or e        numeric day of month (first, second, ..., thirty-first)
; Y             Year
; I or l        Hour, 12 hour clock
; H             Hour, 24 hour clock (single digit hours preceded by "oh")
; k             Hour, 24 hour clock (single digit hours NOT preceded by "oh")
; M             Minute, with 00 pronounced as "o'clock"
; N             Minute, with 00 pronounced as "hundred" (US military time)
; P or p        AM or PM
; Q             "today", "yesterday" or ABdY
;               (*note: not standard strftime value)
; q             "" (for today), "yesterday", weekday, or ABdY
; R             24 hour time, including minute
; Each mailbox is listed in the form <mailbox>=<password>,<name>,<email>,<pager_email>,<options>
; if the e-mail is specified, a message will be sent when a message is
; received, to the given mailbox. If pager is specified, a message will be
; sent there as well. If the password is prefixed by '-', then it is
; considered to be unchangeable.
; Advanced options example is extension 4069
; NOTE: All options can be expressed globally in the general section, and
; overridden in the per-mailbox settings, unless listed otherwise.
; tz=central 		; Timezone from zonemessages below. Irrelevant if envelope=no.
attach=yes 		; Attach the voicemail to the notification email *NOT* the pager email
attachfmt=wav	; Which format to attach to the email.  Normally this is the
			; first format specified in the format parameter above, but this
			; option lets you customize the format sent to particular mailboxes.
			; Useful if Windows users want wav49, but Linux users want gsm.
			; [per-mailbox only]
saycid=yes 		; Say the caller id information before the message. If not described,
			;     or set to no, it will be in the envelope
; cidinternalcontexts=intern	; Internal Context for Name Playback instead of
			; extension digits when saying caller id.
; sayduration=no 	; Turn on/off the duration information before the message. [ON by default]
; saydurationm=2        ; Specify the minimum duration to say. Default is 2 minutes
; dialout=fromvm ; Context to dial out from [option 4 from mailbox's advanced menu].
                 ; If not specified, option 4 will not be listed and dialing out
                 ; from within VoiceMailMain() will not be permitted.
sendvoicemail=yes ; Allow the user to compose and send a voicemail while inside
                  ; VoiceMailMain() [option 5 from mailbox's advanced menu].
                  ; If set to 'no', option 5 will not be listed.
; searchcontexts=yes	; Current default behavior is to search only the default context
			; if one is not specified.  The older behavior was to search all contexts.
			; This option restores the old behavior [DEFAULT=no]
; callback=fromvm 	; Context to call back from
			;     if not listed, calling the sender back will not be permitted
; review=yes 		; Allow sender to review/rerecord their message before saving it [OFF by default
; operator=yes 		; Allow sender to hit 0 before/after/during  leaving a voicemail to
			;     reach an operator  [OFF by default]
; envelope=no 		; Turn on/off envelope playback before message playback. [ON by default]
			;     This does NOT affect option 3,3 from the advanced options menu
; delete=yes		; After notification, the voicemail is deleted from the server. [per-mailbox only]
			;     This is intended for use with users who wish to receive their
			;     voicemail ONLY by email. Note:  "deletevoicemail" is provided as an
			;     equivalent option for Realtime configuration.
; volgain=0.0		; Emails bearing the voicemail may arrive in a volume too
			;     quiet to be heard.  This parameter allows you to specify how
			;     much gain to add to the message when sending a voicemail.
			;     NOTE: sox must be installed for this option to work.
; nextaftercmd=yes	; Skips to the next message after hitting 7 or 9 to delete/save current message.
			;     [global option only at this time]
; forcename=yes		; Forces a new user to record their name.  A new user is
			;     determined by the password being the same as
			;     the mailbox number.  The default is "no".
; forcegreetings=no	; This is the same as forcename, except for recording
			;     greetings.  The default is "no".
; hidefromdir=yes	; Hide this mailbox from the directory produced by app_directory
			;     The default is "no".
;tempgreetwarn=yes	; Remind the user that their temporary greeting is set
[zonemessages]
eastern=America/New_York|'vm-received' Q 'digits/at' IMp
central=America/Chicago|'vm-received' Q 'digits/at' IMp
central24=America/Chicago|'vm-received' q 'digits/at' H N 'hours'
military=Zulu|'vm-received' q 'digits/at' H N 'hours' 'phonetic/z_p'
european=Europe/Berlin|'vm-received' a d b 'digits/at' HM
[default]
; Define maximum number of messages per folder for a particular context.
;maxmsg=50
2000 => 0000,Marc ...,*****@mv-*****.org
also wie gesagt, aufzeichnen und etc funtioniert, genauso wie über mail bzw sendmail ne mail zu verschicken aus der console funktioniuert auch.
:shock:
das nennst Du "Auszug"? Nächstes Mal bitte die CODE Tags selbst verwenden.
externnotify=mail v******@mv-service.org -s VoiceMail
Diese Zeile solltest Du erstmal auskommentieren und dann testen.
Ne die hatte ich schon selber eingebaut, so kommt dann auch ne mail an, nur nicht die die ich haben will. also ohne das kommt nichts.
Wenn ohne diese Zeile nichts kommt, dann ist dein Mailprogramm falsch eingerichtet und nicht der Asterisk.
Und wenn Du schon das interne Mailing von Asterisk überschreibst, solltest Du auch den Aufruf des externen Programmes richtig machen - Asterisk macht dann nämlich von sich aus gar nix mehr.
So wie Du das machst, kriegst Du lediglich eine leere email, in der "VoiceMail" als Subject steht, denn Du hast ja gar nix anderes angegeben. Punkt - aus - Ende.
Works as designed.
Ne das ist klar, das war auch nur nen Test ob behaupt was kommt, und da kamm auch was, nur halt auf den anderen Befehl kamm nichts. Leider!
Hab auch schon mehrfach versucht sendmail und alle abhängigen packete mit apt nach zu installieren, ausser das irgendwie der mail befehl nun nicht mehr geht. Gab es keine besserung, hab aber auch festgestellt, dass z.B. das mailing aus php heraus auch nicht funktioniert, was ja ähnlich auf die sendmail funktionalität zugreift. Nur die frage, wie kriege ich das am einfachsten repartiert, gibts besondere configs die erst eingestellt werden muss?
ich verwende exim4 für den Mailversand.
Eine gute Grundlagenanleitung findest Du hier
Ok Dankeschön, damit funktioniert es jetzt auch.
Der_fragende_Unwissende
