Asterisk10 und ENUMLOOKUP
Timmbo
Aktives Mitglied
6 Nov 2005
ich steige gerade von * 1.2 auf 10 um, leider funktioniert mein ENUMLOOKUP nicht mehr, er geht sofort zur PRIO 10 weiter, jemand eine Idee?
[enum-go]
exten => _+Z.,1,Set(Nebenstelle=${CALLERID(num)})
exten => _X.,1,Set(Nebenstelle=${CALLERID(num)})
exten => _Z.,2,Goto(nachenum${Nebenstelle},${EXTEN},1)
exten => _+Z.,2,Goto(enum,${EXTEN},1)
exten => _0Z.,2,Goto(enum,+43${EXTEN:1},1)
exten => _00Z.,2,Goto(enum,+${EXTEN:2},1)
exten => _000Z.,2,Goto(nachenum${Nebenstelle},${EXTEN},1)
[enum]
exten => _+Z.,1,Set(CALLERID(number)=+43123456)
exten => _+Z.,n,Set(enumlist=e164.arpa e164.org|tree=0)
exten => _+Z.,n,While($["${SET(e164=${CUT(enumlist, ,${SET(tree=$[${tree} + 1])})})}" != ""])
exten => _+Z.,n,Set(sipcount=${ENUMLOOKUP(${EXTEN},sip,c,${e164})}|counter=0)
exten => _+Z.,n,While($[${counter}<0${sipcount}])
exten => _+Z.,n,Set(counter=$[${counter}+1])
exten => _+Z.,n,Gotoif($["${SET(e=${ENUMLOOKUP(${EXTEN},sip,${counter},${e164})})}"=""]?ew)
exten => _+Z.,n,Dial(SIP/${e},120,W)
exten => _+Z.,n(ew),EndWhile
exten => _+Z.,n,EndWhile
exten => _+Z.,n,GotoIf($["${DIALSTATUS}"=""]?ef)
exten => _+Z.,n,Noop
exten => _+Z.,n,Congestion()
exten => _+Z.,n,Hangup
exten => _+Z.,n(ef),goto(enum-lcr,00${EXTEN:1},1)
und hier das Debug:
-- Executing [[email protected]:1] Set("SIP/52-00000087", "Nebenstelle=52") in new stack
    -- Executing [[email protected]:2] Goto("SIP/52-00000087", "enum,+437200101011,1") in new stack
    -- Goto (enum,+437200101011,1)
    -- Executing [[email protected]:1] Set("SIP/52-00000087", "CALLERID(number)=+43123456") in new stack
  == Extension Changed 52[internal] new state InUse for Notify User 43
    -- Executing [[email protected]:2] Set("SIP/52-00000087", "enumlist=e164.arpa e164.org|tree=0") in new stack
    -- Executing [[email protected]:3] While("SIP/52-00000087", "0") in new stack
    -- Jumping to priority 10
    -- Executing [[email protected]:11] GotoIf("SIP/52-00000087", "1?ef") in new stack
    -- Goto (enum,+437200101011,15)
    -- Executing [[email protected]:15] Goto("SIP/52-00000087", "enum-lcr,00437200101011,1") in new stack
    -- Goto (enum-lcr,00437200101011,1)
Thx
Timm
abw1oim
Aktives Mitglied
26 Mrz 2007
Auf die Schnelle folgendes:
funktioniert nicht. Einerseits ist Pipe (|) durch Komma ),) ersetzt worden, andererseits ist mW die Mehrfachbelegung von verschiedenen Variablen in einem Set-Befehl nicht mehr möglich. Wenn Du das entsprechend umbaust, sollte das Log schon etwas anderes zeigen ...
wildzero
5 Jul 2004
Timmbo
Aktives Mitglied
6 Nov 2005
Hallo Kristijan,
das hängt leider nicht von mir ab, aber der 11er ist noch zu instabil, ich denke ab Anfang 2015 wird hier auf Asterisk 11 umgestellt.
Hoffe es geht Dir soweit gut.
[Beitrag 2:]
so hier nun eine Änderung welche zwar den Dialbefehl ausführt, jedoch ohne Inhalt.
  -- Executing [[email protected]:1] Set("SIP/52-0000005c", "Nebenstelle=52") in new stack
    -- Executing [[email protected]:2] Goto("SIP/52-0000005c", "enum,+437200101011,1") in new stack
    -- Executing [[email protected]:1] Set("SIP/52-0000005c", "sipcount=,counter=0") in new stack
    -- Executing [[email protected]:2] GotoIf("SIP/52-0000005c", "1?3:6") in new stack
    -- Goto (enum,+437200101011,3)
    -- Executing [[email protected]:3] Set("SIP/52-0000005c", "counter=") in new stack
    -- Executing [[email protected]:4] Dial("SIP/52-0000005c", "SIP/") in new stack
Und hier der Neue Dialplan von Digium(Bei enum):
[enum-go]
[enum]
exten => _+Z.,1,Set(sipcount=${ENUMLOOKUP(${EXTEN},sip,c)},counter=0)
exten => _+Z.,2,GotoIf($["${counter}"<"${sipcount}"]?3:6)
exten => _+Z.,3,Set(counter=$[${counter}+1])
exten => _+Z.,4,Dial(SIP/${ENUMLOOKUP(${EXTEN},sip,,${counter})})
exten => _+Z.,5,GotoIf($["${counter}"<"${sipcount}"]?3:6)
exten => _+Z.,6,Set(iaxcount=${ENUMLOOKUP(${EXTEN},iax2,c)},counter=0)
exten => _+Z.,7,GotoIf($["${counter}"<"${iaxcount}"]?8:11)
exten => _+Z.,8,Set(counter=$[${counter}+1])
exten => _+Z.,9,Dial(IAX2/${ENUMLOOKUP(${EXTEN},iax2,,${counter})})
exten => _+Z.,10,GotoIf($["${counter}"<"${iaxcount}"]?8:11)
exten => _+Z.,11,NoOp("No valid entries in e164.arpa for ${EXTEN} - checking in e164.org")
; ...then also try e164.org, and look for SIP and IAX NAPTRs...
exten => _+Z.,12,Set(sipcount=${ENUMLOOKUP(${EXTEN},sip,c,,e164.org)},counter=0)
exten => _+Z.,13,GotoIf($["${counter}"<"${sipcount}"]?14:17)
exten => _+Z.,14,Set(counter=$[${counter}+1])
exten => _+Z.,15,Dial(SIP/${ENUMLOOKUP(${EXTEN},sip,,${counter},e164.org)})
exten => _+Z.,16,GotoIf($["${counter}"<"${sipcount}"]?14:17)
exten => _+Z.,17,Set(iaxcount=${ENUMLOOKUP(${EXTEN},iax2,c,,e164.org)},counter=0)
exten => _+Z.,18,GotoIf($["${counter}"<"${iaxcount}"]?19:22)
exten => _+Z.,19,Set(counter=$[${counter}+1])
exten => _+Z.,20,Dial(IAX2/${ENUMLOOKUP(${EXTEN},iax2,,${counter},e164.org)})
exten => _+Z.,21,GotoIf($["${counter}"<"${iaxcount}"]?19:22)
Thx
Timm
Timmbo
Aktives Mitglied
6 Nov 2005
[Update-Gelöst]
der Hersteller hat das enum Modul nicht geladen.
Nachdem ich das Modul func_enum.so hinzugefügt hatte und den Dialplan noch etwas abgeändert hatte(aus dem Internet), geht es nun.
[enum-go]
[enum]
exten => _+Z.,1,Set(CALLERID(number)=+43720xxxxxx)
exten => _+Z.,2,Set(sipcount=${ENUMLOOKUP(${EXTEN},sip,c)})
exten => _+Z.,3,Set(counter=0)
exten => _+Z.,4,GotoIf($["${counter}"<"${sipcount}"]?5:8)
exten => _+Z.,5,Set(counter=${MATH(${counter}+1,int)})
exten => _+Z.,6,Dial(SIP/${ENUMLOOKUP(${EXTEN},sip,,${counter})})
exten => _+Z.,7,GotoIf($["${counter}"<"${sipcount}"]?5:8)
exten => _+Z.,8,Set(sipcount=${ENUMLOOKUP(${EXTEN},sip,c,,tms-itdienst.at)})
exten => _+Z.,9,Set(counter=0)
exten => _+Z.,10,GotoIf($["${counter}"<"${sipcount}"]?11:14)
exten => _+Z.,11,Set(counter=$[${counter}+1])
exten => _+Z.,12,Dial(SIP/${ENUMLOOKUP(${EXTEN},sip,,${counter},tms-itdienst.at)})
exten => _+Z.,13,GotoIf($["${counter}"<"${sipcount}"]?11:14)
exten => _+Z.,14,Set(sipcount=${ENUMLOOKUP(${EXTEN},sip,c,,e164.org)})
exten => _+Z.,15,Set(counter=0)
exten => _+Z.,16,GotoIf($["${counter}"<"${sipcount}"]?17:20)
exten => _+Z.,17,Set(counter=${MATH(${counter}+1,int)})
exten => _+Z.,18,Dial(SIP/${ENUMLOOKUP(${EXTEN},sip,,${counter},e164.org)})
exten => _+Z.,19,GotoIf($["${counter}"<"${sipcount}"]?17:20)
exten => _+Z.,20,goto(enum-failed,00${EXTEN:1},1)
[enum-failed]
exten => _X.,1,Set(CALLERID(number)=${Nebenstelle})
exten => _X.,2,GotoIf($[${REGEX("[@]" ${CDR(channel)})}]?4)
exten => _0043Z.,3,Goto(nachenum${Nebenstelle},0${EXTEN:4},1)
exten => _00Z.,3,Goto(nachenum${Nebenstelle},${EXTEN},1)
exten => _X.,4,Macro(enum-forward)
exten => _0043Z.,5,Goto(nachenum${goback},0${EXTEN:4},1)
exten => _00Z.,5,Goto(nachenum${goback},${EXTEN},1)
[macro-enum-forward]
exten => s,1,Set(nst=${CDR(channel)})
exten => s,2,Set(newvar=${CUT(nst,@,2)})
exten => s,3,Set(goback=${CUT(newvar,-,1)})
exten => s,4,MacroExit()
Timm
pitsiklos
Erhalten Sie 3CX für 1 Jahr kostenlos!
Gehostet, in Ihrer privaten Cloud oder on-Premise! Ganz ohne Haken. Geben Sie Ihren Namen und Ihre E-Mail an und los geht´s:
oder via
