Aufruf von dummy.htm funktioniert nur nach Login im Admin-Mode?
lucy68
30 Mai 2019
ich habe bei einem SNOM D375 (Firmware 8.9.3.61) ein unerklärliches Phänomen:
Normalerweise kann ich über die dummy.htm Einstellungen setzen, so z.B.
http://192.168.10.99/dummy.htm?settings=save&user_idle_text1=TEST
Bei anderen Gerätetypen funktioniert das, hier beim D375 merkwürdiger Weise nicht!
Das Log-File sagt dazu:
08:45:32.116 [WARN ] PHN: No access rights to set parameter user_idle_text1!
08:45:32.030 [DEBUG2] PHN: WEB: HTTP accepting from Tcp:192.168.10.55:49162
08:45:32.031 [DEBUG2] PHN: WEB: HTTP 27/80 accepted from Tcp:192.168.10.55:49162
08:45:32.031 [DEBUG2] PHN: WEB: HTTP 27/80 connected
08:45:32.031 [INFO ] PHN: WEB: Request 27/361/2: POST /dummy.htm HTTP/1.1
08:45:32.032 [INFO ] PHN: WEB: 27 Basic authentication.
08:45:32.033 [INFO ] PHN: Authentication triggered. Set flag back.
08:45:32.033 [DEBUG2] PHN: WEB: HTTP 27/80 disconnected
08:45:32.034 [DEBUG2] PHN: WEB: HTTP 27/80 deleted
08:45:32.110 [DEBUG2] PHN: WEB: HTTP accepting from Tcp:192.168.10.55:49163
08:45:32.111 [DEBUG2] PHN: WEB: HTTP 28/80 accepted from Tcp:192.168.10.55:49163
08:45:32.111 [DEBUG2] PHN: WEB: HTTP 28/80 connected
08:45:32.111 [INFO ] PHN: WEB: Request 28/396/2: POST /dummy.htm HTTP/1.1
08:45:32.112 [INFO ] PHN: WEB: 28 Basic authentication.
08:45:32.116 [WARN ] PHN: No access rights to set parameter user_idle_text2!
08:45:32.116 [WARN ] PHN: No access rights to set parameter user_name2!
08:45:32.116 [WARN ] PHN: No access rights to set parameter user_host2!
08:45:32.116 [WARN ] PHN: No access rights to set parameter user_active2!
08:45:32.117 [WARN ] PHN: No access rights to set parameter user_idle_text3!
08:45:32.117 [WARN ] PHN: No access rights to set parameter user_name3!
08:45:32.117 [WARN ] PHN: No access rights to set parameter user_host3!
08:45:32.117 [WARN ] PHN: No access rights to set parameter user_active3!
08:45:32.117 [WARN ] PHN: No access rights to set parameter user_idle_text4!
08:45:32.118 [WARN ] PHN: No access rights to set parameter user_name4!
08:45:32.118 [WARN ] PHN: No access rights to set parameter user_host4!
08:45:32.118 [WARN ] PHN: No access rights to set parameter user_active4!
08:45:32.120 [DEBUG2] PHN: WEB: HTTP 28/80 disconnected
08:45:32.121 [DEBUG2] PHN: WEB: HTTP 28/80 deleted
08:45:32.252 [DEBUG1] PHN: LID::key_pressed: origin key event, state 2
08:45:32.252 [DEBUG2] PHN: gui_keys: on key event (DND, 0), from_hardware 1, is_longpressed 0, State Idle (28), time 569287
Logge ich mich über die Web-GUI einmal in den erweiterten Admin-Mode ein, kann ich danach die dummy.htm ohne Einschränkungen benutzen. Bis ich den Admin-Mode beende, dann geht es wieder nicht.
Folgendes habe ich bereits probiert:
Parameter Store_settings:
Laut Snom-Wiki müsste in dieser Firmware auch der Parameter
store_settings=save
gesetzt werden. Verwende ich den, kommt jedoch eine Fehlermeldung im Log:
[CRITIC] PHN: Warning: Ignore invalid parameter: store_settings
Username/Password im Request
Ich aber die URL um Username/Password ergänzt
http://admin:[email protected]/dummy.htm?settings=save&user_idle_text1=TEST
bzw. es mit CURL probiert:
curl -u admin:xxxxxx -X GET 'http://192.168.10.99/dummy.htm?settings=save&user_idle_text1=TEST1'
Kein Erfolg
restrict_uri_queries
Ich habe den Parameter restrict_uri_queries auf false bzw. true gesetzt, mit beiden Einstellungen keine Ergebnisse. Auch mit use_hidden_tags on bzw. off gab es keine Änderungen
Hat jemand eine Idee, woran das liegen könnte oder welche Einstellung ich noch verändern müsste?
Lucy68
store_settings=save
Du hast den Wiki-Eintrag erwischt. Die neuste Dokumentation zu dieser Funktion findet sich im Helpdesk… wirklich beitragen kann ich zu Deiner eigentlichen Frage gerade nichts. Nur wilde Idee: Bereits http_scheme=off und dann HTTPs probiert?
… Firmware 8.9.3.61 … Bei anderen Gerätetypen funktioniert das …
Die Frage ist eher, warum das bei den anderen Telefonen klappt. Oder bist Du der Auffassung, dass man diesen speziellen Parameter auch mit User-Rechten ändern können sollte. Die nächste Frage ist, warum Du eine Firmware aus dem Juli 2017 einsetzt? Sind die anderen Snom auf der selben Firmware-Version, neuer oder älter?
Pianist
