ausgehende Nummer setzen
iptelefonie
29 Mrz 2006
Bei mir wird bei abgehenden Anrufen via Capi entweder keine, oder die Standardnummer übertragen. In der Readme von chan_capi habe ich dazu zwar etwas gefunden, aber hat nicht funktioniert.
Ich benutze Asterisk 1.2.23-BRIstuffed-0.3.0-PRE-1y-j mit chan_capi-0.3.5.
Meine capi.conf:
PHP:
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
language=de
defaultcid=[general]
nationalprefix=0
rxgain=0.8
txgain=0.8
language=de                             ;set default language
defaultcid=7584932
;ulaw=yes                                       ;set this, if you live in u-law world instead of a-law
; interface sections ...
[ISDN1]                                                 ;this example interface gets name 'ISDN1' and may be any
        ;name not starting with 'g' or 'contr'.
ntmode=yes                                      ;if isdn card operates in nt mode, set this to yes
isdnmode=did                            ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
        ;when using NT-mode, 'DID' should be set in any case
incomingmsn=*                        ;allow incoming calls to this list of MSNs/DIDs, * = any
msn=7584932
defaultcid=7584932                ;set a default caller id to that interface for dial-out,
        ;this caller id will be used when dial option 'd' is set.
;controller=0                   ;ISDN4BSD default
;controller=7                   ;ISDN4BSD USB default
controller=1                            ;capi controller number to use
group=1                                                 ;dialout group
;prefix=0                                       ;set a prefix to calling number on incoming calls
softdtmf=on                             ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=off                   ;in addition to softdtmf, you can use relaxed dtmf detection
accountcode=2004                                ;Asterisk accountcode to use in CDRs
context=incomming-custom                 ;context for incoming calls
holdtype=local                  ;when Asterisk puts the call on hold, ISDN HOLD will be used. If
        ;set to 'local' (default value), no hold is done and Asterisk may
        ;play MOH.
immediate=yes                   ;DID: immediate start of pbx with extension 's' if no digits were
        ; received on incoming call (no destination number yet)
        ;MSN: start pbx on CONNECT_IND and don't wait for SETUP/SENDING-COMPLETE.
        ; info like REDIRECTINGNUMBER may be lost, but this is necessary for
        ; drivers/pbx/telco which does not send SETUP or SENDING-COMPLETE.
;echosquelch=1                  ;_VERY_PRIMITIVE_ echo suppression
echocancel=yes                  ;EICON DIVA SERVER (CAPI) echo cancelation
        ;(possible values: 'no', 'yes', 'force', 'g164', 'g165')
;echocancelold=yes      ;use facility selector 6 instead of correct 8 (necessary for older eicon drivers)
;echotail=64                            ;echo cancel tail setting
bridge=yes                                      ;native bridging (CAPI line interconnect) if available
;callgroup=1                            ;Asterisk call group
;language=de                            ;set language for this device (overwrites default language)
devices=2
msn=7584932
nationalprefix=0
rxgain=0.8
txgain=0.8
defaultcid=7584932
msn=7584932
        ;play MOH.
devices=2
        ;play MOH.
devices=2
extensions.conf:
In diesem Context wird immer die default MSN (93845) bei ausgehenden Rufen angezeigt:
PHP:
[iax2]
;exten => _0.,1,Dial(CAPI/contr1/7584932:${EXTEN},30,r)
exten => _0.,1,Dial,CAPI/ISDN1/7584932:${EXTEN}|55|Ttr
Hier wird die Nummer immer unterdrückt:
PHP:
[ISDN1]
;exten => _0.,1,Dial,CAPI/contr1/${EXTEN}|55|Ttr
exten => t,1,Hangup()
Ich möchte in verschiedenen Contexten verschiedene MSNs bei abgehenden Anrufen haben.
Danke und Frohe Ostern ;)
Ich empfehle mal ein update von chan_capi.
Armin
Armin
Ich habe jetzt mal ein Update durchgeführt:
Common ISDN API Driver (1.1.0) www.chan-capi.org
Contr1: 2 B channels total, 2 B channels free
Allerdings hat es trotzdem mit dem setzen der abgehenden Nummer noch nicht geklappt.
Folgendes habe ich eben noch ohne Erfolg getestet:
PHP:
exten => _0.,1,set(CALLERID(num)=7584932)
exten => _0.,n,Dial,CAPI/contr1/${EXTEN}|55|Ttr
und anstatt contr1 auch ISDN1 und noch mit 7584932:${EXTEN}.
Wieso klappt das nicht? :(
Was hast du überhaupt für einen Anschluss?
PtP? Zumindest ist es so konfiguriert.
Je nach abgehendem Rufnummerntyp (Internat.,National,Unbekannt) musst du da evtl. deine Vorwahl ohne führende "0" eintragen.
mit
capi debug
set verbose 3
kann man sehen, was gesendet wird...
Mario
-- Accepting overlap voice call from '7584932' to '01608563398' on channel 0/2, span 1
-- Starting simple switch on 'Zap/2-1'
-- Executing Dial("Zap/2-1", "CAPI/ISDN1/7584932:01608563398|55|Ttr") in new stack
> data = ISDN1/7584932:01608563398 format=8
> capi request for interface 'ISDN1'
== ISDN1#02: Call CAPI/ISDN1#02/01608563398-1 (pres=0x20, ton=0x01)
-- Called ISDN1/7584932:01608563398
-- ISDN1#02: received CONNECT_CONF PLCI = 0x101
-- chan_capi queue frame: [ TYPE: Control (4) SUBCLASS: Unknown control '15' (15) ] [ISDN1#02]
-- CAPI/ISDN1#02/01608563398-1 is proceeding passing it to Zap/2-1
-- Channel 0/2, span 1 got hangup request, cause 16
-- ISDN1#02: activehangingup (cause=0) for PLCI=0x101
== Spawn extension (default, 01608563398, 1) exited non-zero on 'Zap/2-1'
-- Hungup 'Zap/2-1'
== ISDN1#02: Interface cleanup PLCI=0x101
Das ist jetzt ein Anruf von einem via ZAP angeschlossenen ISDN-Telefon auf mein Handy. Dort ist die Nummer unterdrückt.
Folgendes funktioniert mittlerweile:
PHP:
[local]
exten => 22,1,set(CALLERID(num)=7584932)
exten => 22,n,Dial,CAPI/ISDN1/01608563398|55|Ttr
Wenn ich von einer anderen Extension, oder einem anderen Asterisk aus einen Call absetze habe ich entweder die Standard-Nr, oder die Nr. wird unterdrückt.
IchBinEsDoch
