[Problem] Aussetzer bei Übertragung (Difference is xx, ms in xx)
rethus
7 Jul 2007
Rahmenbedingung:
  • Telekom Call&Surf IP - Leitung
  • Einwahl über Twinkle, direkt auf der IP des * Servers
  • Nach eingabe der Pin erfolgt login, und MusicOnHold is zu höhren.
Ab dem Moment wo MOH zu höhren ist, läuft in der asterisk_cli (gestartet mit asterisk -c) folgendes ab:
Starting RTCP transmission on RTP instance '0xd10898'
Generator got voice, switching to phase locked mode
Scheduling timer at (0 requested / 0 actual) timer ticks per second
Runt Attribute (got 1, expecting 4)
Runt Attribute (got 2, expecting 4)
Runt Attribute (got 3, expecting 4)
Inconsistent Attribute (length 8228 exceeds remaining msg len 4)
Inconsistent Attribute (length 8228 exceeds remaining msg len 5)
Inconsistent Attribute (length 8228 exceeds remaining msg len 6)
Inconsistent Attribute (length 8228 exceeds remaining msg len 7)
Inconsistent Attribute (length 8228 exceeds remaining msg len 8)
Inconsistent Attribute (length 8228 exceeds remaining msg len 9)
Inconsistent Attribute (length 8228 exceeds remaining msg len 10)
Inconsistent Attribute (length 8228 exceeds remaining msg len 11)
Inconsistent Attribute (length 8228 exceeds remaining msg len 12)
Inconsistent Attribute (length 8228 exceeds remaining msg len 13)
Inconsistent Attribute (length 8228 exceeds remaining msg len 14)
Inconsistent Attribute (length 8228 exceeds remaining msg len 15)
Inconsistent Attribute (length 8228 exceeds remaining msg len 16)
Inconsistent Attribute (length 8228 exceeds remaining msg len 17)
Inconsistent Attribute (length 8228 exceeds remaining msg len 18)
Inconsistent Attribute (length 8228 exceeds remaining msg len 19)
Inconsistent Attribute (length 8228 exceeds remaining msg len 20)
Inconsistent Attribute (length 8228 exceeds remaining msg len 21)
Inconsistent Attribute (length 8228 exceeds remaining msg len 22)
Difference is 15368, ms is 1941
Got RTCP report of 92 bytes
Difference is 41592, ms is 5219
Auto destroying SIP dialog '[email protected]'
Destroying SIP dialog [email protected].120.10
Difference is 13272, ms is 1679
Jeweils genau bei der Ausgabe "Difference..." ist dann eine Unterbreschung von 1-4 Sekunden. Also bei der Ausgabe von:
Woran kann das liegen?
figo12
