Automatic restart of openvpn
warp_be
6 Feb 2007
i installed a long time ago openvpn, which works fine.
But each time the fritz box is restarted (ok it doesn't happen so often, but it happens), i have to restart the openvpn daemon by myself.
Which is the way to make it start automatically ?
Thanks.
First time you should give us a bit of your logfiles, cause without ane further infomation noone could guess what your problem is.
Have you enabled the automatisch start in the Web-Config-Page?
How does your confirguration look like?
cat /mod/etc/openvpn.conf
cat /var/tmp/flash/openvpn*.diff
figo12
