Avm fritzbox 7490 kernel panic!!!
Gtheod
15 Jul 2019
Hi
I have an avm fritzbox 7490 rebooting ...i manage to capture the log file with the help of ttl2usb adapter
But i cant undestand if its hardware or software failure
Any help would be appreciated
Thank you in advace !!!
[ 16.170000] Rebooting in 5 seconds..
ROM VER: 1.1.4
CFG 05
** START
RVEC bf200000
(AVM) EVA Revision: 1.1964 Version: 2964
(C) Copyright 2005 AVM Date: Nov 27 2013 Time: 14:33:10 (1) 3 0x0-0x740D
[FLASH:] WINBOND Uniform-Flash 1MB 256 Bytes WriteBuffer
[FLASH:](Eraseregion [0] 16 sectors a 64kB)
[NAND:] 512MB MICRON 2048 Pagesize 128k Blocksize 4096 Blocks 8Bit 1 CS HW
[SYSTEM:] VR9 on 500MHz/250MHz/250MHz
.Atheros 8030/35 detected
Eva_AVM >##....................................................
Lantiq xDSL CPE VR9
phym = 10000000, mem = 10000000, max_pfn = 00010000
Reserving memory for CP1 @0xb0000000, size 0x00000000
plat_device_tree_setup: AVM hardware subrevision 6
plat_device_tree_setup: using Fallback device-tree of AVM hardware subrevision 0
DT: d0 0d fe ed 00 00 14 36
[ 0.000000] Linux version 3.10.73 (jpluschke@GU_IQ17p1_vr9) (gcc version 4.8.3 (Buildroot 2014.08) ) #1 SMP Mon Nov 27 18:31:19 CET 2017
[ 0.000000] [env_init] 0x81018160[0]
[ 0.000000] [env_init] 0x810181a0[1]
[ 0.000000] [env_init] 0x810182a0[2]
[ 0.000000] [env_init] switch to ram location
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config (ptr 80858000)
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config: module memory entry
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config: version info entry
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config: device-tree for subrev 0 found
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019556 (MIPS 34Kc)
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 10000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] [module-alloc] use 0xb2f000 bytes at 0x81205000
[ 0.000000] [0]lsmtc_smp_setup tcstatus=18102400
[ 0.000000] PERCPU: Embedded 7 pages/cpu @81d38000 s7232 r8192 d13248 u32768
[ 0.000000] Kernel command line: console=ttyS0,115200n8r nor_size=0MB sflash_size=1024KB nand_size=512MB ethaddr=38:10:D5:CC:3D:B1
[ 0.000000] [NAND] nand_size = 0x20000000
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Writing ErrCtl register=0001da20
[ 0.000000] Readback ErrCtl register=0001da20
[ 0.000000] Memory: 238888k/262144k available (5620k kernel code, 23256k reserved, 2979k data, 288k init, 0k highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:181
[ 0.000000] SRSConf0 0x3feffbfe: SRS1: 0xffffffff, SRS2 0xffffffff, SRS3 0xffffffff
[ 0.000000] Lantiq ICU driver, version 3.0.1, (c) 2001-2011 Lantiq Deutschland GmbH
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [ttyS0] enabled, bootconsole disabled
[ 0.020000] Calibrating delay loop... 331.77 BogoMIPS (lpj=1658880)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Security Framework initialized
[ 0.080000] Mount-cache hash table entries: 512
[ 0.090000] CPU1 revision is: 00019556 (MIPS 34Kc)
[ 0.170000] Brought up 2 CPUs
[ 0.170000] [yield_context_init] cpu=1 tc=2 mask=301
[ 0.180000] [yield_context_init] cpu=0 tc=3 mask=2410
[ 0.180000] devtmpfs: initialized
[ 0.200000] pinctrl core: initialized pinctrl subsystem
[ 0.200000] Creating Config Table
[ 0.200000] [avm_generate_hw_config_table_from_device_tree] gpio_cnt: 46
[ 0.210000] NET: Registered protocol family 16
[ 0.220000] avm_check_cpu_features: mips-options: 0x006d638b icache.flags 0x00000000 dcache.flags 0x00000004 isa_level 0x00000063 ases 00000031
[ 0.230000] [TFFS3_Early_Init] called
[ 0.230000] Reboot Status is: Soft-Reboot(KCRASH) Irregular Reboots: SUM(2) - KCRASH(2)
[ 0.240000] avm_alloc_page_extension node_extension_table[0] entries=65536 (size=262144) alloced
[ 0.240000] [avmnet] [avmnet_cfg_init] Driver version: 6.247.4.4 - Revision 1496:3715 - Mo 27. Nov 18:30:32 CET 2017
[ 1.050000] Lantiq PCIe Root Complex driver, version 2.0.0, (c) 2001-2011 Lantiq Deutschland GmbH
[ 1.100000] bio: create slab <bio-0> at 0
[ 1.100000] PCI host bridge to bus 0000:00
[ 1.110000] pci_bus 0000:00: root bus resource [mem 0x1c000000-0x1cffffff]
[ 1.110000] pci_bus 0000:00: root bus resource [io 0x1d800000-0x1d8fffff]
[ 1.120000] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 1.130000] ifx_pcie_rc_class_early_fixup port 0: fixed pcie host bridge to pci-pci bridge
[ 1.140000] pci 0000:00:00.0: BAR 8: assigned [mem 0x1c000000-0x1c0fffff]
[ 1.140000] pci 0000:01:00.0: BAR 0: assigned [mem 0x1c000000-0x1c001fff 64bit]
[ 1.150000] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.160000] pci 0000:00:00.0: bridge window [mem 0x1c000000-0x1c0fffff]
[ 1.170000] NET: Registered protocol family 8
[ 1.170000] NET: Registered protocol family 20
[ 1.170000] Switching to clocksource MIPS
[ 1.240000] NET: Registered protocol family 2
[ 1.240000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 1.250000] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 1.260000] TCP: Hash tables configured (established 2048 bind 2048)
[ 1.260000] TCP: reno registered
[ 1.260000] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.270000] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.280000] avm_pa: try to activate hw accelaration for pid 1 (ipv4)
[ 1.280000] NET: Registered protocol family 1
[ 1.290000] pci 0000:01:00.0: xHCI HW not ready after 5 sec (HC bug?) status = 0x801
[ 1.300000] Lantiq CGU driver, version 1.1.32, (c) 2001-2011 Lantiq Deutschland GmbH
[ 1.310000] IFX DMA driver, version ifxmips_dma_core.c:v1.0.17, (c) 2009 Infineon Technologies AG
[ 1.310000] skb_shared_size:184
[ 1.330000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.330000] fuse init (API version 7.22)
[ 1.330000] msgmni has been set to 466
[ 1.340000] io scheduler noop registered (default)
[ 1.680000] ttyS0 at MMIO 0x1e100c00 (irq = 107) is a PORT_IFX_ASC
[ 1.690000] ifx_usif_uart_init: uart_register_driver failed
[ 1.700000] avm_net_trace: Up and running.
[ 1.700000] [loadcontrol] set auto - scale=1
[ 1.710000] [simple-profiling]:2 performance counters implemented, NEW_34K
[ 1.710000] [simple-profiling]Enable Performance Counter 0 for Data cache load/stores (User Supervisor Kernel Exception TC-ID=0) all cores tc: 0
[ 1.730000] [simple-profiling]Enable Performance Counter 1 for Data cache load/store misses (User Supervisor Kernel Exception TC-ID=0) all cores tc: 0
[ 1.740000] [simple-profiling]Enable Performance Counter 0 for Data cache load/stores (User Supervisor Kernel Exception TC-ID=1) all cores tc: 1
[ 1.750000] [simple-profiling]Enable Performance Counter 1 for Data cache load/store misses (User Supervisor Kernel Exception TC-ID=1) all cores tc: 1
[ 1.770000] [simple-profiling]Enable Performance Counter 0 for Main pipeline stalls (P) (User Supervisor Kernel Exception TC-ID=2) all cores tc: 2
[ 1.780000] [simple-profiling]Enable Performance Counter 1 for Cycles (P) (User Supervisor Kernel Exception TC-ID=2) all cores tc: 2
[ 1.790000] [simple-profiling]Enable Performance Counter 0 for Data cache load/stores (User Supervisor Kernel Exception TC-ID=3) all cores tc: 3
[ 1.800000] [simple-profiling]Enable Performance Counter 1 for Data cache load/store misses (User Supervisor Kernel Exception TC-ID=3) all cores tc: 3
[ 1.820000] [simple-profiling]all cores:performance-mode (round-robin): cpus on
[ 1.820000] Lantiq Thermal Sensor driver, version 1.0.3, (c) 2001-2011 Lantiq Deutschland GmbH
[ 1.830000] ifx_pmu_init: Major 244
[ 1.840000] Lantiq PMU driver, version 1.2.6, (c) 2001-2011 Lantiq Deutschland GmbH
[ 1.840000] Lantiq GPIO driver, version 1.3.2, (c) 2001-2011 Lantiq Deutschland GmbH
[ 1.850000] Infineon Technologies RCU driver version 1.0.7
[ 1.870000] loop: module loaded
[ 1.870000] nbd: registered device at major 43
[ 1.900000] [HSNAND] Hardware-ECC activated
[ 1.910000] ONFI param page 0 valid
[ 1.910000] ONFI flash detected
[ 1.910000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xdc (Micron MT29F4G08ABADAWP), 512MiB, page size: 2048, OOB size: 64
[ 1.930000] Scanning device for bad blocks
[ 2.340000] Creating 6 MTD partitions on "ifx_hsnand":
[ 2.340000] 0x000000000000-0x000000400000 : "kernel"
[ 2.350000] 0x000000400000-0x000003400000 : "filesystem"
[ 2.360000] 0x000003400000-0x000003800000 : "reserved-kernel"
[ 2.370000] 0x000003800000-0x000006800000 : "reserved-filesystem"
[ 2.370000] 0x000006800000-0x000006a00000 : "config"
[ 2.380000] 0x000006a00000-0x000020000000 : "nand-filesystem"
[ 2.390000] [TFFS3_Register_Panic_CB] registering panic callback for mtd ifx_hsnand
[ 2.400000] [TFFS3_Register_Panic_CB] registering panic callback for mtd ifx_sflash
[ 2.400000] Creating 3 MTD partitions on "ifx_sflash":
[ 2.410000] 0x000000000000-0x000000040000 : "urlader"
[ 2.420000] 0x000000040000-0x0000000a0000 : "tffs (1)"
[ 2.420000] 0x0000000a0000-0x000000100000 : "tffs (2)"
[ 2.430000] Lantiq SPI flash driver, version 2.0.2, (c) 2001-2011 Lantiq Deutschland GmbH
[ 2.440000] tun: Universal TUN/TAP device driver, 1.6
[ 2.440000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 2.450000] SWAPI: Registered character device [switch_api] with major no [81]
[ 2.460000] i2c /dev entries driver
[ 2.460000] cpuidle: using governor ladder
[ 2.460000] cpuidle: using governor menu
[ 2.470000] AVM PA for Linux 3.10.73
[ 2.470000] AVM PA skb pktinfo at offset 136 size 208
[ 2.480000] [loadcontrol]module avm_pa registered
[ 2.480000] u32 classifier
[ 2.480000] Performance counters on
[ 2.490000] Actions configured
[ 2.490000] ipip: IPv4 over IPv4 tunneling driver
[ 2.500000] TCP: cubic registered
[ 2.500000] NET: Registered protocol family 10
[ 2.500000] avm_pa: try to activate hw accelaration for pid 2 (ipv6)
[ 2.510000] sit: IPv6 over IPv4 tunneling driver
[ 2.520000] NET: Registered protocol family 17
[ 2.520000] Bridge broadcast ratelimiter registered
[ 2.520000] l2tp_core: L2TP core driver, V2.0
[ 2.530000] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 2.530000] l2tp_netlink: L2TP netlink interface
[ 2.540000] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 2.540000] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[ 2.550000] 8021q: 802.1Q VLAN Support v1.8
[ 2.560000] Key type dns_resolver registered
[ 2.560000] <ifx_fix_timing>
[ 2.570000] [TFFS3_Init] No storage module registered, trying legacy fallback
[ 2.570000] [TFFS3_Register_LGCY] Called
[ 2.580000] [TFFS3_LGCY_Configure] Called
[ 2.580000] [TFFS3_LGCY_Setup] using mtd7(tffs (1)), mtd8(tffs (2))
[ 2.590000] [TFFS3_LGCY_Setup] mtd "tffs (1)": segment value 954
[ 2.590000] [TFFS3_LGCY_Setup] mtd "tffs (2)": segment value 955
[ 2.600000] [TFFS3_LGCY_Setup] Using segment 955 (avail: 954 + 955)
[ 2.600000] [TFFS3_LGCY_Setup] mtd8 size=0x60000
[ 2.610000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0)
[ 2.610000] [rescan_segment] Called with mode=2
[ 2.610000] TFFS: Clearing index for update
[ 2.630000] Adam2 environment variables API installed.
[ 2.630000] {avmnet_cfg_netinit}
[ 2.630000] [avmnet] No config found for HWRev 185, HWSubRev 6, Profile-ID 0, trying base config for HWSubRev
[ 2.640000] [avmnet] No config found for HWRev 185, HWSubRev 6, trying base config for HWRev
[ 2.650000] [avmnet] [avmnet_swi_7port_init] Init on module swi_vr9 called.
[ 3.010000] [ppe_eth_init] init_hw()
[ 3.010000] [init_hw] ppe_hw_init=0xff successful
[ 3.020000] [ppe_eth_init] ifx_proc_file_create()
[ 3.020000] [ppe_eth_init] dma_setup_init()
[ 3.030000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x48
[ 3.040000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x48
[ 3.810000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 4.830000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 5.610000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 6.630000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 7.410000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 8.440000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 9.210000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 10.240000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 10.680000] system-load 4 loadavg 0.46 0.10 0.3 - 32 tasks:87 % curr:swapper/0(23 %) max:migration/0(38 %, pid:7) pgstat: sum=59154 free=58005 slab=2210 alloc=512/s fault=0/s (sleep 0)
[ 11.030000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 11.480000] system-load 100% loadavg 0.46 0.10 0.3 - 32 tasks:6 % curr:swapper/0(0 %) max:migration/1(6 %, pid:12) pgstat: sum=59154 free=58005 slab=2210 alloc=0/s fault=0/s (sleep 0)
[ 12.070000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 12.850000] [avmnet] [setup_phy] Giving up on hanging PHY phy_ar803x_1
[ 12.860000] [avmnet] [avmnet_ar803x_setup] setup failed for module phy_ar803x_1
[ 12.860000] [avmnet] Module mac_7port_1: setup() failed on child phy_ar803x_1
[ 12.870000] [avmnet] Module swi_vr9: setup() failed on child mac_7port_1
[ 12.880000] [avmnet] [avmnet_cfg_netinit] network module setup returned with error
[ 12.880000] [kernel-breakpoint] pc=0x803e7d30(avmnet_cfg_netinit+0x2d0/0x420) addr=0x8fc3be3c task=swapper/0 pid=1 ra=0x803e7d30(avmnet_cfg_netinit+0x2d0/0x420)
[ 12.900000] Code(0x803e7d28): 0x0c013180 0x26455448 <0x000c000d> 0x080f9f4d 0x00000000
[ 12.910000] set_reboot_status: Soft-Reboot(KCRASH) - KCRASH(3) SUM(3)
[ 12.910000] BUG() at function 'avmnet_cfg_netinit' line: 946 file: drivers/net/ethernet/avm/avm_cpmac/common/avmnet_config.c
[ 12.920000] === MIPS MT State Dump ===
[ 12.920000] -- Global State --
[ 12.920000] MVPControl Read: 00000005
[ 12.920000] MVPConf0 : b8008403
[ 12.920000] -- per-VPE State --
[ 12.920000] VPE 0
[ 12.920000] VPEControl : 00008000
[ 12.920000] VPEConf0 : 800f0003
[ 12.920000] VPE0.Status : 1100ff01
[ 12.920000] VPE0.EPC : 802d94c0 arch_local_irq_restore+0x60/0x80
[ 12.920000] VPE0.Cause : 10800000
[ 12.920000] VPE0.Config7 : 80080400
[ 12.920000] VPE 1
[ 12.920000] VPEConf0 : 802f0003
[ 12.920000] VPE1.Status : 1100c601
[ 12.920000] VPE1.EPC : 8001f028 __pastwait+0x0/0x18
[ 12.920000] VPE1.Cause : 10800000
[ 12.920000] VPE1.Config7 : 80080400
[ 12.920000] -- per-TC State --
[ 12.920000] TC 0 (current TC with VPE EPC above)
[ 12.920000] TCStatus : 00000000
[ 12.920000] TCBind : 00000000
[ 12.920000] TCRestart: 80027ab0 mips_mt_regdump+0x130/0x4a0
[ 12.920000] TCHalt : 00000000
[ 12.920000] TCContext: 00000000
[ 12.920000] SP: 8fc3b820
[ 12.920000] GP: 8fc38000
[ 12.920000] RA: 800279b0 mips_mt_regdump+0x30/0x4a0
[ 12.920000] TC 1
[ 12.920000] TCStatus : 18902400
[ 12.920000] TCBind : 00200001
[ 12.920000] TCRestart: 8001f000 r4k_wait_irqoff+0x20/0x48
[ 12.920000] TCContext: 00140000
[ 12.920000] SP: 8fc83ec8
[ 12.920000] GP: 8fc80000
[ 12.920000] RA: 8001eff0 r4k_wait_irqoff+0x10/0x48
[ 12.920000] TC 2
[ 12.920000] TCStatus : 09102400
[ 12.920000] TCBind : 00400001
[ 12.920000] TCRestart: 80028fac yield_context_thread+0x1ac/0x360
[ 12.920000] SP: 8fcc7ed0
[ 12.920000] GP: 8fcc4000
[ 12.920000] RA: f6202911 0xf6202911
[ 12.920000] TC 3
[ 12.920000] TCBind : 00600000
[ 12.920000] SP: 8fcd7ed0
[ 12.920000] GP: 8fcd4000
[ 12.920000] RA: 4c318800 0x4c318800
[ 12.920000] ===========================
[ 13.130000] Kernel bug detected[#1]:
[ 13.140000] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.73 #1
[ 13.140000] task: 8fc37ad8 ti: 8fc38000 task.ti: 8fc38000
[ 13.150000] $ 0 : 00000000 18102000 00000046 00000000
[ 13.150000] $ 4 : 18102000 00000400 0000012d 0000012d
[ 13.160000] $ 8 : 00000003 00000000 00005920 00000000
[ 13.160000] $12 : 00000000 0000012d 00000000 00000000
[ 13.170000] $16 : 8075de1c 80920000 805c0000 00000006
[ 13.170000] $20 : 00000000 80920000 8089d8a4 8089d8e4
[ 13.180000] $24 : 00000001 00000000
[ 13.180000] $28 : 8fc38000 8fc3be38 00000051 803e7d30
[ 13.190000] Hi : 00002260
[ 13.190000] Lo : 00008980
[ 13.200000] ac1Hi: 00000000 ac1Lo: 00000000
[ 13.200000] ac2Hi: 00000000 ac2Lo: 00000000
[ 13.200000] ac3Hi: 00000000 ac3Lo: 00000000
[ 13.210000] dspcontrol: 00000000
[ 13.210000] Status: 1100ff03 KERNEL EXL IE
[ 13.220000] Cause : 10800024 exc_code:9
[ 13.220000] epc : 803e7d30 avmnet_cfg_netinit+0x2d0/0x420
[ 13.230000] ra : 803e7d30 avmnet_cfg_netinit+0x2d0/0x420
[ 13.230000] Not tainted
[ 13.230000] PrId : 00019556 (MIPS 34Kc)
[ 13.240000] Modules linked in:
[ 13.240000] Process swapper/0 (pid: 1, threadinfo=8fc38000, task=8fc37ad8, tls=00000000)
[ 13.250000] Stack : 807159e0 805c5448 0000012c 0000012c 00000000 806d8e78 00000000 808b0000
00000000 803e7a60 00000008 807159e0 8086821c 8000eca8 81d350e2 00000007
00000007 00000001 808a67e4 00000007 808b0000 00000008 808a683c 00000007
808b0000 00000008 807159e0 80868afc cccccccc cccccccc 8fc37668 807338b0
00000007 00000007 8086821c 800801fc 80007800 00000000 00000000 00000000
[ 13.280000] Call Trace:
[ 13.290000] [<803e7d30>] avmnet_cfg_netinit+0x2d0/0x420
[ 13.290000] [<8000eca8>] do_one_initcall+0x108/0x220
[ 13.300000] [<80868afc>] kernel_init_freeable+0x16c/0x22c
[ 13.300000] [<80007818>] kernel_init+0x18/0x180
[ 13.310000] [<800024e8>] ret_from_kernel_thread+0x14/0x1c
[ 13.310000]
[ 13.310000]
Code: 24848dfc 0c013180 26455448 <000c000d> 080f9f4d 00000000 24848da0 0c013180 26455448
[ 13.320000] CPU_ID=0 TC0 ----- (LINUX)
[ 13.330000] Status: 1100ff01 KERNEL IE
[ 13.330000] current: swapper/0 (pid: 1, threadinfo=8fc38000, task=8fc37ad8, sp=8fc3ba38 tls=0x00000000)
[ 13.340000] Call Trace:
[ 13.340000] [<802d8060>] arch_trigger_all_cpu_backtrace+0x120/0x740
[ 13.350000] [<8036492c>] die_notifier+0xac/0x100
[ 13.350000] [<8007af1c>] notifier_call_chain+0x5c/0xe0
[ 13.360000] [<8007bac4>] notify_die+0x44/0x60
[ 13.360000] [<800230cc>] die+0x4c/0x140
[ 13.370000] [<80023424>] do_trap_or_bp+0x204/0x220
[ 13.370000] [<80002480>] ret_from_exception+0x0/0x18
[ 13.380000] [<803e7d30>] avmnet_cfg_netinit+0x2d0/0x420
[ 13.380000] [<8000eca8>] do_one_initcall+0x108/0x220
[ 13.390000] [<80868afc>] kernel_init_freeable+0x16c/0x22c
[ 13.390000] [<80007818>] kernel_init+0x18/0x180
[ 13.400000] [<800024e8>] ret_from_kernel_thread+0x14/0x1c
[ 13.400000]
[ 13.400000] CPU_ID=1 TC1 ----- (LINUX)
[ 13.410000] Status: 1100c601 KERNEL IE
[ 13.410000] current: swapper/1 (pid: 0, threadinfo=8fc80000, task=8fc5ada8, sp=8fc83ec8 tls=0x00000000)
[ 13.420000] Call Trace:
[ 13.420000] [<8001f000>] r4k_wait_irqoff+0x20/0x48
[ 13.430000] [<80090260>] cpu_startup_entry+0x180/0x1e0
[ 13.430000] [<8088eb7c>] smp_bootstrap+0xc/0x60
[ 13.440000]
[ 13.440000] YIELD-TC2 -----
[ 13.440000] current: CPU1-YIELD-TC2 (pid: 0, threadinfo=8fcc4000, task=8fcc0018, sp=8fcc7ed0 tls=0x00000000)
[ 13.450000] Call Trace:
[ 13.450000] [<80028fac>] yield_context_thread+0x1ac/0x360
[ 13.460000]
[ 13.460000] YIELD-TC3 -----
[ 13.460000] current: CPU0-YIELD-TC3 (pid: 0, threadinfo=8fcd4000, task=8fcd0018, sp=8fcd7ed0 tls=0x00000000)
[ 13.470000] Call Trace:
[ 13.480000] [<80028fac>] yield_context_thread+0x1ac/0x360
[ 13.480000]
[ 13.480000] ---[ end trace 2c6f69369de21979 ]---
[ 13.490000] [tffs_open_panic] Called. panic_handle_use: 0
[ 13.490000] [TFFS3_Panic_Lock] Called.
[ 13.490000] [panic_reinit] Called for mtd ifx_hsnand
[ 13.490000] [panic_reinit] Called for mtd ifx_sflash
[ 13.490000] [tffs_open_panic] z_length: 0x8010
[ 13.490000] [tffs_release_kern] Close error -28 on ID 0x60
[ 13.490000]
[ 13.490000]
[ 13.490000] ------------------- Last part of Panic-log Content: -------------------
[ 13.490000]
[ 13.490000] 2144k available (5620k kernel code, 23256k reserved, 2979k data, 288k init, 0k highmem)
[ 13.490000] [ 0.000000] Hierarchical RCU implementation.
[ 13.490000] [ 0.000000] NR_IRQS:181
[ 13.490000] [ 0.000000] SRSConf0 0x3feffbfe: SRS1: 0xffffffff, SRS2 0xffffffff, SRS3 0xffffffff
[ 13.490000] [ 0.000000] Lantiq ICU driver, version 3.0.1, (c) 2001-2011 Lantiq Deutschland GmbH
[ 13.490000] [ 0.000000] Console: colour dummy device 80x25
[ 13.490000] [ 0.000000] console [ttyS0] enabled, bootconsole disabled
[ 13.490000] [ 0.020000] Calibrating delay loop... 331.77 BogoMIPS (lpj=1658880)
[ 13.490000] [ 0.080000] pid_max: default: 32768 minimum: 301
[ 13.490000] [ 0.080000] Security Framework initialized
[ 13.490000] [ 0.080000] Mount-cache hash table entries: 512
[ 13.490000] [ 0.090000] I-cache flushes single-threaded
[ 13.490000] [ 0.090000] D-cache flushes single-threaded
[ 13.490000] [ 0.090000] Limit of 2 TCs set
[ 13.490000] [ 0.090000] TLB of 32 entry pairs shared by 2 VPEs
[ 13.490000] [ 0.090000] VPE 0: TC 0, VPE 1: TC 1
[ 13.490000] [ 0.090000] IPI buffer pool of 8 buffers
[ 13.490000] [ 0.090000] CPU1 revision is: 00019556 (MIPS 34Kc)
[ 13.490000] [ 0.170000] TC 1 going on-line as CPU 1
[ 13.490000] [ 0.170000] Brought up 2 CPUs
[ 13.490000] [ 0.170000] [yield_context_init] cpu=1 tc=2 mask=301
[ 13.490000] [ 0.180000] [yield_context_init] cpu=0 tc=3 mask=2410
[ 13.490000] [ 0.180000] devtmpfs: initialized
[ 13.490000] [ 0.200000] pinctrl core: initialized pinctrl subsystem
[ 13.490000] [ 0.200000] Creating Config Table
[ 13.490000] [ 0.200000] [avm_generate_hw_config_table_from_device_tree] gpio_cnt: 46
[ 13.490000] [ 0.210000] NET: Registered protocol family 16
[ 13.490000] [ 0.220000] FPU Affinity set after 5000 emulations
[ 13.490000] [ 0.220000] avm_check_cpu_features: mips-options: 0x006d638b icache.flags 0x00000000 dcache.flags 0x00000004 isa_level 0x00000063 ases 00000031
[ 13.490000] [ 0.230000] [TFFS3_Early_Init] called
[ 13.490000] [ 0.230000] Reboot Status is: Soft-Reboot(KCRASH) Irregular Reboots: SUM(2) - KCRASH(2)
[ 13.490000] [ 0.240000] avm_alloc_page_extension node_extension_table[0] entries=65536 (size=262144) alloced
[ 13.490000] [ 0.240000] [avmnet] [avmnet_cfg_init] Driver version: 6.247.4.4 - Revision 1496:3715 - Mo 27. Nov 18:30:32 CET 2017
[ 13.490000] [ 0.250000] Port 0 PLL REGFILE
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_CTRL1 0x8e39
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_CTRL2 0x0183
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_CTRL3 0x0042
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_CTRL4 0x0000
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_CTRL5 0x0000
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_CTRL6 0x0000
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_CTRL7 0x0000
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_A_CTRL1 0x120e
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_A_CTRL2 0x39d7
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_A_CTRL3 0x0900
[ 13.490000] [ 0.250000] PCIE_PHY_PLL_STATUS 0x0000
[ 13.490000] [ 0.250000] TX1 REGFILE
[ 13.490000] [ 0.250000] PCIE_PHY_TX1_CTRL1 0x0009
[ 13.490000] [ 0.250000] PCIE_PHY_TX1_CTRL2 0x2e00
[ 13.490000] [ 0.250000] PCIE_PHY_TX1_CTRL3 0x1fff
[ 13.490000] [ 0.250000] PCIE_PHY_TX1_A_CTRL1 0x0810
[ 13.490000] [ 0.250000] PCIE_PHY_TX1_A_CTRL2 0x0706
[ 13.490000] [ 0.250000] PCIE_PHY_TX1_MOD1 0x0000
[ 13.490000] [ 0.250000] PCIE_PHY_TX1_MOD2 0x0000
[ 13.490000] [ 0.250000] PCIE_PHY_TX1_MOD3 0x0180
[ 13.490000] [ 0.250000] TX2 REGFILE
[ 13.490000] [ 0.250000] PCIE_PHY_TX2_CTRL1 0x0009
[ 13.490000] [ 0.250000] PCIE_PHY_TX2_CTRL2 0x3096
[ 13.490000] [ 0.250000] PCIE_PHY_TX2_A_CTRL1 0x8010
[ 13.490000] [ 0.250000] PCIE_PHY_TX2_A_CTRL2 0x4707
[ 13.490000] [ 0.250000] PCIE_PHY_TX2_MOD1 0x0000
[ 13.490000] [ 0.250000] PCIE_PHY_TX2_MOD2 0x0000
[ 13.490000] [ 0.250000] PCIE_PHY_TX2_MOD3 0x0180
[ 13.490000] [ 0.250000] RX1 REGFILE
[ 13.490000] [ 0.250000] PCIE_PHY_RX1_CTRL1 0x0001
[ 13.490000] [ 0.250000] PCIE_PHY_RX1_CTRL2 0x3000
[ 13.490000] [ 0.250000] PCIE_PHY_RX1_CDR 0x0235
[ 13.490000] [ 0.250000] PCIE_PHY_RX1_EI 0x0004
[ 13.490000] [ 0.250000] PCIE_PHY_RX1_A_CTRL 0x6803
[ 13.490000] [ 0.260000] Port 0 PLL REGFILE
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_CTRL1 0x38e4
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_CTRL2 0x03ee
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_CTRL3 0x0000
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_CTRL4 0x1b72
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_CTRL5 0xfae3
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_CTRL6 0x3a04
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_CTRL7 0x0002
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_A_CTRL1 0x120e
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_A_CTRL2 0x39d7
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_A_CTRL3 0x2900
[ 13.490000] [ 0.260000] PCIE_PHY_PLL_STATUS 0x0070
[ 13.490000] [ 0.260000] TX1 REGFILE
[ 13.490000] [ 0.260000] PCIE_PHY_TX1_CTRL1 0x0009
[ 13.490000] [ 0.260000] PCIE_PHY_TX1_CTRL2 0x2e00
[ 13.490000] [ 0.260000] PCIE_PHY_TX1_CTRL3 0x1fff
[ 13.490000] [ 0.260000] PCIE_PHY_TX1_A_CTRL1 0x0810
[ 13.490000] [ 0.260000] PCIE_PHY_TX1_A_CTRL2 0x0706
[ 13.490000] [ 0.260000] PCIE_PHY_TX1_MOD1 0x1ffe
[ 13.490000] [ 0.260000] PCIE_PHY_TX1_MOD2 0xfffe
[ 13.490000] [ 0.260000] PCIE_PHY_TX1_MOD3 0x0001
[ 13.490000] [ 0.260000] TX2 REGFILE
[ 13.490000] [ 0.260000] PCIE_PHY_TX2_CTRL1 0x0009
[ 13.490000] [ 0.260000] PCIE_PHY_TX2_CTRL2 0x3096
[ 13.490000] [ 0.260000] PCIE_PHY_TX2_A_CTRL1 0x8010
[ 13.490000] [ 0.260000] PCIE_PHY_TX2_A_CTRL2 0x4707
[ 13.490000] [ 0.260000] PCIE_PHY_TX2_MOD1 0x1ffe
[ 13.490000] [ 0.260000] PCIE_PHY_TX2_MOD2 0xfffe
[ 13.490000] [ 0.260000] PCIE_PHY_TX2_MOD3 0x0001
[ 13.490000] [ 0.260000] RX1 REGFILE
[ 13.490000] [ 0.260000] PCIE_PHY_RX1_CTRL1 0x0001
[ 13.490000] [ 0.260000] PCIE_PHY_RX1_CTRL2 0x3000
[ 13.490000] [ 0.260000] PCIE_PHY_RX1_CDR 0x0235
[ 13.490000] [ 0.260000] PCIE_PHY_RX1_EI 0x0004
[ 13.490000] [ 0.260000] PCIE_PHY_RX1_A_CTRL 0x6803
[ 13.490000] [ 1.050000] Lantiq PCIe Root Complex driver, version 2.0.0, (c) 2001-2011 Lantiq Deutschland GmbH
[ 13.490000] [ 1.100000] bio: create slab <bio-0> at 0
[ 13.490000] [ 1.100000] PCI host bridge to bus 0000:00
[ 13.490000] [ 1.110000] pci_bus 0000:00: root bus resource [mem 0x1c000000-0x1cffffff]
[ 13.490000] [ 1.110000] pci_bus 0000:00: root bus resource [io 0x1d800000-0x1d8fffff]
[ 13.490000] [ 1.120000] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 13.490000] [ 1.130000] pci 0000:00:00.0: [1bef:0011] type 01 class 0x060000
[ 13.490000] [ 1.130000] ifx_pcie_rc_class_early_fixup port 0: fixed pcie host bridge to pci-pci bridge
[ 13.490000] [ 1.140000] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 13.490000] [ 1.140000] pci 0000:01:00.0: [1912:0015] type 00 class 0x0c0330
[ 13.490000] [ 1.140000] pci 0000:01:00.0: reg 10: [mem 0x00000000-0x00001fff 64bit]
[ 13.490000] [ 1.140000] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 13.490000] [ 1.140000] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 13.490000] [ 1.140000] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
[ 13.490000] [ 1.140000] pci 0000:00:00.0: BAR 8: assigned [mem 0x1c000000-0x1c0fffff]
[ 13.490000] [ 1.140000] pci 0000:01:00.0: BAR 0: assigned [mem 0x1c000000-0x1c001fff 64bit]
[ 13.490000] [ 1.150000] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 13.490000] [ 1.160000] pci 0000:00:00.0: bridge window [mem 0x1c000000-0x1c0fffff]
[ 13.490000] [ 1.170000] NET: Registered protocol family 8
[ 13.490000] [ 1.170000] NET: Registered protocol family 20
[ 13.490000] [ 1.170000] Switching to clocksource MIPS
[ 13.490000] [ 1.240000] NET: Registered protocol family 2
[ 13.490000] [ 1.240000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 13.490000] [ 1.250000] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 13.490000] [ 1.260000] TCP: Hash tables configured (established 2048 bind 2048)
[ 13.490000] [ 1.260000] TCP: reno registered
[ 13.490000] [ 1.260000] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 13.490000] [ 1.270000] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 13.490000] [ 1.280000] avm_pa: try to activate hw accelaration for pid 1 (ipv4)
[ 13.490000] [ 1.280000] NET: Registered protocol family 1
[ 13.490000] [ 1.290000] PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
[ 13.490000] [ 1.290000] pci 0000:01:00.0: xHCI HW not ready after 5 sec (HC bug?) status = 0x801
[ 13.490000] [ 1.300000] PCI: CLS 0 bytes, default 32
[ 13.490000] [ 1.300000] Lantiq CGU driver, version 1.1.32, (c) 2001-2011 Lantiq Deutschland GmbH
[ 13.490000] [ 1.310000] IFX DMA driver, version ifxmips_dma_core.c:v1.0.17, (c) 2009 Infineon Technologies AG
[ 13.490000] [ 1.310000] skb_shared_size:184
[ 13.490000] [ 1.330000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 13.490000] [ 1.330000] fuse init (API version 7.22)
[ 13.490000] [ 1.330000] yaffs: yaffs built Nov 27 2017 18:31:03 Installing.
[ 13.490000] [ 1.330000] msgmni has been set to 466
[ 13.490000] [ 1.340000] io scheduler noop registered (default)
[ 13.490000] [ 1.340000] [avm_membench_init]
[ 13.490000] [ 1.680000] ttyS0 at MMIO 0x1e100c00 (irq = 107) is a PORT_IFX_ASC
[ 13.490000] [ 1.690000] ifx_usif_uart_init: uart_register_driver failed
[ 13.490000] [ 1.700000] avm_net_trace: Up and running.
[ 13.490000] [ 1.700000] [loadcontrol] set auto - scale=1
[ 13.490000] [ 1.700000] [avm] configured: watchdog event debug
[ 13.490000] [ 1.700000] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Nov 27 2017 18:29:53)
[ 13.490000] [ 1.710000] AVM Simple Profiling enabled Version 3.0
[ 13.490000] [ 1.710000] [simple-profiling]:2 performance counters implemented, NEW_34K
[ 13.490000] [ 1.710000] [simple-profiling]Enable Performance Counter 0 for Data cache load/stores (User Supervisor Kernel Exception TC-ID=0) all cores tc: 0
[ 13.490000] [ 1.730000] [simple-profiling]Enable Performance Counter 1 for Data cache load/store misses (User Supervisor Kernel Exception TC-ID=0) all cores tc: 0
[ 13.490000] [ 1.740000] [simple-profiling]Enable Performance Counter 0 for Data cache load/stores (User Supervisor Kernel Exception TC-ID=1) all cores tc: 1
[ 13.490000] [ 1.750000] [simple-profiling]Enable Performance Counter 1 for Data cache load/store misses (User Supervisor Kernel Exception TC-ID=1) all cores tc: 1
[ 13.490000] [ 1.770000] [simple-profiling]Enable Performance Counter 0 for Main pipeline stalls (P) (User Supervisor Kernel Exception TC-ID=2) all cores tc: 2
[ 13.490000] [ 1.780000] [simple-profiling]Enable Performance Counter 1 for Cycles (P) (User Supervisor Kernel Exception TC-ID=2) all cores tc: 2
[ 13.490000] [ 1.790000] [simple-profiling]Enable Performance Counter 0 for Data cache load/stores (User Supervisor Kernel Exception TC-ID=3) all cores tc: 3
[ 13.490000] [ 1.800000] [simple-profiling]Enable Performance Counter 1 for Data cache load/store misses (User Supervisor Kernel Exception TC-ID=3) all cores tc: 3
[ 13.490000] [ 1.820000] [simple-profiling]all cores:performance-mode (round-robin): cpus on
[ 13.490000] [ 1.820000] Lantiq Thermal Sensor driver, version 1.0.3, (c) 2001-2011 Lantiq Deutschland GmbH
[ 13.490000] [ 1.830000] ifx_pmu_init: Major 244
[ 13.490000] [ 1.840000] Lantiq PMU driver, version 1.2.6, (c) 2001-2011 Lantiq Deutschland GmbH
[ 13.490000] [ 1.840000] Lantiq GPIO driver, version 1.3.2, (c) 2001-2011 Lantiq Deutschland GmbH
[ 13.490000] [ 1.850000] Infineon Technologies RCU driver version 1.0.7
[ 13.490000] [ 1.870000] loop: module loaded
[ 13.490000] [ 1.870000] nbd: registered device at major 43
[ 13.490000] [ 1.900000] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[ 13.490000] [ 1.900000] [HSNAND] Hardware-ECC activated
[ 13.490000] [ 1.910000] ONFI param page 0 valid
[ 13.490000] [ 1.910000] ONFI flash detected
[ 13.490000] [ 1.910000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xdc (Micron MT29F4G08ABADAWP), 512MiB, page size: 2048, OOB size: 64
[ 13.490000] [ 1.930000] Scanning device for bad blocks
[ 13.490000] [ 2.340000] Creating 6 MTD partitions on "ifx_hsnand":
[ 13.490000] [ 2.340000] 0x000000000000-0x000000400000 : "kernel"
[ 13.490000] [ 2.350000] 0x000000400000-0x000003400000 : "filesystem"
[ 13.490000] [ 2.360000] 0x000003400000-0x000003800000 : "reserved-kernel"
[ 13.490000] [ 2.370000] 0x000003800000-0x000006800000 : "reserved-filesystem"
[ 13.490000] [ 2.370000] 0x000006800000-0x000006a00000 : "config"
[ 13.490000] [ 2.380000] 0x000006a00000-0x000020000000 : "nand-filesystem"
[ 13.490000] [ 2.390000] [TFFS3_Register_Panic_CB] registering panic callback for mtd ifx_hsnand
[ 13.490000] [ 2.400000] {ifx_sflash_setbaudrate} VR9 A21 high baudrate support
[ 13.490000] [ 2.400000] SPI Device: w25x10 0xEF (Winbond) 0x40 0x14
[ 13.490000] [ 2.400000] [TFFS3_Register_Panic_CB] registering panic callback for mtd ifx_sflash
[ 13.490000] [ 2.400000] Creating 3 MTD partitions on "ifx_sflash":
[ 13.490000] [ 2.410000] 0x000000000000-0x000000040000 : "urlader"
[ 13.490000] [ 2.420000] 0x000000040000-0x0000000a0000 : "tffs (1)"
[ 13.490000] [ 2.420000] 0x0000000a0000-0x000000100000 : "tffs (2)"
[ 13.490000] [ 2.430000] Lantiq SPI flash driver, version 2.0.2, (c) 2001-2011 Lantiq Deutschland GmbH
[ 13.490000] [ 2.440000] tun: Universal TUN/TAP device driver, 1.6
[ 13.490000] [ 2.440000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 13.490000] [ 2.450000] IFX SWITCH API, Version 1.1.8.5
[ 13.490000] [ 2.450000] SWAPI: Registered character device [switch_api] with major no [81]
[ 13.490000] [ 2.460000] Switch API: PCE MicroCode loaded !!
[ 13.490000] [ 2.460000] i2c /dev entries driver
[ 13.490000] [ 2.460000] cpuidle: using governor ladder
[ 13.490000] [ 2.460000] cpuidle: using governor menu
[ 13.490000] [ 2.470000] AVM PA for Linux 3.10.73
[ 13.490000] [ 2.470000] AVM PA skb pktinfo at offset 136 size 208
[ 13.490000] [ 2.480000] [loadcontrol]module avm_pa registered
[ 13.490000] [ 2.480000] u32 classifier
[ 13.490000] [ 2.480000] Performance counters on
[ 13.490000] [ 2.490000] Actions configured
[ 13.490000] [ 2.490000] ipip: IPv4 over IPv4 tunneling driver
[ 13.490000] [ 2.500000] TCP: cubic registered
[ 13.490000] [ 2.500000] NET: Registered protocol family 10
[ 13.490000] [ 2.500000] avm_pa: try to activate hw accelaration for pid 2 (ipv6)
[ 13.490000] [ 2.510000] sit: IPv6 over IPv4 tunneling driver
[ 13.490000] [ 2.520000] NET: Registered protocol family 17
[ 13.490000] [ 2.520000] Bridge broadcast ratelimiter registered
[ 13.490000] [ 2.520000] KOAM is loaded successfully.
[ 13.490000] [ 2.520000] l2tp_core: L2TP core driver, V2.0
[ 13.490000] [ 2.530000] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 13.490000] [ 2.530000] l2tp_netlink: L2TP netlink interface
[ 13.490000] [ 2.540000] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 13.490000] [ 2.540000] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[ 13.490000] [ 2.550000] 8021q: 802.1Q VLAN Support v1.8
[ 13.490000] [ 2.560000] Key type dns_resolver registered
[ 13.490000] [ 2.560000] <ifx_fix_timing>
[ 13.490000] [ 2.570000] [TFFS3_Init] No storage module registered, trying legacy fallback
[ 13.490000] [ 2.570000] [TFFS3_Register_LGCY] Called
[ 13.490000] [ 2.580000] [TFFS3_LGCY_Configure] Called
[ 13.490000] [ 2.580000] [TFFS3_LGCY_Setup] using mtd7(tffs (1)), mtd8(tffs (2))
[ 13.490000] [ 2.590000] [TFFS3_LGCY_Setup] mtd "tffs (1)": segment value 954
[ 13.490000] [ 2.590000] [TFFS3_LGCY_Setup] mtd "tffs (2)": segment value 955
[ 13.490000] [ 2.600000] [TFFS3_LGCY_Setup] Using segment 955 (avail: 954 + 955)
[ 13.490000] [ 2.600000] [TFFS3_LGCY_Setup] mtd8 size=0x60000
[ 13.490000] [ 2.610000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0)
[ 13.490000] [ 2.610000] [rescan_segment] Called with mode=2
[ 13.490000] [ 2.610000] TFFS: Clearing index for update
[ 13.490000] [ 2.630000] Adam2 environment variables API installed.
[ 13.490000] [ 2.630000] {avmnet_cfg_netinit}
[ 13.490000] [ 2.630000] [avmnet] No config found for HWRev 185, HWSubRev 6, Profile-ID 0, trying base config for HWSubRev
[ 13.490000] [ 2.640000] [avmnet] No config found for HWRev 185, HWSubRev 6, trying base config for HWRev
[ 13.490000] [ 2.650000] [avmnet] [avmnet_swi_7port_init] Init on module swi_vr9 called.
[ 13.490000] [ 3.010000] Loading AVM Net Common Datapath Driver for 7Port Switch......
[ 13.490000] [ 3.010000] [ppe_eth_init] init_hw()
[ 13.490000] [ 3.010000] [init_hw] ppe_hw_init=0xff successful
[ 13.490000] [ 3.020000] [ppe_eth_init] ifx_proc_file_create()
[ 13.490000] [ 3.020000] [ppe_eth_init] dma_setup_init()
[ 13.490000] [ 3.030000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x48
[ 13.490000] [ 3.040000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x48
[ 13.490000] [ 3.810000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 4.830000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 5.610000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 6.630000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 7.410000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 8.440000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 9.210000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 10.240000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 10.680000] system-load 4 loadavg 0.46 0.10 0.3 - 32 tasks:87 % curr:swapper/0(23 %) max:migration/0(38 %, pid:7) pgstat: sum=59154 free=58005 slab=2210 alloc=512/s fault=0/s (sleep 0)
[ 13.490000] [ 11.030000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 11.480000] system-load 100% loadavg 0.46 0.10 0.3 - 32 tasks:6 % curr:swapper/0(0 %) max:migration/1(6 %, pid:12) pgstat: sum=59154 free=58005 slab=2210 alloc=0/s fault=0/s (sleep 0)
[ 13.490000] [ 12.070000] [avmnet] [setup_phy] PHY phy_ar803x_1 hanging, trying to reset it.
[ 13.490000] [ 12.850000] [avmnet] [setup_phy] Giving up on hanging PHY phy_ar803x_1
[ 13.490000] [ 12.860000] [avmnet] [avmnet_ar803x_setup] setup failed for module phy_ar803x_1
[ 13.490000] [ 12.860000] [avmnet] Module mac_7port_1: setup() failed on child phy_ar803x_1
[ 13.490000] [ 12.870000] [avmnet] Module swi_vr9: setup() failed on child mac_7port_1
[ 13.490000] [ 12.880000] [avmnet] [avmnet_cfg_netinit] network module setup returned with error
[ 13.490000] [ 12.880000] [kernel-breakpoint] pc=0x803e7d30(avmnet_cfg_netinit+0x2d0/0x420) addr=0x8fc3be3c task=swapper/0 pid=1 ra=0x803e7d30(avmnet_cfg_netinit+0x2d0/0x420)
[ 13.490000] [ 12.900000] Code(0x803e7d28): 0x0c013180 0x26455448 <0x000c000d> 0x080f9f4d 0x00000000
[ 13.490000] [ 12.910000] set_reboot_status: Soft-Reboot(KCRASH) - KCRASH(3) SUM(3)
[ 13.490000] [ 12.910000] BUG() at function 'avmnet_cfg_netinit' line: 946 file: drivers/net/ethernet/avm/avm_cpmac/common/avmnet_config.c
[ 13.490000] [ 12.920000] === MIPS MT State Dump ===
[ 13.490000] [ 12.920000] -- Global State --
[ 13.490000] [ 12.920000] MVPControl Read: 00000005
[ 13.490000] [ 12.920000] MVPConf0 : b8008403
[ 13.490000] [ 12.920000] -- per-VPE State --
[ 13.490000] [ 12.920000] VPE 0
[ 13.490000] [ 12.920000] VPEControl : 00008000
[ 13.490000] [ 12.920000] VPEConf0 : 800f0003
[ 13.490000] [ 12.920000] VPE0.Status : 1100ff01
[ 13.490000] [ 12.920000] VPE0.EPC : 802d94c0 arch_local_irq_restore+0x60/0x80
[ 13.490000] [ 12.920000] VPE0.Cause : 10800000
[ 13.490000] [ 12.920000] VPE0.Config7 : 80080400
[ 13.490000] [ 12.920000] VPE 1
[ 13.490000] [ 12.920000] VPEConf0 : 802f0003
[ 13.490000] [ 12.920000] VPE1.Status : 1100c601
[ 13.490000] [ 12.920000] VPE1.EPC : 8001f028 __pastwait+0x0/0x18
[ 13.490000] [ 12.920000] VPE1.Cause : 10800000
[ 13.490000] [ 12.920000] VPE1.Config7 : 80080400
[ 13.490000] [ 12.920000] -- per-TC State --
[ 13.490000] [ 12.920000] TC 0 (current TC with VPE EPC above)
[ 13.490000] [ 12.920000] TCStatus : 00000000
[ 13.490000] [ 12.920000] TCBind : 00000000
[ 13.490000] [ 12.920000] TCRestart: 80027ab0 mips_mt_regdump+0x130/0x4a0
[ 13.490000] [ 12.920000] TCHalt : 00000000
[ 13.490000] [ 12.920000] TCContext: 00000000
[ 13.490000] [ 12.920000] SP: 8fc3b820
[ 13.490000] [ 12.920000] GP: 8fc38000
[ 13.490000] [ 12.920000] RA: 800279b0 mips_mt_regdump+0x30/0x4a0
[ 13.490000] [ 12.920000] TC 1
[ 13.490000] [ 12.920000] TCStatus : 18902400
[ 13.490000] [ 12.920000] TCBind : 00200001
[ 13.490000] [ 12.920000] TCRestart: 8001f000 r4k_wait_irqoff+0x20/0x48
[ 13.490000] [ 12.920000] TCContext: 00140000
[ 13.490000] [ 12.920000] SP: 8fc83ec8
[ 13.490000] [ 12.920000] GP: 8fc80000
[ 13.490000] [ 12.920000] RA: 8001eff0 r4k_wait_irqoff+0x10/0x48
[ 13.490000] [ 12.920000] TC 2
[ 13.490000] [ 12.920000] TCStatus : 09102400
[ 13.490000] [ 12.920000] TCBind : 00400001
[ 13.490000] [ 12.920000] TCRestart: 80028fac yield_context_thread+0x1ac/0x360
[ 13.490000] [ 12.920000] SP: 8fcc7ed0
[ 13.490000] [ 12.920000] GP: 8fcc4000
[ 13.490000] [ 12.920000] RA: f6202911 0xf6202911
[ 13.490000] [ 12.920000] TC 3
[ 13.490000] [ 12.920000] TCBind : 00600000
[ 13.490000] [ 12.920000] SP: 8fcd7ed0
[ 13.490000] [ 12.920000] GP: 8fcd4000
[ 13.490000] [ 12.920000] RA: 4c318800 0x4c318800
[ 13.490000] [ 12.920000] ===========================
[ 13.490000] [ 13.130000] Kernel bug detected[#1]:
[ 13.490000] [ 13.140000] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.73 #1
[ 13.490000] [ 13.140000] task: 8fc37ad8 ti: 8fc38000 task.ti: 8fc38000
[ 13.490000] [ 13.150000] $ 0 : 00000000 18102000 00000046 00000000
[ 13.490000] [ 13.150000] $ 4 : 18102000 00000400 0000012d 0000012d
[ 13.490000] [ 13.160000] $ 8 : 00000003 00000000 00005920 00000000
[ 13.490000] [ 13.160000] $12 : 00000000 0000012d 00000000 00000000
[ 13.490000] [ 13.170000] $16 : 8075de1c 80920000 805c0000 00000006
[ 13.490000] [ 13.170000] $20 : 00000000 80920000 8089d8a4 8089d8e4
[ 13.490000] [ 13.180000] $24 : 00000001 00000000
[ 13.490000] [ 13.180000] $28 : 8fc38000 8fc3be38 00000051 803e7d30
[ 13.490000] [ 13.190000] Hi : 00002260
[ 13.490000] [ 13.190000] Lo : 00008980
[ 13.490000] [ 13.200000] ac1Hi: 00000000 ac1Lo: 00000000
[ 13.490000] [ 13.200000] ac2Hi: 00000000 ac2Lo: 00000000
[ 13.490000] [ 13.200000] ac3Hi: 00000000 ac3Lo: 00000000
[ 13.490000] [ 13.210000] dspcontrol: 00000000
[ 13.490000] [ 13.210000] Status: 1100ff03 KERNEL EXL IE
[ 13.490000] [ 13.220000] Cause : 10800024 exc_code:9
[ 13.490000] [ 13.220000] epc : 803e7d30 avmnet_cfg_netinit+0x2d0/0x420
[ 13.490000] [ 13.230000] ra : 803e7d30 avmnet_cfg_netinit+0x2d0/0x420
[ 13.490000] [ 13.230000] Not tainted
[ 13.490000] [ 13.230000] PrId : 00019556 (MIPS 34Kc)
[ 13.490000] [ 13.240000] Modules linked in:
[ 13.490000] [ 13.240000] Process swapper/0 (pid: 1, threadinfo=8fc38000, task=8fc37ad8, tls=00000000)
[ 13.490000] [ 13.250000] Stack : 807159e0 805c5448 0000012c 0000012c 00000000 806d8e78 00000000 808b0000
[ 13.490000] [ 13.250000] 00000000 803e7a60 00000008 807159e0 8086821c 8000eca8 81d350e2 00000007
[ 13.490000] [ 13.250000] 00000007 00000001 808a67e4 00000007 808b0000 00000008 808a683c 00000007
[ 13.490000] [ 13.250000] 808b0000 00000008 807159e0 80868afc cccccccc cccccccc 8fc37668 807338b0
[ 13.490000] [ 13.250000] 00000007 00000007 8086821c 800801fc 80007800 00000000 00000000 00000000
[ 13.490000] [ 13.250000] ...
[ 13.490000] [ 13.280000] Call Trace:
[ 13.490000] [ 13.290000] [<803e7d30>] avmnet_cfg_netinit+0x2d0/0x420
[ 13.490000] [ 13.290000] [<8000eca8>] do_one_initcall+0x108/0x220
[ 13.490000] [ 13.300000] [<80868afc>] kernel_init_freeable+0x16c/0x22c
[ 13.490000] [ 13.300000] [<80007818>] kernel_init+0x18/0x180
[ 13.490000] [ 13.310000] [<800024e8>] ret_from_kernel_thread+0x14/0x1c
[ 13.490000] [ 13.310000] Code: 24848dfc 0c013180 26455448 <000c000d> 080f9f4d 00000000 24848da0 0c013180 26455448
[ 13.490000] [ 13.320000] CPU_ID=0 TC0 ----- (LINUX)
[ 13.490000] [ 13.330000] Status: 1100ff01 KERNEL IE
[ 13.490000] [ 13.330000] current: swapper/0 (pid: 1, threadinfo=8fc38000, task=8fc37ad8, sp=8fc3ba38 tls=0x00000000)
[ 13.490000] [ 13.340000] Call Trace:
[ 13.490000] [ 13.340000] [<802d8060>] arch_trigger_all_cpu_backtrace+0x120/0x740
[ 13.490000] [ 13.350000] [<8036492c>] die_notifier+0xac/0x100
[ 13.490000] [ 13.350000] [<8007af1c>] notifier_call_chain+0x5c/0xe0
[ 13.490000] [ 13.360000] [<8007bac4>] notify_die+0x44/0x60
[ 13.490000] [ 13.360000] [<800230cc>] die+0x4c/0x140
[ 13.490000] [ 13.370000] [<80023424>] do_trap_or_bp+0x204/0x220
[ 13.490000] [ 13.370000] [<80002480>] ret_from_exception+0x0/0x18
[ 13.490000] [ 13.380000] [<803e7d30>] avmnet_cfg_netinit+0x2d0/0x420
[ 13.490000] [ 13.380000] [<8000eca8>] do_one_initcall+0x108/0x220
[ 13.490000] [ 13.390000] [<80868afc>] kernel_init_freeable+0x16c/0x22c
[ 13.490000] [ 13.390000] [<80007818>] kernel_init+0x18/0x180
[ 13.490000] [ 13.400000] [<800024e8>] ret_from_kernel_thread+0x14/0x1c
[ 13.490000] [ 13.400000] CPU_ID=1 TC1 ----- (LINUX)
[ 13.490000] [ 13.410000] Status: 1100c601 KERNEL IE
[ 13.490000] [ 13.410000] current: swapper/1 (pid: 0, threadinfo=8fc80000, task=8fc5ada8, sp=8fc83ec8 tls=0x00000000)
[ 13.490000] [ 13.420000] Call Trace:
[ 13.490000] [ 13.420000] [<8001f000>] r4k_wait_irqoff+0x20/0x48
[ 13.490000] [ 13.430000] [<80090260>] cpu_startup_entry+0x180/0x1e0
[ 13.490000] [ 13.430000] [<8088eb7c>] smp_bootstrap+0xc/0x60
[ 13.490000] [ 13.440000]
[ 13.490000] [ 13.440000] YIELD-TC2 -----
[ 13.490000] [ 13.440000] current: CPU1-YIELD-TC2 (pid: 0, threadinfo=8fcc4000, task=8fcc0018, sp=8fcc7ed0 tls=0x00000000)
[ 13.490000] [ 13.450000] Call Trace:
[ 13.490000] [ 13.450000] [<80028fac>] yield_context_thread+0x1ac/0x360
[ 13.490000] [ 13.460000]
[ 13.490000] [ 13.460000] YIELD-TC3 -----
[ 13.490000] [ 13.460000] current: CPU0-YIELD-TC3 (pid: 0, threadinfo=8fcd4000, task=8fcd0018, sp=8fcd7ed0 tls=0x00000000)
[ 13.490000] [ 13.470000] Call Trace:
[ 13.490000] [ 13.480000] [<80028fac>] yield_context_thread+0x1ac/0x360
[ 13.490000] [ 13.480000] ---[ end trace 2c6f69369de21979 ]---
[ 16.100000] Kernel panic - not syncing: Fatal exception
[ 16.100000] Rebooting in 5 seconds..
ROM VER: 1.1.4
Use Code-Tags for the Log! Please edit the post.
A Ethernet-PHY seems to be defective.
Reaktionen: Gtheod
klaboom
