backup via wireless on hd usb
matteoraggi
8 Jun 2008
via browser I see folders on hd usb mounted, but I can't enter in them and I don't see files, via ftp I see only mounted folder and nothing in it and out of it, what I must to do normally read nand write files via FTP to do backup via wireless on my hd usb?
Without more on information noone can helf your.
Your should tell us which box you have, which firmware you use, and which mondifications you use in your freetz. And - of course - your freetz-revision (easy going if you attach your .config)
Surly you yave a syslog on your box and could paste us the content?
When answering to posts, there is an option 'Anhänge verwalten' which allows you to attach files to the post (see attached image).
09.06.08 11:45:35 The file sytem contained on the USB mass storage device 15 is not supported or the device has an invalid partition table. (device type: 04b8:082c)
09.06.08 11:45:34 Partition mounted in uStor00
09.06.08 11:44:59 Printer sharing at Port 9100 enabled.
09.06.08 11:44:56 USB device 015, class 'printer', plugged in
09.06.08 11:44:56 USB device 015, class 'storage', plugged in
09.06.08 00:35:22 uStor01 has been successfully removed
09.06.08 00:35:21 USB device 014 unplugged
08.06.08 16:52:23 Partition mounted in uStor01
08.06.08 16:52:15 USB device 014, class 'storage', plugged in
05.06.08 20:55:55 Printer sharing stopped.
05.06.08 20:55:53 USB device 013 unplugged
05.06.08 20:55:52 USB device 013 unplugged
05.06.08 19:57:35 The file sytem contained on the USB mass storage device 13 is not supported or the device has an invalid partition table. (device type: 04b8:082c)
05.06.08 19:57:34 Partition mounted in uStor00
05.06.08 19:56:59 Printer sharing at Port 9100 enabled.
05.06.08 19:56:56 USB device 013, class 'printer', plugged in
05.06.08 19:56:56 USB device 013, class 'storage', plugged in
05.06.08 12:19:07 Printer sharing stopped.
05.06.08 12:19:06 Printer sharing stopped.
05.06.08 12:18:35 USB device 012 unplugged
05.06.08 12:18:34 USB device 012 unplugged
05.06.08 11:17:20 The file sytem contained on the USB mass storage device 12 is not supported or the device has an invalid partition table. (device type: 04b8:082c)
05.06.08 11:17:19 Partition mounted in uStor00
05.06.08 11:16:43 Printer sharing at Port 9100 enabled.
05.06.08 11:16:40 USB device 012, class 'storage', plugged in
05.06.08 11:16:40 USB device 012, class 'printer', plugged in
05.06.08 01:27:31 Printer sharing stopped.
05.06.08 01:26:59 USB device 011 unplugged
05.06.08 01:26:58 USB device 011 unplugged
04.06.08 11:38:01 The file sytem contained on the USB mass storage device 11 is not supported or the device has an invalid partition table. (device type: 04b8:082c)
04.06.08 11:38:00 Partition mounted in uStor00
04.06.08 11:37:55 Printer sharing at Port 9100 enabled.
04.06.08 11:37:51 USB device 011, class 'printer', plugged in
04.06.08 11:37:51 USB device 011, class 'storage', plugged in
04.06.08 00:51:42 uStor01 has been successfully removed
04.06.08 00:51:39 USB device 010 unplugged
03.06.08 20:10:46 Partition mounted in uStor01
03.06.08 20:10:38 USB device 010, class 'storage', plugged in
03.06.08 19:10:52 Printer sharing stopped.
03.06.08 19:10:20 USB device 009 unplugged
03.06.08 19:05:55 The file sytem contained on the USB mass storage device 9 is not supported or the device has an invalid partition table. (device type: 04b8:082c)
03.06.08 19:05:54 Partition mounted in uStor00
03.06.08 19:05:19 Printer sharing at Port 9100 enabled.
03.06.08 19:05:16 USB device 009, class 'storage', plugged in
03.06.08 19:05:16 USB device 009, class 'printer', plugged in
Posting 2:
files in attachment
[Edit Novize: attachment deleted]
Hi.
Perhaps you should delete above attachment. There's many private data in it!
Greets Oliver
You will find your .config-file in your freetz-directory.
figo12
