beronet BN4S0 und bristuff
maurice383
4 Feb 2006
so jetzt haette ich gerne auch mal ein problem !
bn4s0 will nicht mit mir spielen, alles sieht recht nett aus jedoch:
root@buechse:~# asterisk –r
    -- Executing Dial("SIP/14-081a8068", "ZAP/g1/XXXXXXX||tTo") in new stack
Jun  1 15:47:40 NOTICE[2317]: app_dial.c:1096 dial_exec_full: Unable to create channel of type 'ZAP' (cause 34 - Circuit/channel congestion)
  == Everyone is busy/congested at this time (1:0/1/0)
    -- Executing Hangup("SIP/14-081a8068", "") in new stack
Debian 4.0 - Kernel 2.6.18-6-686 - bristuff-0.3.0-PRE-1y-h - qozap_beronet_BRIstuff-0.3.0PRE-1y-h.patch
karte wird am mehrgeraete-anschluss betrieben, led's bleiben dunkel wie die nacht.
anbei mal alles an config-info was interessant sein koennte:
root@buechse:~# lspci -vvv
00:13.0 ISDN controller: Cologne Chip Designs GmbH ISDN network Controller [HFC-4S] (rev 01)
        Subsystem: Cologne Chip Designs GmbH Unknown device b560
        Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
        Interrupt: pin A routed to IRQ 10
        Region 0: I/O ports at 2320 [size=8]
        Region 1: Memory at 2a100000 (32-bit, non-prefetchable) [size=4K]
        Capabilities: [40] Power Management version 2
                Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
                Status: D0 PME-Enable- DSel=0 DScale=0 PME-
root@buechse:~# cat /proc/zaptel/*
Span 1: ztqoz/1/1 "quadBRI PCI ISDN Card 1 Span 1 [TE] (cardID 0)" AMI/CCS
           1 ztqoz1/1/1 Clear (In use)
           2 ztqoz1/1/2 Clear (In use)
           3 ztqoz1/1/3 HDLCFCS (In use)
Span 2: ztqoz/1/2 "quadBRI PCI ISDN Card 1 Span 2 [TE] (cardID 0)" AMI/CCS
           4 ztqoz1/2/1 Clear (In use)
           5 ztqoz1/2/2 Clear (In use)
           6 ztqoz1/2/3 HDLCFCS (In use)
Span 3: ztqoz/1/3 "quadBRI PCI ISDN Card 1 Span 3 [TE] (cardID 0)" AMI/CCS
           7 ztqoz1/3/1 Clear (In use)
           8 ztqoz1/3/2 Clear (In use)
           9 ztqoz1/3/3 HDLCFCS (In use)
Span 4: ztqoz/1/4 "quadBRI PCI ISDN Card 1 Span 4 [TE] (cardID 0)" AMI/CCS
          10 ztqoz1/4/1 Clear (In use)
          11 ztqoz1/4/2 Clear (In use)
          12 ztqoz1/4/3 HDLCFCS (In use)
Span 5: ZTDUMMY/1 "ZTDUMMY/1 1"
root@buechse:~# cat /etc/modules
loop
qozap ports=0
ztdummy
root@buechse:~$ cat /etc/modules.conf
qozap
root@ buechse:~$ cat /etc/modprobe.conf
alias net-pf-10 off
alias ipv6 off
install qozap /sbin/modprobe --first-time --ignore-install qozap; ztcfg
root@buechse:~$ cat /etc/zaptel.conf
loadzone=nl
defaultzone=nl
span=1,1,3,ccs,ami
bchan=1,2
dchan=3
span=2,2,3,ccs,ami
bchan=4,5
dchan=6
span=3,3,3,ccs,ami
bchan=7,8
dchan=9
span=4,4,3,ccs,ami
bchan=10,11
dchan=12
root@buechse:~$ cat /etc/asterisk/zapata.conf
[channels]
language=de
switchtype = euroisdn
signalling = bri_cpe_ptmp
pridialplan = dynamic
prilocaldialplan = local
nationalprefix = 0
internationalprefix = 00
faxdetect=both
echocancel=yes
echotraining = 100
echocancelwhenbridged=yes
overlapdial=yes
immediate=no
priindication = passthrough
context=incoming
group = 1
channel => 1,2,4,5,7,8,10,11
root@buechse:~$ dmesg
Zapata Telephony Interface Registered on major 196
Zaptel Version: 1.2.18
Zaptel Echo Canceller: MG2
qozap: no version for "zt_receive" found: kernel tainted.
ACPI: Unable to derive IRQ for device 0000:00:13.0
ACPI: PCI Interrupt 0000:00:13.0[A]: no GSI - using IRQ 10
qozap: BeroNet BN4S0 card configured at io port 0x2320 IRQ 10 HZ 250 CardID 0
qozap: S/T ports: 4 [ TE TE TE TE ]
qozap: 1 multiBRI card(s) in this box, 4 BRI ports total, bloop 0, pcmslave 0, dacs 1.
Registered tone zone 3 (Netherlands)
Zaptel Transcoder support loaded
das muss ich doch weinen, was in meinem alter garnicht huebsch aussieht. :confused:
nur nicht aus liebe weinen
also, dann beantworte ich meine anfrage mal flugs selber:
konfiguration ist von vorne bis hinten ok - es ist ein hardware problem.
eingesetzt wurde ein mini-itx pc mit einer riser card ( setzt 1 pci-slot senkrecht auf zwei pci-slots waagerecht um).
solbald die beronet im anderen slot war funktionierte alles einwandfrei.
laut haendler ein (wenn auch bekanntes ) mysterium, da die riser-card eigentlich nur durchschleift.
seufz.
warum habe ich eigentlich keinen blumenladen aufgemacht ?? :cool:
Trotzdem noch eine Frage von mir: Wozu brauchst Du noch ztdummy wenn Du eine Karte hast?
:confused:
lasse mich gerne eine besseren belehren:
ztdummy als timing device (z.b.meetme ) falls keine digium karten eingesetzt werden -
sagt jedenfalls "http://www.voip-info.org/wiki-Asterisk+timer+ztdummy".
Es sollte eigentlich heißen "falls keine Zaptel Karte(n) eingesetzt werden". Das kann eine Digium Karte sein, muss aber nicht. Wenn Du die BN4S0 mit Bristuff nutzt wird sie ja über Zaptel angesteuert.
goody
ich gehör zur generation 'read the fucking manual' ( and believe everey fucking word in it ). werd den ztdummy mal abschalten und schauen ob es eine auswirkung auf die conferences hat.
danke fuer deinen hinweis !!
figo12
