Bibliothek für Fritz!Box kompilieren
OK, wie muss ich das ganze strippen?
Ansonsten scheint es inzwischen zu laufen. Ich brauche nur noch das Gerätchen, um es auch praktisch zu testen.
[mickey@blob ds-0.2.9]$ toolchain/target/bin/mipsel-linux-strip
Usage: toolchain/target/bin/mipsel-linux-strip <option(s)> in-file(s)
Removes symbols and sections from files
The options are:
-I --input-target=<bfdname> Assume input file is in format <bfdname>
-O --output-target=<bfdname> Create an output file in format <bfdname>
-F --target=<bfdname> Set both input and output format to <bfdname>
-p --preserve-dates Copy modified/access timestamps to the output
-R --remove-section=<name> Remove section <name> from the output
-s --strip-all Remove all symbol and relocation information
-g -S -d --strip-debug Remove all debugging symbols & sections
--strip-unneeded Remove all symbols not needed by relocations
--only-keep-debug Strip everything but the debug information
-N --strip-symbol=<name> Do not copy symbol <name>
-K --keep-symbol=<name> Do not strip symbol <name>
--keep-file-symbols Do not strip file symbol(s)
-w --wildcard Permit wildcard in symbol comparison
-x --discard-all Remove all non-global symbols
-X --discard-locals Remove any compiler-generated symbols
-v --verbose List all object files modified
-V --version Display this program's version number
-h --help Display this output
--info List object formats & architectures supported
-o <file> Place stripped output into <file>
toolchain/target/bin/mipsel-linux-strip: supported targets: elf32-tradlittlemips elf32-tradbigmips ecoff-littlemips ecoff-bigmips elf32-ntradlittlemips elf64-tradlittlemips elf32-ntradbigmips elf64-tradbigmips elf64-little elf64-big elf32-little elf32-big srec symbolsrec tekhex binary ihex
d.h.
mipsel-linux-strip libyasdi_drv_serial.so
OK, werde das dann mal machen, wenn ich an meiner Toolchain-Kiste sitze.
Heiko2026
