[Gelöst] Bind - Alte Freetz Version akzeptiert config, neue nicht.
JokerGermany
7 Aug 2007
Fritz!OS: 7.12
Freetz: master-20190813-77e64b8c6
Bind config:
options {
        allow-notify { 192.168.2.2; 192.168.2.5;192.168.2.6; };
    directory "/var/media/ftp/FRITZ/bind";
        forwarders { 192.168.180.1; 192.168.180.2; };
    listen-on port 53 { 127.0.0.1; 192.168.2.1; 192.168.200.1; 192.168.179.1; };
        listen-on-v6 port 53 { any; };
    allow-query { internal-net;};
    notify yes;
        response-policy { zone "rpz"; };
acl internal-net {
#fd00::3631:c4ff:fe62:af8/64;
#XXXX:XX:XXXX:XXXX::/56;
192.168.188.0/24;
127.0.0.1/8;
192.168.2.0/24;
192.168.179.0/24;
192.168.200.0/24;
zone "geheim.lan" in {
      type slave;
        masters { 192.168.2.2; };
      file "geheim.lan";
zone "2.168.192.in-addr.arpa" in {
    type slave;
    file "geheim.lan.rev";
zone "rpz" {
  type master;
  file "db.rpz";
#options {
    #directory "/var/media/ftp/uStor01/bind";
    #forwarders { 192.168.180.1; 192.168.180.2; };
    #forward first;
    #listen-on port 53 { 127.0.0.1; 192.168.2.1; };
    #allow-query { 127.0.0.1/8; 192.168.2.0/24; };
    #notify no;
#zone "." in {
#    type hint;
#    file "root.hint";
#zone "127.in-addr.arpa" in {
#    type master;
#    file "ptr/127";
#zone "2.168.192.in-addr.arpa" in {ARM
#    type master;
#    file "ptr/192.168.178";
#zone "geheim.lan" in {
#    type master;
#    file "zone/box";
Heute neue Freetz Version erstellt:
Fritz!OS: 7.12
Freetz: 7590_07.12-freetz-master-20200702-a9dc8e293.de_20200707-234643
Und die startet bind nicht.
Will man es starten spuckt syslogd folgendes aus:
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: starting BIND 9.11.13 (Extended Support Version) <id:ad4df16>
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: running on Linux mips 3.10.104 #1 SMP Wed Jul 3 12:19:08 CEST 2019
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: [truncated] built with '--cache-file=/dev/null' '--target=mips-linux' '--host=mips-linux' '--build=x86_64-pc-linux-gnu' '--program-prefix=' '--program-suffix=' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--d
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: running as: named
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: compiled by GCC 5.5.0
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: threads support is disabled
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: ----------------------------------------------------
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: BIND 9 is maintained by Internet Systems Consortium,
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: Inc. (ISC), a non-profit 501(c)(3) public-benefit
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: corporation.  Support and training for BIND 9 are
Jul  8 00:02:05 7590-Ort daemon.notice named[11089]: available at https://www.isc.org/support
Jul  8 00:02:05 7590-Ort daemon.info named[11089]: using up to 1024 sockets
Jul  8 00:02:05 7590-Ort daemon.info named[11089]: loading configuration from '/etc/named.conf'
Jul  8 00:02:05 7590-Ort daemon.err named[11089]: /etc/named.conf:16: '127.0.0.1/8': address/prefix length mismatch '8'
Jul  8 00:02:05 7590-Ort daemon.crit named[11089]: loading configuration: failure
Jul  8 00:02:05 7590-Ort daemon.crit named[11089]: exiting (due to fatal error)
Hmm, was ist das Problem?
Bin ein Bind und Freetz Noob.
Falls ihr mehr Infos braucht sagt Bescheid.
Vielen Dank für die Hilfe.
Versuch's mal mit "127.0.0.0/8" ... wenn da die Adresse steht, ist der Teil außerhalb der Maske nicht 0.
EDIT: Der ACL-Eintrag beschränkt die IP-Adressen, die zugreifen dürfen ... wenn man für "localhost" ausschließlich die 127.0.0.1 verwendet, kann man auch /32 als Maske nehmen. Mancher nutzt aber auch noch andere Adressen im "localnet", z.B. 127.0.0.2 o.ä.
Reaktionen: JokerGermany
Danke, das wars.
Die alte Version war scheinbar etwas kulanter.
holh-66
