Boblight for Fritzbox?
wow, that was fast :) i simply have to add it with patch -p0?
thx for your work.
ok, that worked, thanks. is it now integrated in the firmware image?
will it autostart when i restart the router?
make boblight-precompiled
Does only compile the binary, you will first have to execute
make menuconfig
, select the Package in the Package list and finally execute
make
to create an new image that you can flash to your fritzbox. And it seems that in sf's package isnt an webinterface or init script, that means that you will have configure it by yourself and than execute it from the console.
Finally no, it will not start automatically, you will have to do it by the console every time the box reboots or you can create an little script (add it to your rc.custom) that will start boblight for you
I cannot find the package, went through all categories, but no success.
or does it have a cryptic name?
No, you have to add the Package to the menu file.
Can't remember the name right now (Config.in or Makefile.in, i think), but it's a very easy task.
it shows nothing.
btw, what´s the best way to transfer files to the fritzbox? or will i have to use vi?
thanks for all your help
Add this line
 source make/boblight/Config.in
in the section "Testing" of file "make/Config.in" and this line
 source make/boblight/external.in
in the section "packages" of file "make/external.in"
ok, after building the binaries are in build/modified/filesystem/usr/bin, so that seems to be ok.
how can i copy the boblight.conf now to the /etc directory and place a script in init.d ?
can i edit the filesystem before compiling? using telnet?
EDIT: is the "addon" directory what i want?
ok i put the boblight.conf under /packages/.../boblight-r417/root/etc/
how do i put the init.d script there? also by creating a file in packages/.../boblight-r417/root/etc/init.d?
i´d have to make it executable then, right?
a simple
/usr/bin/boblightd -f &
is enough as startup script?
seems as I´m doing something wrong... the compiled image has exactly the same size than the one before..
do i have to edit /make/boblight/external.files ?
EDIT: tried to start boblightd via telnet, the config file is there after i inserted it before compiling.
but i get an error:
root@fritz:/var/mod/root/etc# boblightd -c /etc/boblight.conf
(InitLog)                       start of log /mod/root/.boblight/boblightd.log
(PrintFlags)                    starting boblightd -c /etc/boblight.conf
(CConfig::LoadConfigFromFile)   opening /etc/boblight.conf
(CConfig::CheckConfig)          checking config lines
(CConfig::CheckDeviceConfig)    ERROR: /etc/boblight.conf no devices defined
(CConfig::CheckColorConfig)     ERROR: /etc/boblight.conf no colors defined
(CConfig::CheckLightConfig)     ERROR: /etc/boblight.conf no lights defined
the .conf file is correct, i can see that with vi.
btw will i have to use ttyACM0 oder ttyS0 to access the usb port?
I´m confused now... what´s the right place for boblight.conf?
/etc?
/mod/root/etc?
/var/mod/root/etc/?
/var/mod/etc?
The right place is:
 /var/tmp/boblight
i even get those errors when running boblightd with the sample config.
root@fritz:/var/tmp/boblight# boblightd -f -c /var/tmp/boblight/sample_boblight.conf
(PrintFlags)                    starting boblightd -f -c /var/tmp/boblight/sample_boblight.conf
(CConfig::LoadConfigFromFile)   opening /var/tmp/boblight/sample_boblight.conf
(CConfig::CheckDeviceConfig)    ERROR: /var/tmp/boblight/sample_boblight.conf no devices defined
(CConfig::CheckColorConfig)     ERROR: /var/tmp/boblight/sample_boblight.conf no colors defined
(CConfig::CheckLightConfig)     ERROR: /var/tmp/boblight/sample_boblight.conf no lights defined
fusionK
