[Problem] Build Freetz-trunk 8255 and size image
ayakunin
12 Nov 2011
STEP 3: PACK
  checking for left over Subversion directories
  integrate freetz info file into image
packing var.tar
creating filesystem image
  squashfs blocksize: 65536
merging kernel image
  kernel image size:[B] 15326720[/B] (max: 15597568, free: 270848)
  Aproximately free time for the answering machine: 18s (0min 18s)
packing 7390_05.05freetz-devel-8255.en_20111217-165513.image
Image files can be found in the ./images/ subfolder
done.
alex@tux:~/src/avm/freetz-trunk> ls -l ./images/
итого 29336
-rw-r--r-- 1 alex users [B][COLOR="red"]30039040[/COLOR][/B] дек.  17 16:55 7390_05.05freetz-devel-8255.en_20111217-165513.image
As you can see the real size of the image and should not be the same, this is a bug?
Thanks for the link and your work, I updated the trunk to version 8260 and have a question about the size of the image:
STEP 3: PACK
packing var.tar
  kernel image size: [B]15326720[/B] (max: 15597568, free: 270848)
packing 7390_05.05freetz-devel-8260.en_20111218-062504.image
done.
-rw-r--r-- 1 alex users [B]15997952[/B] дек.  18 06:25 7390_05.05freetz-devel-8260.en_20111218-062504.image
Now that right? The dimensions do not match.
Thank you.
I unpacked the image and saw the size of three directories filesystem, firmware and kernel. Compared with the size of ./build/modified, and they are the same. Or was meant for something else?
I'm not quite sure what to watch. If you tell, then I will definitely take a look.
Try
tar tvf images/7390_05.05freetz-devel-8260.en_20111218-062504.image
There should be a line
-rw-r--r-- 0/0  [B]15326720[/B] 2011-00-00 00:00:00 ./var/tmp/kernel.image
I am updated trunk from svn and build new image:
STEP 3: PACK
packing var.tar
  kernel image size: [B]15056384[/B] (max: 15597568, free: 541184)
  Aproximately free time for the answering machine: 152s (2min 32s)
packing 7390_05.05freetz-devel-8269.en_20111220-171223.image
done.
alex@tux:~/src/avm/freetz-trunk> tar tvf ./images/7390_05.05freetz-devel-8269.en_20111220-171223.image
drwxr-xr-x root/root         0 2011-12-20 17:11 ./
drwxrwxr-x root/root         0 2011-12-20 17:12 ./var/
-rwxrwx--- root/root    259708 2011-06-14 17:53 ./var/chksum
-rw-rw---- root/root     39124 2011-05-04 15:07 ./var/flash_update_2.6.19.2.ko
-rw-rw-r-- root/root       128 2011-09-19 18:21 ./var/signature
-rw-r--r-- root/root       348 2011-12-20 17:12 ./var/.packages
-rwxrwxr-x root/root     23342 2011-12-20 17:12 ./var/install
-rw-r--r-- root/root     27003 2011-12-20 17:12 ./var/.config
drwxrwxr-x root/root         0 2011-12-20 17:12 ./var/tmp/
-rw-rw---- root/root         0 2011-09-19 18:21 ./var/tmp/filesystem.image
-rw-r--r-- root/root  [B]15056392[/B] 2011-12-20 17:12 ./var/tmp/kernel.image
-rw-r--r-- root/root       226 2011-12-20 17:12 ./var/static.pkg
-rw-rw-r-- root/root     41396 2011-09-08 17:33 ./var/flash_update_2.6.28.ko
-rwxrwxr-x root/root      2795 2011-09-19 18:21 ./var/info.txt
-rwxrwx--- root/root    265248 2011-06-14 17:53 ./var/regelex
Thanks for the tips, now became more versed in freetz and hopefully at least somewhat helpful :)
nightdeck
