busybox 1.10.1
johnbock
2 Mrz 2008
It's been working for me and haven't noticed anything bad...
I've enable the volume_id routines;)
[edit]
forgot the 210 telnet close patch patch, hehe
I do not think that we should use the unstalbe busybox-releases right now. The 1.9.2 doesn't make any problems with my setup, and for anyone other....
Furthermore there is much in progress on busybox-ML so I do not think it is a good idea for that.
busybox-1.10.1 ist als stable deklariert. johnbock kann es ja mal testen und dann berichten.
MfG Oliver
At 12:00 it will be 24h, and I haven't noticed any problems...
your patchfiles aren't complete. You should use something similar to svn diff, cause at my server I had to activate some busybox-options by my own.
Did I remove too much? Here's my complete svn diff:
I think this patch changes too much not used for "our" busybox. There are changes to kernel-config, there are options set which are extra options in Freetz and so on. I do not apply this patch directly to freetz with all these changes.
greetz
greetz
O.K. should I rework the patch against the current trunk?
Please revert all your personal changes. do a fresh checkout of the busybox-config an then redo the make-precoess.
Busybox asks not set config-options. Then I'll check this in.
I attached a patch which shouzld work. But I'm not sure. I'm in office right now and there's no Testbox reachable.
Now I have got it... I had forgotten the busybox config in tools:confused:
figo12
