Callmonitor und Dreambox
Mahon
6 Nov 2006
hi zusammen,
brauch mal kurz Hilfe, hab ich da was nicht richtig Kompiliert?
in meinen Listeners steht:
in:request ^ ^ dreammessage --port=9112 --user='root' --password='dreambox' 192.168.0.27
Bei einem Testanruf kommt dann:
including /usr/lib/callmonitor/actions.d/dboxlcd.sh
including /usr/lib/callmonitor/actions.d/dial.sh
including /usr/lib/callmonitor/actions.d/dropbear.sh
including /usr/lib/callmonitor/actions.d/mail.sh
including /usr/lib/callmonitor/actions.d/messages.sh
>>> in:request ID=1 TIMESTAMP=13.11.06 20:15 SOURCE=0943161969 DEST=0943156246 EXT=4 DURATION=16 PROVIDER=
/usr/sbin/callmonitor-test: /mod/pkg/callmonitor/usr/lib/callmonitor/applets/callmonitor-test.sh: 7: cannot open /tmp/flash/callmonitor/callers: No such file
[0] EVENT=in:request SOURCE='0943161969' DEST='0943156246' SOURCE_NAME='' DEST_NAME='' ID=1 EXT=4 DURATION=16 TIMESTAMP='13.11.06 20:15' PROVIDER=
[0:0] processing rule 'in:request' '^' '^' 'dreammessage --port=9112 --user='root' --password='dreambox' 192.168.0.27'
[0:0] event 'in:request' matches pattern 'in:request'
[0:0] parameter SOURCE='0943161969' matches pattern '^'
[0:0] parameter DEST='0943156246' matches pattern '^'
[0:0] SUCCEEDED
[0:0] ACTION: 'dreammessage --port=9112 --user='root' --password='dreambox' 192.168.0.27'
nc: connect: Connection refused
[0:0] listener failed with an exit status of 1
*edit*
Schon OK hab alles unter Kontrolle, Danke trotzdem.
Hi
was war den nun die Lösung, habe das gleiche Problem.
bye
Eggy
Leider nur ein Tippfehler soweit ich mich erinnern kann....
horafo4576
