Hi All,
I recently installed my new 7270. The first thing I did was to put Freetz on to it. All of this went fine. The problem now is that I can't locate the option to assign a different subnet to WLAN. According to the manual it should be under IP settings but I can't find it. Is it me or is the option gone after putting Freetz on the box.
Thx.
Thx.
