cfg_asterisk1x usb_install auf 7170 (ohne Labor-FW) funktioniert nicht
myrken
17 Jan 2007
ich habe die FB 7170 mit der Firmware 29.04.59.
Nun wollte ich asterisk installieren, auf einen USB-Stick, jedoch funktioniert die Installation nicht.
Hier erst mal das, was die Installation ausspuckt, nachdem ich alles so machte, wie in dynamics Anleitung:
# ./cfg_asterisk16 usb_install
              total         used         free       shared      buffers
  Mem:        30276        25716         4560            0         1840
 Swap:            0            0            0
Total:        30276        25716         4560
INFORMATION: Installing asterisk16 (http://www.spblinux.de/fbox.new/26) to /var/media/ftp/DataTraveler2-0-Partition-0-1/addons ...
asterisk16.sqf -> /var/ram0:
Connecting to www.spblinux.de[62.2.86.226]:80
ram0                 100% |******************************************************************************************|  1692 KB    00:00 ETA
INFORMATION: Installing asterisk16 on usb device (DataTraveler2-0-Partition-0-1)
[b]./cfg_asterisk16: eval: 1: /var/asterisk16/bin/cp: not found
Start extracting files ... please wait!
./cfg_asterisk16: eval: 1: /var/asterisk16/bin/cp: not found[/b]
COMPLETED:   asterisk16 has been successfully installed to usb device DataTraveler2-0-Partition-0-1
Performing root install ... This may take a couple minutes.
Aborting during this period will render your system inoperable!!!
INFORMATION: asterisk16 start disabled during ROOT overlaying phase ...
Installation progress: ls: /var/media/ftp/DataTraveler2-0-Partition-0-1/addons/asterisk16/bin: No such file or directory
[b].ls: /var/media/ftp/DataTraveler2-0-Partition-0-1/addons/asterisk16/etc: No such file or directory
.ls: /var/media/ftp/DataTraveler2-0-Partition-0-1/addons/asterisk16/usr: No such file or directory[/b]
INFORMATION: ROOT overlaying phase finished. asterisk16 starting enabled!
  Mem:        30276        25892         4384            0         1840
 Swap:            0            0            0
Total:        30276        25892         4384
to use asterisk16 type ./cfg_asterisk16 start
(or /var/media/ftp/DataTraveler2-0-Partition-0-1/addons/cfg_asterisk16 start)
After a reboot you may reinstall asterisk16 from usb with
/var/media/ftp/DataTraveler2-0-Partition-0-1/addons/cfg_asterisk16 usb_install
Danach funktioniert natürlich "cfg_asterisk16 start" nicht.
Kann es sein, dass das cfg_asterisk16-Paket, was momentan in /fbox.new/ liegt, einen Fehler hat?
Wenn ich das Ganze mit cfg_asterisk14 probiere, passiert das selbe.
... dann halt vorläufig mit der Version auf spblinux.de/fbox/ probieren.
(Es gab/gibt firmware version wo cp rekursiv mit symlinks nicht richtig funktioniert hat).
spblinux
Welche Datei und von wo genau hast Du die Datei denn runtergeladen ?
Ich habe beide Versionen mit wget http://www.fbplinux.de/fbox.new/cfg_asterisk1x geladen.
spblinux
Mit der spblinux.de/fbox/cfg_asterisk14 ging's dann (die 16 meckert wegen einer fehlenden www.spblinux.de/fbox/26/asterisk16_usb.sqf).
Danke Euch beiden. :)
Ist halt ein wenig doof, wenn man das Zeugs nicht selbst irgendwie zusammengefrickelt bekommt. ;)
Bitte nochmal von c2a2b2.com/fbox bzw c2a2b2.com/fbox/0.9.29 runterladen und erneut testen.
Es gab einen kleinen "Bug" im Script, der gerade angepasst wurde ...
selbes Problem hatte ich auch. Selben Fehler. Hab dann wieder die 16er Version installiert. Damit lief es wieder.
Hab Labor-Version 29.04.93-10770.
Hilft evtl. ne neuere Labor??
mit der c2a2b2.com/fbox/0.9.29/cfg_asterisk16 funktioniert's zusammen mit 29.04.59.
Danke. :)
ok danke dynamic werds gleich mal testen.:groesste:
McBebe1
