Chan_capi compilen unter Suse 9.2
modules.conf:
[modules]
autoload=yes
; If you want, load the GTK console right away.
; Don't load the KDE console since
; it's not as sophisticated right now.
noload => pbx_gtkconsole.so
;load => pbx_gtkconsole.so
noload => pbx_kdeconsole.so
; Intercom application is obsoleted by
; chan_oss.  Don't load it.
noload => app_intercom.so
; Explicitly load the chan_modem.so early on to be sure
; it loads before any of the chan_modem_* 's afte rit
load => chan_modem.so
load => res_musiconhold.so
; Load either OSS or ALSA, not both
; By default, load OSS only (automatically) and do not load ALSA
noload => chan_alsa.so
;noload => chan_oss.so
noload => chan_zap.so
; Module names listed in "global" section will have symbols globally
; exported to modules loaded after them.
[global]
chan_modem.so=yes
chan_capi.so=yes
chan_zap.so=no
Fehler:
 [app_zapateller.so] => (Block Telemarketers with Special Information Tone)
  == Registered application 'Zapateller'
 [app_zapbarge.so] => (Barge in on Zap channel application)
  == Registered application 'ZapBarge'
 [app_zapras.so] => (Zap RAS Application)
  == Registered application 'ZapRAS'
 [app_zapscan.so]Jan 23 16:00:23 WARNING[1071]: loader.c:309 ast_load_resource: /usr/lib/asterisk/modules/app_zapscan.so: undefined symbol: ast_channel_walk
Jan 23 16:00:23 WARNING[1071]: loader.c:500 load_modules: Loading module app_zapscan.so failed!
Ouch ... error while writing audio data: : Broken pipe
Could not resync/reset buffers: No such process
Skipped ID3 Tag!
hm...
schmeiss noch chan_modem raus, das brauchst du auch nicht. Weiss jetzt nicht, was das noch so alles nachzieht. Schon die modules.conf von mir probiert, die ich weter oben gepostet habe?
Was der jetzt für Schmerzen mit dem zaptel-zeug hat... :gruebel:
mit der modules.conf bekomme ich folgenden Fehler:
Jan 23 16:09:47 WARNING[1119]: chan_skinny.c:2602 reload_config: Unable to get our IP address, Skinny disabled
  == Registered channel type 'Skinny' (Skinny Client Control Protocol (Skinny))
 [chan_zap.so]Jan 23 16:09:47 WARNING[1119]: loader.c:309 ast_load_resource: /usr/lib/asterisk/modules/chan_zap.so: undefined symbol: ast_manager_register
Jan 23 16:09:47 WARNING[1119]: loader.c:500 load_modules: Loading module chan_zap.so failed!
[root@spiderstar asterisk]# Ouch ... error while writing audio data: : Broken pipe
könnte es schlicht und ergreifend sein, dass unter /usr/lib/asterisk/modules noch irgendwelche Überresete einer alten asterisk-Installation rumfliegen, wo zaptel mit installiert war und das chan_zap.so jetzt schlicht und ergreifend nicht zum * passt? hmm? :)
Wenn Du es nicht grade selber installiert hast und es eh nicht brauchst, schieb es doch einfach mal woanders hin.
Jetzt läuft * ! :)
Bin mal gespannt ob er auch Bug-Frei läuft ...
Installiert habe ich die CVS vom 16.01.05 und chan_capi 0.3.5
Noch eine Frage:
Wie kann ich Overlap Dialing in Chan_capi einstellen?
Wir haben eine Telefonanlage mit 2stelliger Durchwahl (123456-89).
Vielen Dank für die Hilfe ! :)
