chan_sccp: Call forwarding
Stonequader
8 Nov 2006
Ich probiere gerade Asterisk 1.2 mit chan_sccp 20060204 aus, dazu ein Cisco 7940 mit SCCP Firmware 8.0(6.0).
Problem dabei: Ich habe die CFwdAll-taste nur während eines Gesprächs, also kann ich die einmal gesetzte Weiterleitung nicht wieder löschen. Wie bekomme ich die vorhandene Weiterleitung wieder weg - und wie sage ich Asterisk oder dem Telefon, dass der CFwdAll-Button immer angezeigt werden soll.
Hier noch meine sccp.conf, falls die wichtig sein sollte:
; (SCCP*)
; An implementation of Skinny Client Control Protocol (SCCP)
; Sergio Chersovani ([email protected])
; http://chan-sccp.belios.de
[general]
servername = Asterisk                   ; show this name on the device registration
keepalive = 60                          ; phone keep alive message evey 60 secs. Used to check the voicemail
debug = 1                                       ; console debug level. 1 => 10
context = default
dateFormat = D.M.Y                      ; M-D-Y in any order. Use M/D/YA (for 12h format)
bindaddr = 0.0.0.0                      ; replace with the ip address of the asterisk server (RTP important param)
port = 2000                                     ; listen on port 2000 (Skinny, default)
disallow=all                            ; First disallow all codecs
allow=alaw                                      ; Allow codecs in order of preference
allow=ulaw                                      ;
firstdigittimeout = 8                   ; dialing timeout for the 1st digit
digittimeout = 4                                ; more digits
;digittimeoutchar = #                   ; you can force the channel to dial with this char in the dialing state
autoanswer_ring_time = 1                ; ringing time in seconds for the autoanswer, the default is 0
autoanswer_tone = 0x32                  ; autoanswer confirmation tone. For a complete list of tones: grep SKINNY_TONE sccp_protocol.h
                                                ; not all the tones can be played in a connected state, so you have to try.
remotehangup_tone = 0x32                ; passive hangup notification. 0 for none
transfer_tone = 0                               ; confirmation tone on transfer. Works only between SCCP devices
callwaiting_tone = 0x2d                 ; sets to 0 to disable the callwaiting tone
musicclass=default                      ; Sets the default music on hold class
language=en                                     ; Default language setting
;accountcode=skinny                     ; accountcode to ease billing
deny=0.0.0.0/0.0.0.0                    ; Deny every address except for the only one allowed.
permit=192.168.1.0/255.255.255.0        ; Accept class C 192.168.1.0
                                                ; You may have multiple rules for masking traffic.
                                                ; Rules are processed from the first to the last.
                                                ; This General rule is valid for all incoming connections. It's the 1st filter.
;localnet = 192.168.1.0/255.255.255.0 ; All RFC 1918 addresses are local networks
;externip = 1.2.3.4                     ; IP Address that we're going to notify in RTP media stream
;externhost = mydomain.dyndns.org   ; Hostname (if dynamic) that we're going to notify in RTP media stream
; externrefresh = 60                    ; expire time in seconds for the hostname (dns resolution)
dnd = on                                        ; turn on the dnd softkey for all devices. Valid values are "off", "on" (busy signal), "reject" (busy signal), "silent" (ringer = silent)
rtptos = 184                            ; sets the default rtp packets TOS
echocancel = on                         ; sets the phone echocancel for all devices
silencesuppression = off                ; sets the silence suppression for all devices
;callgroup=1,3-4                                ; We are in caller groups 1,3,4. Valid for all lines
;pickupgroup=1,3-5                      ; We can do call pick-p for call group 1,3,4,5. Valid for all lines
;amaflags =                             ; Sets the default AMA flag code stored in the CDR record
trustphoneip = no                               ; The phone has a ip address. It could be private, so if the phone is behind NAT
                                                ; we don't have to trust the phone ip address, but the ip address of the connection
tos = 0x68                                      ; call control packets tos (0x68 Assured forwarding)
;earlyrtp = none                                ; valid options: none, offhook, dial, ringout. default is none.
                                                ; The audio strem will be open in the progress and connected state.
private = on                            ; permit the private function softkey
;mwilamp = on                           ; Set the MWI lamp style when MWI active to on, off, wink, flash or blink
;mwioncall = off                                ; Set the MWI on call.
;blindtransferindication = ring ; moh or ring. the blind transfer should ring the caller or just play music on hold
protocolversion = 5                     ; skinny version protocol. Just for testing. 2 to 6
cfwdall = on                            ; activate the callforward ALL stuff and softkeys
cfwdbusy = on                           ; activate the callforward BUSY stuff and softkeys
[devices]
type        = 7940                      ; device type (see below)
autologin   = 79401 ; lines list. You can add an empty line for an empty button (7960, 7970, 7940, 7920)
description = Phone7940                 ; internal description. Not important
;tzoffset  = +2
transfer = on                           ; enable or disable the transfer capability. It does remove the transfer softkey
park = off                                      ; take a look to the compile howto. Park stuff is not compiled by default
;speeddial =                            ; you can add an empty speedial if you want an empty button (7960, 7970, 7920)
;speeddial = 1000,name                  ; speeddial number and name
cfwdall = on                            ; activate the callforward stuff and softkeys
cfwdbusy = on
dtmfmode = inband                               ; inband or outofband. outofband is the native cisco dtmf tone play.
                                        ; Some phone model does not play dtmf tones while connected (bug?), so the default is inband
;imageversion = P00405000700            ; useful to upgrade old firmwares (the ones that do not load *.xml from the tftp server)
deny=0.0.0.0/0.0.0.0                    ; Same as general
permit=192.168.1.240/255.255.255.255    ; This device can register only using this ip address
dnd = on                                        ; turn on the dnd softkey for this device. Valid values are "off", "on" (busy signal), "reject" (busy signal), "silent" (ringer = silent)
private = on                            ; permit the private function softkey for this device
device => SEP00xxxxxxxxxx               ; device name SEP<MAC>
[lines]
id          = 79401                     ; future use
pin         = 1234                      ; future use
label       = 79401                     ; button line label (7960, 7970, 7940, 7920)
description = Test 79401                ; top diplay description
context     = default
incominglimit = 2                               ; more than 1 incoming call = call waiting.
transfer = on                           ; per line transfer capability. on, off, 1, 0
mailbox = 79401                         ; voicemail.conf (syntax: vmbox[@context][:folder])
vmnum = 750                                     ; speeddial for voicemail administration, just a number to dial
cid_name = 79401 CID                    ; caller id name
cid_num = 79401
trnsfvm = 1000                          ; extension to redirect the caller (e.g for voicemail)
secondary_dialtone_digits = 9           ; digits for the secondary dialtone (max 9 digits)
secondary_dialtone_tone = 0x22  ; outside dialtone
;accountcode=79401                      ; accountcode to ease billing
rtptos = 184                            ; sets the the rtp packets TOS for this line
echocancel = on                         ; sets the phone echocancel for this line
silencesuppression = off                ; sets the silence suppression for this line
;callgroup=1,3-4                                ; We are in caller groups 1,3,4. Valid for this line
;pickupgroup=1,3-5                      ; We can do call pick-p for call group 1,3,4,5. Valid for this line
;amaflags =                             ; Sets the default AMA flag code stored in the CDR record for this line
line => 79401
; phone types
;    12 -- Cisco IP Phone 12SP+ (or other 12 variants)
;    30 -- Cisco IP Phone 30VIP (or other 30 variants)
;  7902 -- Cisco IP Phone 7902G
;  7905 -- Cisco IP Phone 7905G
;  7910 -- Cisco IP Phone 7910
;  7912 -- Cisco IP Phone 7912G
;  7935 -- Cisco IP Conference Station 7935
;  7936 -- Cisco IP Conference Station 7936
;  7920 -- Cisco IP Wireless Phone 7920
;  7940 -- Cisco IP Phone 7940
;  7960 -- Cisco IP Phone 7960
;  7970 -- Cisco IP Phone 7970
;  7914 -- Cisco IP Phone 7960 with a 7914 addon
;   ata -- Cisco ATA-186 or Cisco ATA-188
;  kirk -- Kirk telecom ip phones
Danke & viele Grüße
IchBinEsDoch
