cisco 7912 mit chan_sccp an *
finace
21 Feb 2007
ich habe folgendes Problem.
Wenn sich mein Cisco 7912 bei Asterisk anmelden versucht erhalte ich folgenden Error
[Aug 11 00:22:38] ERROR[4044]: chan_skinny.c:2875 handle_register_message: Rejecting Device SEP0016471A635C: Device not found
[Aug 11 00:22:38] WARNING[4044]: chan_skinny.c:4172 get_input: Skinny Client sent less data than expected.  Expected 4 but got 0.
wenn ich denn code richtig verstehe versucht er sich an der Skinny Datei anzumelden. Diese habe ich aber, in der Modules.conf deaktivert.
Modules.conf
; Asterisk configuration file
; Module Loader configuration file
[modules]
autoload=yes
[global]
chan_capi.so=yes
; Any modules that need to be loaded before the Asterisk core has been
; initialized (just after the logger has been initialized) can be loaded
; using 'preload'. This will frequently be needed if you wish to map all
; module configuration files into Realtime storage, since the Realtime
; driver will need to be loaded before the modules using those configuration
; files are initialized.
; An example of loading ODBC support would be:
;preload => res_odbc.so
;preload => res_config_odbc.so
; Uncomment the following if you wish to use the Speech Recognition API
;preload => res_speech.so
; If you want, load the GTK console right away.
; Don't load the KDE console since
; it's not as sophisticated right now.
noload => pbx_gtkconsole.so
;load => pbx_gtkconsole.so
noload => pbx_kdeconsole.so
load => res_musiconhold.so
; Load either OSS or ALSA, not both
; By default, load OSS only (automatically) and do not load ALSA
noload => chan_alsa.so
;noload => chan_oss.so
noload => pbx_ael.so
noload => chan_skinny.so
load => chan_sccp.so
load => chan_capi.so
Hier meine sccp.conf
[general]
keepalive = 30                   ; IMPORTANT: 5secs. lead to trouble with
                                ; 7960
context = internal
dateFormat = D.M.YA              ; M-D-Y in any order (5 chars max)
bindaddr = 192.168.0.6         ; asterisk box.
port = 2000                      ; listen on port 2000 (Skinny, default)
debug = 10
[devices]
type        = 7912
description = Bedroom
tzoffset    = 0
autologin   = 6004
device => SEP0016471A635C
type        = 7960
description = Office
tzoffset    = 0
autologin   = 6000
speeddial   = 6001,6001,6001@internal
speeddial   = 6004,6004,6004@internal
device => SEPxxxxxxxxxxxx
type        = 7960
description = LivingRoom
tzoffset    = 0
autologin   = 6001
speeddial   = 6000,6000,6000@internal
; This is an example config with multiple phones
; 08/2005 Stefan Gofferje
[lines]
id            = 6000
pin           = 1234
label         = 6000
context       = client_int_unrestricted
callwaiting   = 1
incominglimit = 2
mailbox       = 1000
vmnum         = 8500
cid_name      = Office
cid_num       = 6000
line => 6000
id            = 6001
pin           = 1234
label         = 6001
callwaiting   = 1
incominglimit =  2
mailbox       = 1000
vmnum         = 8500
cid_name      = Living Room
cis_num       = 6001
line => 6001
id            = 6004
pin           = 1234
label         = 6004
callwaiting   = 1
incominglimit = 2
mailbox       = 1000
vmnum         = 8500
cid_name      = Bedroom
cid_num       = 6004
line => 6004
kann mir bitte jemand weiterhelfen, ich weiss nicht weiter.
Die Mac Adresse stimmt das habe mehre mal überprüft.
Mfg
Thomas
Die 'load' und 'noload' statements müssen unter [modules] stehen (nicht unter [global]).
mwsss
