compile balance for 7270
stefanoIT
11 Jul 2007
I'm trying to compile balance tcp proxy http://www.inlab.de/balance.html for 7270 using freetz 1.0.3
It seems working but when I try to use that on 7270 I receive this message:
# ./balance -d -f -b 192.168.4.8 1008 192.168.4.9:80
argv[0]=./balance
bindhost=192.168.4.8
source port 1008
file /var/run/balance/balance.1008.192.168.4.8 already exists
./balance: can't resolve symbol 'index'
I'm forgotting something in the compiling. or What?
Thanks
stefano
Please use the stable freetz-1.1 for testing, and the trunk for developing, cause features are only added in trunk
If you are using freetz-1.0.3 you should also compile your binary with the toolchain from freetz-1.0.3.
This is not the first time I'm seeing this problem:
http://trac.freetz.org/changeset/1122
Regards,
Oliver
I solved using --static option of gcc.
I have some problem in shader library, it's very difficult to find it.
stefano
nightdeck
