default prefix in PSTN dialing, is this possible?
vpe
24 Feb 2006
Hello,
i need make all calls to PSTN (*111#) make with prefix: *31*, how i set this?
simple: i need before all cals sended to PSTN send *31*number
Not work with setting on Telefoniegeräte or Internettelefonie in FBF management :-(
Is prefix to PSTN possible?
Or via voip.cfg is possible?
Many thanx..
Why don't simply try? It works, to call *111#*31*telconumber. If the called number is occupied and a recall is requested, then the calling number will be provided for the recall.
In Germany is *31# used to restrict sending your own number. This is adjusted on the page "Telefoniegeräte" (Eigene Rufnummer unterdrücken (COLR)). It's not possible to change this prefix.
Gruß Telefonmännchen
but i try before ask and get inband "called number not exist"
if same try direkt to PSTN (without fritz), works fine !
i look on fritz.box:1012 monitor and call is same in both cases:
*111#telconumber
fritz.box:1012 telnet monitor maybe have bug or filter, if show same number but in *111#*31*telconumber situation PSTN TSP say: "called number not exist" and second works fine.
If make from same telephone device (Siemens DECT) direct call to PSTN: *31*telconumber, works fine.
yes, here is same in O2 cell phones (*31#), but in O2 PSTN is *31* and not possible switch in O2 permanent CLIR - not ask me why is this.
Then, not possible change the prefix in FBF in any internal settings?
Maybe on request AVM make in voip.cfg or ar7.cfg file any settings for change possibility this switch in future release?
and second, i need CLIR functionality.. COLR is IMHO Connected Line Identification Restriction, COLP (Connected Line Identification) inversion.. COLR is for disable identify forward calls..
from AVM no response until now :-( i check mailbox now.
i found any BUG in AVM firmware:
if i make call on my phone
then FRITZ still send to PSTN line this:
*31#telconumber
(say DTRACE32.EXE 2.08 (C) AVM Berlin - see picture)
then, but i need still give preffix *31* automatically ideally by any txt parameter (for ex. from ar7.cfg etc), not by hand on my phone before all calls...
Update from AVM:
Sending a keypad sequence to the landline provider:
- lift the receiver
- dial *111#*#*31*telconumber
work, but this is very hard work before all calls :-)
Kn72
