Deutsche Menüführung CCME 4.0 + 7960
olliman
4 Jan 2007
Hallo Leute,
kurz ne Frage. Wie kann man auf einen Router 2851 mit der IOS Version 12.4.(11)T und einem Call Manager Express v4.0(2). Daran hängen mehrere 7940 oder 7960 Phones. Ich möchte die auf deutsche Menüsprache umstellen. Die Sprachfiles sind schon runtergeladen, am Flash und per TFTP Server freigeschalten.
Hier meine Config:
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname CISCO_2851
boot-start-marker
boot system flash c2800nm-spservicesk9-mz.124-11.T.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$BrE5$XpRZF7/vWx1GB7Ve4FVAl1
no aaa new-model
network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.61.1 192.168.61.10
ip dhcp excluded-address 192.168.61.245 192.168.61.255
ip dhcp pool VOIP
network 192.168.61.0 255.255.255.0
default-router 192.168.61.1
option 150 ip 192.168.61.1
ip dhcp pool ITS
ip tftp source-interface GigabitEthernet0/1
no ip domain lookup
ip dhcp-server 192.168.61.1
multilink bundle-name authenticated
isdn switch-type basic-net3
voice-card 0
no dspfarm
interface Loopback0
ip address 192.168.11.254 255.255.255.255
interface GigabitEthernet0/0
description Management Port
ip address 10.10.10.1 255.255.255.248
duplex auto
speed auto
description Anschluss VOIP
ip address 192.168.61.1 255.255.255.0
duplex auto
speed auto
interface BRI0/0/0
no ip address
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn guard-timer 1000
isdn send-alerting
isdn sending-complete
isdn static-tei 0
isdn skipsend-idverify
interface BRI0/0/1
no ip address
isdn switch-type basic-5ess
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
tftp-server flash:P00307020400.bin
tftp-server flash:P00307020400.sb2
tftp-server flash:P00307020400.sbn
tftp-server flash:P00307020400.loads
tftp-server flash:de-mk-sccp.jar
tftp-server flash:de-td-sccp.jar
control-plane
voice-port 0/0/0
compand-type a-law
cptone AT
timeouts call-disconnect 0
bearer-cap Speech
voice-port 0/0/1
dial-peer voice 2 pots
description ISDN
destination-pattern 0T
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 3 voip
destination-pattern 2..
session target ipv4:192.168.61.254
telephony-service
load 7960-7940 P00307020400
max-ephones 5
max-dn 5
ip source-address 192.168.61.1 port 2000
timeouts interdigit 2
cnf-file location flash:
cnf-file perphone
user-locale DE
user-locale 1 DE
user-locale 2 DE
user-locale 3 DE
user-locale 4 DE
network-locale AT
network-locale 1 AT
network-locale 2 AT
network-locale 3 AT
network-locale 4 AT
max-conferences 8 gain -6
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Jan 09 2007 16:58:19
ephone-template 1
network-locale 1
user-locale 1
Bitte wie stellt man nun ein, dass die Telefone die deutsche Menüführung annehmen. Bisher ist es mir nicht gelungen :(
MfG
Martin
Danke im Vorraus!
Eigentlich sollte der Call Manager Express v4.0(2) schon deutsche Locales für die 7940er und 7960er integriert haben. Die Locales sind lediglich für 7941, 7961 und 7970. Schau mal hier:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a00806dad6a.html
Die Locales sollst Du laut Cisco anders installieren:
Diese sollten sich in den Directories German_Germany und Germany befinden.
Die tftp Server Befehle sehen dann so aus:
Router(config)# tftp-server flash:/de-td-sccp.jar alias German_Germany/td-sccp.jar
Router(config)# tftp-server flash:/g3-tones.xml alias Germany/g3-tones.xml
Hier der Link zu der Cisco Anleitung:
http://www.cisco.com/en/US/products...figuration_guide_chapter09186a00806a7fe7.html
Bei mir in der Config sieht das so aus:
show flash:
75 884 Sep 22 2006 14:25:40 +02:00 Readme-locale-de_DE.txt
76 0 Sep 22 2006 14:26:14 +02:00 German_Germany
78 67413 Sep 22 2006 14:27:16 +02:00 German_Germany/mk-sccp.jar
79 69128 Sep 22 2006 14:27:32 +02:00 German_Germany/tc-sccp.jar
80 67710 Sep 22 2006 14:27:48 +02:00 German_Germany/td-sccp.jar
81 932 Sep 22 2006 14:35:40 +02:00 German/g3-tones.xml
83 932 Sep 22 2006 14:45:02 +02:00 Germany/g3-tones.xml
tftp-server Befehle:
tftp-server flash:de-mk-sccp.jar alias German_Germany/mk-sccp.jar
tftp-server flash:de-tc-sccp.jar alias German_Germany/tc-sccp.jar
tftp-server flash:de-td-sccp.jar alias German_Germany/td-sccp.jar
tftp-server flash:g3-tones.xml alias German/g3-tones.xml
tftp-server flash:g3-tones.xml alias Germany/g3-tones.xml
telephony-service
load 7960-7940 P00307020200
load 7970 TERM70.7-0-1-0s
user-locale DE
network-locale DE
time-zone 23
time-format 24
date-format dd-mm-yy
keepalive 10
voicemail 99
create cnf-files version-stamp 7960 Dec 14 2006 14:05:21
Was Du noch versuchen kannst:
gehe in den telephony-service und gebe "create cnf-files" ein. Starte dann mal ein Phone neu. Wie gesagt, eigentlich sollte der 4er CME die deutschen Locales für die 7940er und 7960er integriert haben.
Gruss
motivator77
Hi Motivator77,
danke für die Info. Ich weiß nicht, ich such stundenlang auf cisco.com und finde diese Tutorials nicht :( danke auf jeden Fall.
Der Befehl create cnf-files hat nie was gebracht, das hab ich bei jeder Änderung gemacht und nichts ist geschehen. Auf den Phones stand immer "Locale Updating error". Das kann daran liegen, ich werds mal versuchen und euch dann bescheid geben, obs so funktioniert hat oder nicht.
MfG
Martin
Hi Leute,
es funktioniert so wie Motivator es gesagt hat.
Danke für die Hilfe!
MfG
Martin
buggernot123
