Dial mISDN/4/$OUTNUM or mISDN/2-2/$OUTNUM
XyVy
22 Jul 2008
Hello guys,
I have confused in this topic. I have a OpenVox B200P, the card has 2 BRI Ports.
When I want to do dial using 2nd channel in 2nd BRI port, what do I must to use?
Thanks in advance!
May be to select the correct channel the dial string must be:
mISDN/P:C/$OUTNUM ?
Where P = Port and C = Channel ?
Thanks.
Afaik not possible :(. You can use the port-number or a group-name to select a port. You can't select the channel within the port(s).
mISDN/portnumber/$OUTNUM or
mISDN/g:group-name/$OUTNUM
It works as I said in previous post, the example below:
Thu Nov  6 21:49:46 2008: P[ 1]   --> Call on preselected Channel (1).
Thu Nov  6 21:49:46 2008: P[ 1]   --> preselected_channel: 1
Thu Nov  6 21:49:46 2008: P[ 1]  channel with stid:0 not in use!
Thu Nov  6 21:49:46 2008: P[ 0]   --> * NEW CHANNEL dad:968261513 oad:(null)
Thu Nov  6 21:49:46 2008: P[ 1]  * Queuing chan 0xb7b7ac08
Thu Nov  6 21:49:46 2008: P[ 1]  read_config: Getting Config
Thu Nov  6 21:49:46 2008: P[ 1]  config_jb: Called
Thu Nov  6 21:49:46 2008: P[ 1]   --> * CallGrp:1 PickupGrp:1
Thu Nov  6 21:49:46 2008: P[ 1]   --> TON: Unknown
Thu Nov  6 21:49:46 2008: P[ 1]   --> LTON: Unknown
Thu Nov  6 21:49:46 2008: P[ 1]   --> CTON: Unknown
Thu Nov  6 21:49:46 2008: P[ 1]  * CALL: 1:1/968261513
Thu Nov  6 21:49:46 2008: P[ 1]   --> * dad:7968261513 tech:mISDN/1-u294 ctx:fro
m-pstn
Thu Nov  6 21:49:46 2008: P[ 1]   --> * adding2newbc ext 7968261513
Thu Nov  6 21:49:46 2008: P[ 1]   --> * adding2newbc callerid 968937190
Thu Nov  6 21:49:46 2008: P[ 1]   --> pres: -1 screen: -1
Thu Nov  6 21:49:46 2008: P[ 1]   --> pres: 0
Thu Nov  6 21:49:46 2008: P[ 1]   --> PRES: Allowed (0x0)
Thu Nov  6 21:49:46 2008: P[ 1]   --> SCREEN: Unscreened (0x0)
Thu Nov  6 21:49:46 2008: P[ 1]  NO OPTS GIVEN
Thu Nov  6 21:49:46 2008: P[ 1]  I SEND:SETUP oad:968937190 dad:968261513 pid:18
Thu Nov  6 21:49:46 2008: P[ 1]   --> bc_state:BCHAN_CLEANED
Thu Nov  6 21:49:46 2008: P[ 1]   --> channel:1 mode:TE cause:16 ocause:16 rad:
cad:
Thu Nov  6 21:49:46 2008: P[ 1]   --> info_dad: onumplan:0 dnumplan:0 rnumplan:0
 cpnnumplan:0
Thu Nov  6 21:49:46 2008: P[ 1]   --> caps:Speech pi:0 keypad: sending_complete:
Thu Nov  6 21:49:46 2008: P[ 1]   --> screen:0 --> pres:0
Thu Nov  6 21:49:46 2008: P[ 1]   --> addr:0 l3id:20017 b_stid:0 layer_id:500101
80
Thu Nov  6 21:49:46 2008: P[ 1]   --> facility:Fac_None out_facility:Fac_None
Thu Nov  6 21:49:46 2008: P[ 1]   --> urate:0 rate:16 mode:0 user1:0
Thu Nov  6 21:49:46 2008: P[ 1]   --> bc:89caa04 h:0 sh:0
IchBinEsDoch
