[Frage] Dial numbers before each call
atux_null
31 Aug 2017
i would like to create some dialing rules when calling 10 digit numbers
2XXXXXXXXX
69XXXXXXXX
looking for starts to add *31* before the calls.
i have tried it like:
how can i fix that please?
Hallo.
Eine Möglichkeit.
1.Deine 10 Rufnummern ohne *31* bei den Wählregeln eintragen 2XXXXXXXX
2.Die Anwahl immer mit *31* 2XXXXXXXX
Zweite Möglichkeit.
Für diese Fixed Line beim Provider die Rufnummernübertragung dauernd ausschalten
Thanks for the reply. This is what I have tried but the 2XXXXXXXXX is not accepted, see error screenshot
This field ist the dialed number, means 2XXXXXXXX.
the *31*2XXXXXXXX You mus put as a call by call Number and then use it in the dialing roule at "conneced via"
Not sure I follow your instructions. Could you please explain it to me or share print screens?
Sorry if found that it will not work. For the call by call number also only digits are allowed. Therefore, You have no possibility to add this *31# code.
Even though. How can I achieve that with fritzbox to send permanently a hidden caller id, please? As I mentioned above i have issues to make it work
If your lines are VoIP based, then You can set this at the settings of each phone device: "CLIR".
And you must configure the CLIR feature at the VoIP account correctly. But You have if it already worked.
If You have an old analog fixed line, then there is no real solution.
ipscout
