debian-asterisk:~# cat /var/log/diva1.log
INITIAL XLOG: CARD:1, Dialogic Diva 4BRI-8 PCI v2 SN:8386 - PORT 1, STARTED AT: Do 10. Sep 02:15:33 CEST 2009
Package Build: 3.1.4-109.75-1
0:0063:209 - Instance(0)=0x80356000 image_start=0x80000000, shared_memory=0xa0001000 card=53
0:0000:000 - Diva Server 4BRI-8M 2.0 (2620)
0:0000:000 - Protocol: 'TE_DMLT, Build 109-76, Protocol 6.03(V19) 108-1 [F#01FF]'
0:0000:000 - DSP task 6: DIVA Server BRI 2M Kernel Version 1.00 Build 109-789
0:0000:000 - DSP task 15: DIVA Server BRI 2M SoftIP Kernel Version 1.00 Build 109-789
0:0000:000 - DSP task 100: HSCX Task Version 1.00 Build 109-789
0:0000:000 - DSP task 104: HSCXBR Task Version 1.00 Build 109-789
0:0000:000 - DSP task 107: HSCX Small Task Version 1.00 Build 109-789
0:0000:001 - DSP task 110: PIAFSD Task Version 1.00 Build 109-789
0:0000:001 - DSP task 200: V.110 Kernel Task Version 1.00 Build 109-789
0:0000:001 - DSP task 201: V.110 Overlay (600) Version 1.00 Build 109-789
0:0000:001 - DSP task 202: V.110 Overlay (1200) Version 1.00 Build 109-789
0:0000:001 - DSP task 203: V.110 Overlay (1200/75) Version 1.00 Build 109-789
0:0000:001 - DSP task 204: V.110 Overlay (75/1200) Version 1.00 Build 109-789
0:0000:001 - DSP task 205: V.110 Overlay (2400) Version 1.00 Build 109-789
0:0000:001 - DSP task 206: V.110 Overlay (4800,9600,19200,38400) Version 1.00 Build 109-789
0:0000:001 - DSP task 207: V.110 Overlay (7200,14400,28800) Version 1.00 Build 109-789
0:0000:001 - DSP task 208: V.110 Overlay (12000,24000) Version 1.00 Build 109-789
0:0000:001 - DSP task 209: V.110 Overlay (48000) Version 1.00 Build 109-789
0:0000:001 - DSP task 210: V.110 Overlay (56000) Version 1.00 Build 109-789
0:0000:001 - DSP task 225: V.110 Kernel Task BRI 2M Version 1.00 Build 109-789
0:0000:001 - DSP task 504: VOICEBR Task Version 1.00 Build 109-789
0:0000:001 - DSP task 510: DTMF Task Version 1.00 Build 109-789
0:0000:001 - DSP task 512: DTMFBR Task Version 1.00 Build 109-789
0:0000:001 - DSP task 520: SIG.MDM Task Version 1.00 Build 109-789
0:0000:001 - DSP task 532: TONEBR Task Version 1.00 Build 109-789
0:0000:001 - DSP task 542: MEASBR Task Version 1.00 Build 109-789
0:0000:001 - DSP task 552: LECBR Task Version 1.00 Build 109-789
0:0000:001 - DSP task 590: Conferencing Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 600: TIKRNL81.F34 Task Version 1.00 Build 109-789
0:0000:001 - DSP task 624: SIG Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 604: FSK OWN Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 607: V8.F34 Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 608: INFO Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 609: V.34 Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 622: INFOH.F34 Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 623: HV34.F34 Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 610: DIAL/FSK/FAX.F34 Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 611: DIAL.F34 Partial Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 612: FSKFAX.F34 Partial Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 613: FAX.F34 Partial Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 614: V.22/V.32 LEC Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 615: V.32 Partial Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 618: V.90 DPCM Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 619: V.90 APCM Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 625: V.22FC Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 629: V.22bis FC Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 627: V.29FC Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 620: V.18 OWN-LK Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 621: V.OWN Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 702: VKRNLBR.SEC Task Version 1.00 Build 109-789
0:0000:001 - DSP task 709: VKRNL Small Task Version 1.00 Build 109-789
0:0000:001 - DSP task 703: G.711 Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 704: RTP G.711/G.726 Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 706: RTP GSM Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 711: RTP G.729AB Overlay Version 1.00 Build 109-789
0:0000:001 - DSP task 722: CKRNLBR.SEC Task Version 1.00 Build 109-789
0:0000:001 - Conf: DLI21st=1,MWIREG=1,ECTA=1,ECTF=1
0:0000:002 - Conf: S2=1,Tei=0,NT2=1,Perm=0,WDog=0,LowCh=0,L1Hunt=0x0
0:0000:002 - Conf: Loop=0,DidLen=0,Law=0,nosig=0,AlertTO=0xffff,PDisc=0
0:0000:002 - Conf: Prot=1,PVer=0,NT=1,Lim=0,RTone=0,L2_Links=8
0:0000:002 - Conf: XConn=0/6,ClkM=1/128/4096,ClkP=0000/0/0
0:0000:002 - SN:8386-0 0 1 1 0 0
0:0000:003 - Initialize Softmodem!!
0:0000:003 - sysCreateDpc: handler=0x80142eb0, context=0x805f822c
0:0000:003 - sdp_dpc_init: check dpc 0 0x8035f0e8
0:0000:003 - sdp_dpc_init: assign dpc 0 0x8035f0e8
0:0000:003 - sysCreateDpc: handler=0x80142eb0, context=0x805fb574
0:0000:003 - sdp_dpc_init: check dpc 1 0x8035f0f4
0:0000:003 - sdp_dpc_init: assign dpc 1 0x8035f0f4
0:0000:003 - ddal_load_time_init: link instance 0 to ddal
0:0000:003 - task 0: sdp module not present! (own_gp=0x0, sdp_gp=0x0)
0:0000:003 - ddal_load_time_init: link instance 1 to ddal
0:0000:003 - task 1: sdp module not present! (own_gp=0x0, sdp_gp=0x0)
0:0000:003 - ddal_load_time_init: sdp module 0 not present!
0:0000:003 - ddal_load_time_init: sdp module 1 not present!
0:0000:003 - Initialized 0 instances:
0:0000:006 - init_bulk_buffers 4 65536 28672 2
0:0000:068 - Set_LineClock_OpMode: Set to 0x0000
0:0000:069 - [0] Starting kernel...
0:0000:071 - [0] DSP OK
0:0000:071 - [1] Starting kernel...
0:0000:073 - [1] DSP OK
0:0000:073 - Initialize IPACX in NT mode
0:0000:073 - Hardware Initialisation done.
0:0000:076 - PSI: init
0:0000:076 - PSI:set etsi interface
0:0000:076 - CREATEID ok: context:0 assigned Id:1 freeIds=ef
0:0000:076 - manufacturer features: 0xaf307f94
0:0000:076 - D2Assign 0 d_id=01
0:0000:076 - MDL: init
0:0000:076 - MDL: init 0x8055d368 to entry 0
0:0000:077 - D2Assign 1 d_id=01
0:0000:077 - MDL: init 0x8055d684 to entry 1
0:0000:077 - D2Assign 2 d_id=01
0:0000:077 - MDL: init 0x8055d9a0 to entry 2
0:0000:077 - D2Assign 3 d_id=01
0:0000:077 - MDL: init 0x8055dcbc to entry 3
0:0000:077 - D2Assign 4 d_id=01
0:0000:077 - MDL: init 0x8055dfd8 to entry 4
0:0000:077 - D2Assign 5 d_id=01
0:0000:077 - MDL: init 0x8055e2f4 to entry 5
0:0000:077 - D2Assign 6 d_id=01
0:0000:077 - MDL: init 0x8055e610 to entry 6
0:0000:077 - D2Assign 7 d_id=01
0:0000:077 - MDL: init 0x8055e92c to entry 7
0:0000:078 - PCI DMA test: write 32 bytes system(0xa036142c) -> pci(0x36fae000)
0:0000:086 - PCI DMA test: read 32 bytes pci(0x36fae000) -> system(0xa036144c)
0:0000:086 - PCI DMA test OK
0:0000:086 - PCI DMA write transfer 163840 bytes in 8 mSec
0:0000:093 - PCI DMA read transfer 163840 bytes in 6 mSec
0:0000:385 - CREATEID ok: context:ff assigned Id:2 freeIds=ee
0:0000:402 - DELETEID ok: deleted Id:2 freeIds=ef
0:0000:406 - CREATEID ok: context:ff assigned Id:3 freeIds=ee
0:0000:406 - Use management combined indications, limit=4096
0:0000:520 - L1_UP
debian-asterisk:~#
