Does usbroot work on the 7270?
johnbock
2 Mrz 2008
I'm having problems manually loading the module Piglet_noemif using modprobe.
During boot I drop into ash
echo 'kernel_args init=/bin/ash' >/sys/kernel/urlader/environment
Mount all virtual filesystems
/lib/mdev/misc/virtual_fs mount
Load the piglet as in usbroot
   piglet_bitfile=/lib/modules/microvoip_isdn_top.bit${HWRevision_BitFileCount}
   dect_firstlevelfile=/lib/modules/dectfw_firstlevel.hex
   dect_secondlevelfile=/lib/modules/dectfw_secondlevel.hex
   piglet_load_params=""
   modprobe Piglet_noemif \
      piglet_bitfile=$piglet_bitfile \
      piglet_enable_button=2 \
      dect_firstlevelfile=$dect_firstlevelfile \
      dect_secondlevelfile=$dect_secondlevelfile \
      $piglet_load_params
And get an error stating modprobe can't load the module. Using insmod works.
I haven't look into the problem in detail yet, but it may have something to do with depmod while building the image...
Can you provide a log of your try?
Regards
Oliver
figo12
