DSMod / Fritz expanding users?
flemse
14 Mrz 2007
Hi
I want to expand the user login on my Fritz, I 'am running with DSMod.
Why? Because I dont like the SSH(root) FTP(ftp) login name.
Any suggest.
Flemming
What do you exactly want to do with this new user?
dsmod dropbear is patched to only allow root logins
Greets, Oliver
Hi
Thanks for reply.
If so I aggre; no need for more users!
But what I want to is: Disable root for dropbear and make a new "root" account with a nother name.
But maybe it bring too mutch problem...
Flemming
Then you will have to delete the patch make/dropbear/patches/100-root-login-only.patch and build dropbear again. In the webinterface you can disallow root logins for dropbear with expert option "-w".
But there is no script to add another user to dsmod at the moment. You will have to do that on your own.
Greets, Oliver
/var/mod/root $ modpasswd save
/var/mod/root $ echo 'flemse:*' >> /tmp/flash/shadow.save
/var/mod/root $ modpasswd load
/var/mod/root $ modpasswd flemse
Protonator
