DTMFBOX: Analoges AMT per SIP bereitstellen! unknown account!
MeTRiX
3 Feb 2009
ich habe das Thema hiermit aus dem Thread dtmfbox (AB/CB/CT VoIP/ISDN/Analog) ausgelagert. War dort glaube nicht so richtig einsortiert :-(
Ich habe eine Fritzbox Fon WLAN (2000 1665) heute mit der aktuellen Stable freetz-1.1-stable-3243 mit der aktuellen DTMFBox 0.5.0 versehen.
Hier die .CONFIG:
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_04_33=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5140 is not set
FREETZ_TYPE_FON_WLAN=y
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
# FREETZ_TYPE_FON_WLAN_7240 is not set
# FREETZ_TYPE_FON_WLAN_7270 is not set
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_SPEEDPORT_W701V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_AVM_VERSION_STRING="04.33"
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_A_CH is not set
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_LANG_STRING="de"
FREETZ_TYPE_STRING="fon_wlan"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
# FREETZ_REPLACE_KERNEL is not set
FREETZ_SHOW_ADVANCED=y
FREETZ_TARGET_REF="4mb_26"
FREETZ_KERNEL_REF="4mb_26"
FREETZ_KERNEL_LAYOUT="ar7"
FREETZ_KERNEL_MTD_SIZE=59
FREETZ_HAS_PHONE=y
# FREETZ_HAS_TAM is not set
FREETZ_HAS_WLAN=y
FREETZ_HAS_USB_CLIENT=y
# FREETZ_HAS_USB_HOST is not set
# FREETZ_HAS_AVM_INETD is not set
# Mod ------------------------------------
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
# Patches
# Remove Brandings
# FREETZ_REMOVE_BRANDING_1und1 is not set
# FREETZ_REMOVE_BRANDING_avm is not set
# FREETZ_REMOVE_BRANDING_aol is not set
FREETZ_REMOVE_HELP=y
FREETZ_REMOVE_ASSISTANT=y
# FREETZ_REMOVE_TR069 is not set
# FREETZ_REMOVE_USB_MODULE is not set
# FREETZ_REMOVE_CDROM_ISO is not set
# FREETZ_PATCH_ENUM is not set
# FREETZ_PATCH_SIGNED is not set
# FREETZ_PATCH_GETCONS is not set
# FREETZ_REMOVE_WEBSRV is not set
FREETZ_REMOVE_UPNP=y
FREETZ_REMOVE_UPNP_LIBS=y
FREETZ_REMOVE_USERMAN=y
FREETZ_REMOVE_DSLD=y
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_VOIP_ISDN is not set
# FREETZ_REMOVE_WLAN is not set
# Package selection
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DROPBEAR is not set
FREETZ_PACKAGE_DTMFBOX=y
# CAPI/SIP
FREETZ_PACKAGE_DTMFBOX_WITH_CAPI=y
FREETZ_PACKAGE_DTMFBOX_WITH_VOIP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ICE=y
# Codecs
FREETZ_PACKAGE_DTMFBOX_WITH_G711_CODEC=y
# FREETZ_PACKAGE_DTMFBOX_WITH_SPEEX_CODEC is not set
FREETZ_PACKAGE_DTMFBOX_WITH_GSM_CODEC=y
# Misc
# FREETZ_PACKAGE_DTMFBOX_SVN is not set
# FREETZ_PACKAGE_DTMFBOX_USE_DIFF_PATCH is not set
# FREETZ_PACKAGE_DTMFBOX_WITH_WEBPHONE is not set
FREETZ_PACKAGE_DTMFBOX_WITH_HELP=y
# FREETZ_PACKAGE_DTMFBOX_WITH_ESPEAK is not set
# FREETZ_PACKAGE_DTMFBOX_WITH_MADPLAY is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_OPENNTPD is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# Web interface
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
# FREETZ_PACKAGE_SYSLOGD_CGI is not set
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Debug helpers
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Testing
# FREETZ_GROUP_APACHE_PHP is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_SHOW_UNSTABLE_PACKAGES is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_SITE="ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan/firmware/deutsch"
FREETZ_DL_SOURCE="fritz.box_fon_wlan.08.04.34.image"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: http://freetz.3dfxatwork.de
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: http://freetz.wirsind.info
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: http://freetz.magenbrot.net
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_VERBOSITY_LEVEL=2
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_SUBVERSION_STRING=y
FREETZ_DEVELOPER_VERSION_STRING=y
# FREETZ_STATUS_STYLE is not set
# External
# EXTERNAL_ENABLED is not set
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_INETD is not set
# FREETZ_BUSYBOX_IP is not set
# FREETZ_BUSYBOX_PATCH is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
# FREETZ_BUSYBOX_FASTPROC is not set
# FREETZ_BUSYBOX_KEYS is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_TAC is not set
# FREETZ_BUSYBOX_MDEV_RENAME is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
# Kernel modules
# crypto
# FREETZ_MODULE_aes is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# fs
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext3 is not set
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_fuse is not set
# FREETZ_MODULE_jbd is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc_ccitt is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Shared libraries
# Libraries -------------------------------
# FREETZ_LIB_libatm is not set
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
# FREETZ_LIB_libcrypto is not set
# FREETZ_LIB_libssl is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
# FREETZ_LIB_libz is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
# FREETZ_LIB_libresolv is not set
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# FREETZ_LIB_libuClibc__ is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libglib_1 is not set
# GLib2
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
FREETZ_LIB_libcapi20=y
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libpcap is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
# Compiler options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_KERNEL_VERSION_2_6_13_1=y
# FREETZ_KERNEL_VERSION_2_6_19_2 is not set
FREETZ_KERNEL_VERSION="2.6.13.1"
FREETZ_TARGET_UCLIBC_VERSION_0_9_28=y
# FREETZ_TARGET_UCLIBC_VERSION_0_9_29 is not set
FREETZ_TARGET_GCC_VERSION="4.2.1"
FREETZ_TARGET_UCLIBC_VERSION="0.9.28"
FREETZ_TARGET_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
FREETZ_TARGET_CCACHE=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# FREETZ_TARGET_TOOLCHAIN is not set
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
Mein Vorhaben: Ich möchte den angeschlossenen Analog-Anschluss (GSM Gateway) per SIP meinem Asterisk bereitstellen.
Vorab: Ich habe an der FB ein Analog-Telefon angeschlossen und kann damit wunderbar über das GSM Gateway raustelefonieren. Also Funktion ist grundsätzlich gegeben.
Meinen ISDN-Anschluss bekomme ich übrigens auch mit der selben Box problemlos bereitgestellt. Nur Analog will nicht.
Hier meine dtmfbox.cfg:
//[HTML:<script>function show_title(title) { document.write("<table border='0' cellpadding='3' width='95%'><tr><td bgcolor='#cccccc'><b>" + title + "</b></td></tr></table>"); }</script>]
//[HTML:<script>function set_group(div, setting, visible_value) { document.getElementById(div).style.display=(document.getElementById(setting).value == visible_value ? 'block' : 'none') }</script>]
[general]
adjust_priority=1		// Prozess-Priorität dynamisch anpassen [OPTION:1|ja,0|nein]
max_connections=10		// Max. Anzahl an parallelen Verbindungen [WIDTH:50px]
delimiter=none			// Standard-Trenner für DTMF-Zeichen [HIDE:1]
scriptfile=none			// Benutzerdefiniertes Skript [HIDE:1]
plugins=libmenu.plugin.so	// Plugins - Komma getrennt [HIDE:1]
[logging]
loglevel=3			// <b>Loglevel</b> [OPTION:0|0,1|1,2|2,3|3,4|4]
				// [HTML:<p><script>show_title('Ausgabe')</script>]
show_sender=0			// Source.c [OPTION:1|ja,0|nein]
show_type=1			// Verbindungstyp [OPTION:1|ja,0|nein]
show_con=1			// Verbindungs-ID [OPTION:1|ja,0|nein]
show_acc=1			// Account-ID [OPTION:1|ja,0|nein]
show_source=0			// Quellrufnummer [OPTION:1|ja,0|nein]
show_destination=0		// Zielrufnummer [OPTION:1|ja,0|nein]
show_controller=0		// CAPI-Controller [OPTION:1|ja,0|nein]
show_plci=0			// PLCI [OPTION:1|ja,0|nein]
show_ncci=0			// NCCI [OPTION:1|ja,0|nein]
[audio]
conf_clockrate=8000		// Samplerate Konferenzbrücke [OPTION:8000|8000,11025|11025,16000|16000,22050|22050]
snd_clockrate=8000		// Samplerate Soundkarte [HIDE:1]
null_sound=0			// 1=Null-Sound, 0=Soundkarte [HIDE:1]
bidirectional_sound=0  		// 1=Bidirectional, 0=Unidirectional [HIDE:1]
snd_play=-1			// Sound-Device-ID Speaker, -1=auto [HIDE:1]
snd_rec=-1			// Sound-Device-ID Mic, -1=auto [HIDE:1]
snd_ec_tail=0			// Echo-Canceller Tail Length (Soundkarte, msec) [HIDE:1]
con_ec_tail=0			// Echo-Canceller Tail Length (Verbindungen, msec) [WIDTH:50px]
resampler_quality=2		// Resample-Quality [OPTION:0|High Quality,1|Middle Quality,2|Low Quality]
mixer_talkover=0		// Talkover an/aus [HIDE:1]
mixer_rx_volume=100		// Empfangslautstärke (0-200) [WIDTH:50px]
mixer_tx_volume=100		// Sendelautstärke (0-200) [WIDTH:50px]
earlyb3_ring=1			// Fake-Ring [OPTION:1|aktiviert,0|deaktiviert]
text2speech=/var/dtmfbox/script/espeak.sh(/var/dtmfbox/script/espeak.sh, "%text%", "%src_id%")	// Text2Speech Skriptaufruf (nicht ändern!) [HIDE:1]
[voip]
voip=1				// <b>VoIP</b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_VOIP_ACTIVE', 'voip_voip', '1')]
				// [HTML:<div ID='DIV_VOIP_ACTIVE'>]
voip_registrar=1		// Registrar-Modus [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_VOIP_REGISTRAR_MODE', 'voip_voip_registrar', '1')]
				// [HTML:<div ID='DIV_VOIP_REGISTRAR_MODE'>]
voip_max_clients=4		// Registrar-Modus: Max. Clients [OPTION:0|0,1|1,2|2,3|3,4|4,5|5,6|6,7|7,8|8,9|9,10|10]
voip_realm=fritz.box		// Registrar-Modus: Authentication-Realm [WIDTH:250px]
				// [HTML:</div><script>set_group('DIV_VOIP_REGISTRAR_MODE', 'voip_voip_registrar', '1')</script>]
voip_udp_port=5061		// SIP Port [WIDTH:50px]
voip_rtp_start=4000		// RTP/RTCP Start-Port [WIDTH:50px]
voip_rtp_max=4			// Max. Anzahl an RTP/RTCP Ports [OPTION:0|0,1|1,2|2,3|3,4|4,5|5,6|6,7|7,8|8,9|9,10|10,11|11,12|12,13|13,14|14,15|15,16|16,17|17,18|18,19|19,20|20]
voip_register_interval=3600	// Registrierungs-Intervall (in sec) [WIDTH:50px]
voip_keep_alive=180		// Keep-Alive alle X sec senden (0=aus) [WIDTH:50px]
voip_use_vad=0			// VAD (silence detection) [OPTION:1|aktiviert,0|deaktiviert]
voip_ip_addr=			// IP-Adresse des Interfaces (optional) [WIDTH:250px]
voip_stun=			// STUN-Server [WIDTH:250px]
voip_stun_port=3478		// STUN-Port [WIDTH:50px]
voip_ice=1			// ICE [OPTION:1|aktiviert,0|deaktiviert]
voip_nameserver=		// Nameserver (max. 4, Komma-getrennt) [WIDTH:250px]
voip_codecs=g711		// Codecs (g711, speex, gsm, Komma-getrennt) [WIDTH:250px]
voip_allow_unknown=0		// Ereignis auslösen, bei unbekannten Accounts? (nicht ändern!) [HIDE:1]
				// [HTML:</div><script>set_group('DIV_VOIP_ACTIVE', 'voip_voip', '1')</script>]
[capi]
capi_controller=1,4,3,5		// Listen CAPI-Controller. Komma getrennt
capi_int_prefix=		// Landesvorwahl (z.B. 0049) [WIDTH:50px]
capi_nat_prefix=		// Ortsvorwahl (z.B. 203) [WIDTH:50px]
capi_ulaw=0			// Alaw=0, Ulaw=1 (nicht ändern!) [HIDE:1]
capi_allow_unknown=0		// Ereignis auslösen, bei unbekannten Accounts? [HIDE:1]
[acc1]
active=1			// <b>Account</b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC1_ACTIVE', 'acc1_active', '1')]
				// [HTML:<div ID='DIV_ACC1_ACTIVE'>]
name=analog				// Name [WIDTH:250px]
number=unknown				// Rufnummer [WIDTH:250px]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC1_TYPE_CAPI', 'acc1_type', 'capi'); set_group('DIV_ACC1_TYPE_VOIP', 'acc1_type', 'voip')]
				// [HTML:<div ID='DIV_ACC1_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
capi_controller_out=4		// Standardcontroller (ausgehende Verbindung): [OPTION:1|1,2|2,3|3,4|4,5|5]
				// [HTML:</div><script>set_group('DIV_ACC1_TYPE_CAPI', 'acc1_type', 'capi')</script><div ID='DIV_ACC1_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
voip_registrar=			// Registrar-Server [WIDTH:250px]
voip_realm=			// Registrar-Realm (oder *) [WIDTH:250px]
voip_user=			// Username [WIDTH:250px]
voip_pass=			// Passwort [WIDTH:250px] [TYPE:password]
voip_do_not_register=0		// Registrieren [OPTION:0|ja,1|nein]
voip_proxy=			// (Optional) Proxy [WIDTH:250px]
voip_id=			// (Optional) ID [WIDTH:250px]
voip_contact=			// (Optional) Contact [WIDTH:250px]
				// [HTML:</div><script>set_group('DIV_ACC1_TYPE_VOIP', 'acc1_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=1		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC1_REGISTRAR', 'acc1_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC1_REGISTRAR'>]
registrar_user=analog			// Username [WIDTH:250px]
registrar_pass=sip2			// Passwort [WIDTH:250px] [TYPE:password]
				// [HTML:</div><br><script>set_group('DIV_ACC1_REGISTRAR', 'acc1_registrar_active', '1');show_title('Internes Menü')</script>]
menu_entry=menu:main		// Einstiegsmenü [WIDTH:250px]
menu_keycode=*610		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC1_ACTIVE', 'acc1_active', '1')</script>]
[acc2]
active=0			// <b>Account<b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC2_ACTIVE', 'acc2_active', '1')]
				// [HTML:<div ID='DIV_ACC2_ACTIVE'>]
name=				// Name [WIDTH:250px]
number=				// Rufnummer [WIDTH:250px]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC2_TYPE_CAPI', 'acc2_type', 'capi'); set_group('DIV_ACC2_TYPE_VOIP', 'acc2_type', 'voip')]
				// [HTML:<div ID='DIV_ACC2_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
capi_controller_out=1		// Standardcontroller (ausgehende Verbindung): [OPTION:1|1,2|2,3|3,4|4,5|5]
				// [HTML:</div><script>set_group('DIV_ACC2_TYPE_CAPI', 'acc2_type', 'capi')</script><div ID='DIV_ACC2_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
				// [HTML:</div><script>set_group('DIV_ACC2_TYPE_VOIP', 'acc2_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=0		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC2_REGISTRAR', 'acc2_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC2_REGISTRAR'>]
registrar_user=			// Username [WIDTH:250px]
registrar_pass=			// Passwort [WIDTH:250px] [TYPE:password]
				// [HTML:</div><br><script>set_group('DIV_ACC2_REGISTRAR', 'acc2_registrar_active', '1');show_title('Internes Menü')</script>]
menu_keycode=*611		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC2_ACTIVE', 'acc2_active', '1')</script>]
[acc3]
active=0			// <b>Account<b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC3_ACTIVE', 'acc3_active', '1')]
				// [HTML:<div ID='DIV_ACC3_ACTIVE'>]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC3_TYPE_CAPI', 'acc3_type', 'capi'); set_group('DIV_ACC3_TYPE_VOIP', 'acc3_type', 'voip')]
				// [HTML:<div ID='DIV_ACC3_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
				// [HTML:</div><script>set_group('DIV_ACC3_TYPE_CAPI', 'acc3_type', 'capi')</script><div ID='DIV_ACC3_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
				// [HTML:</div><script>set_group('DIV_ACC3_TYPE_VOIP', 'acc3_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=0		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC3_REGISTRAR', 'acc3_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC3_REGISTRAR'>]
				// [HTML:</div><br><script>set_group('DIV_ACC3_REGISTRAR', 'acc3_registrar_active', '1');show_title('Internes Menü')</script>]
menu_keycode=*612		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC3_ACTIVE', 'acc3_active', '1')</script>]
[acc4]
active=0			// <b>Account<b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC4_ACTIVE', 'acc4_active', '1')]
				// [HTML:<div ID='DIV_ACC4_ACTIVE'>]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC4_TYPE_CAPI', 'acc4_type', 'capi'); set_group('DIV_ACC4_TYPE_VOIP', 'acc4_type', 'voip')]
				// [HTML:<div ID='DIV_ACC4_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
				// [HTML:</div><script>set_group('DIV_ACC4_TYPE_CAPI', 'acc4_type', 'capi')</script><div ID='DIV_ACC4_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
				// [HTML:</div><script>set_group('DIV_ACC4_TYPE_VOIP', 'acc4_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=0		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC4_REGISTRAR', 'acc4_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC4_REGISTRAR'>]
				// [HTML:</div><br><script>set_group('DIV_ACC4_REGISTRAR', 'acc4_registrar_active', '1');show_title('Internes Menü')</script>]
menu_keycode=*613		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC4_ACTIVE', 'acc4_active', '1')</script>]
[acc5]
active=0			// <b>Account<b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC5_ACTIVE', 'acc5_active', '1')]
				// [HTML:<div ID='DIV_ACC5_ACTIVE'>]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC5_TYPE_CAPI', 'acc5_type', 'capi'); set_group('DIV_ACC5_TYPE_VOIP', 'acc5_type', 'voip')]
				// [HTML:<div ID='DIV_ACC5_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
				// [HTML:</div><script>set_group('DIV_ACC5_TYPE_CAPI', 'acc5_type', 'capi')</script><div ID='DIV_ACC5_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
				// [HTML:</div><script>set_group('DIV_ACC5_TYPE_VOIP', 'acc5_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=0		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC5_REGISTRAR', 'acc5_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC5_REGISTRAR'>]
				// [HTML:</div><br><script>set_group('DIV_ACC5_REGISTRAR', 'acc5_registrar_active', '1');show_title('Internes Menü')</script>]
menu_keycode=*614		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC5_ACTIVE', 'acc5_active', '1')</script>]
[acc6]
active=0			// <b>Account<b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC6_ACTIVE', 'acc6_active', '1')]
				// [HTML:<div ID='DIV_ACC6_ACTIVE'>]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC6_TYPE_CAPI', 'acc6_type', 'capi'); set_group('DIV_ACC6_TYPE_VOIP', 'acc6_type', 'voip')]
				// [HTML:<div ID='DIV_ACC6_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
				// [HTML:</div><script>set_group('DIV_ACC6_TYPE_CAPI', 'acc6_type', 'capi')</script><div ID='DIV_ACC6_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
				// [HTML:</div><script>set_group('DIV_ACC6_TYPE_VOIP', 'acc6_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=0		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC6_REGISTRAR', 'acc6_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC6_REGISTRAR'>]
				// [HTML:</div><br><script>set_group('DIV_ACC6_REGISTRAR', 'acc6_registrar_active', '1');show_title('Internes Menü')</script>]
menu_keycode=*615		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC6_ACTIVE', 'acc6_active', '1')</script>]
[acc7]
active=0			// <b>Account<b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC7_ACTIVE', 'acc7_active', '1')]
				// [HTML:<div ID='DIV_ACC7_ACTIVE'>]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC7_TYPE_CAPI', 'acc7_type', 'capi'); set_group('DIV_ACC7_TYPE_VOIP', 'acc7_type', 'voip')]
				// [HTML:<div ID='DIV_ACC7_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
				// [HTML:</div><script>set_group('DIV_ACC7_TYPE_CAPI', 'acc7_type', 'capi')</script><div ID='DIV_ACC7_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
				// [HTML:</div><script>set_group('DIV_ACC7_TYPE_VOIP', 'acc7_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=0		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC7_REGISTRAR', 'acc7_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC7_REGISTRAR'>]
				// [HTML:</div><br><script>set_group('DIV_ACC7_REGISTRAR', 'acc7_registrar_active', '1');show_title('Internes Menü')</script>]
menu_keycode=*616		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC7_ACTIVE', 'acc7_active', '1')</script>]
[acc8]
active=0			// <b>Account<b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC8_ACTIVE', 'acc8_active', '1')]
				// [HTML:<div ID='DIV_ACC8_ACTIVE'>]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC8_TYPE_CAPI', 'acc8_type', 'capi'); set_group('DIV_ACC8_TYPE_VOIP', 'acc8_type', 'voip')]
				// [HTML:<div ID='DIV_ACC8_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
				// [HTML:</div><script>set_group('DIV_ACC8_TYPE_CAPI', 'acc8_type', 'capi')</script><div ID='DIV_ACC8_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
				// [HTML:</div><script>set_group('DIV_ACC8_TYPE_VOIP', 'acc8_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=0		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC8_REGISTRAR', 'acc8_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC8_REGISTRAR'>]
				// [HTML:</div><br><script>set_group('DIV_ACC8_REGISTRAR', 'acc8_registrar_active', '1');show_title('Internes Menü')</script>]
menu_keycode=*617		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC8_ACTIVE', 'acc8_active', '1')</script>]
[acc9]
active=0			// <b>Account<b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC9_ACTIVE', 'acc9_active', '1')]
				// [HTML:<div ID='DIV_ACC9_ACTIVE'>]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC9_TYPE_CAPI', 'acc9_type', 'capi'); set_group('DIV_ACC9_TYPE_VOIP', 'acc9_type', 'voip')]
				// [HTML:<div ID='DIV_ACC9_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
				// [HTML:</div><script>set_group('DIV_ACC9_TYPE_CAPI', 'acc9_type', 'capi')</script><div ID='DIV_ACC9_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
				// [HTML:</div><script>set_group('DIV_ACC9_TYPE_VOIP', 'acc9_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=0		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC9_REGISTRAR', 'acc9_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC9_REGISTRAR'>]
				// [HTML:</div><br><script>set_group('DIV_ACC9_REGISTRAR', 'acc9_registrar_active', '1');show_title('Internes Menü')</script>]
menu_keycode=*618		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC9_ACTIVE', 'acc9_active', '1')</script>]
[acc10]
active=0			// <b>Account<b> [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC10_ACTIVE', 'acc10_active', '1')]
				// [HTML:<div ID='DIV_ACC10_ACTIVE'>]
type=capi			// Account-Typ [OPTION:capi|capi,voip|voip] [ONCHANGE:set_group('DIV_ACC10_TYPE_CAPI', 'acc10_type', 'capi'); set_group('DIV_ACC10_TYPE_VOIP', 'acc10_type', 'voip')]
				// [HTML:<div ID='DIV_ACC10_TYPE_CAPI'><br><script>show_title('CAPI')</script>]
				// [HTML:</div><script>set_group('DIV_ACC10_TYPE_CAPI', 'acc10_type', 'capi')</script><div ID='DIV_ACC10_TYPE_VOIP'><br><script>show_title('VoIP')</script>]
				// [HTML:</div><script>set_group('DIV_ACC10_TYPE_VOIP', 'acc10_type', 'voip')</script><br><script>show_title('Registrar-Login')</script>]
registrar_active=0		// Registrar-Login [OPTION:1|aktiviert,0|deaktiviert] [ONCHANGE:set_group('DIV_ACC10_REGISTRAR', 'acc10_registrar_active', '1')]
				// [HTML:<div ID='DIV_ACC10_REGISTRAR'>]
				// [HTML:</div><br><script>set_group('DIV_ACC10_REGISTRAR', 'acc10_registrar_active', '1');show_title('Internes Menü')</script>]
menu_keycode=*619		// Interne Kurzwahl [WIDTH:50px]
				// [HTML:</div><script>set_group('DIV_ACC10_ACTIVE', 'acc10_active', '1')</script>]
Wenn ich nun testweise mit meinem X-Lite Softphone rauswähle (direkt an der FB angemeldet) zeigt die FB (DTMFBOX) folgendes im Log und nach ca. 20 Sekunden bekomme ich am Softphone die Ansage „The Person you are calling is unavailable“ – Die Ansage muss von der FB kommen, da das GSM Gateway keinerlei Anstalten macht zu wählen.:
10.0.0.181 ist mein Softphone Client. Die FB hat die 10.0.0.12
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2009.04.05 23:15:36 =~=~=~=~=~=~=~=~=~=~=~=
Start dtmfbox ...
 dtmfbox 0.5.0
 23:15:49 dtmfbox 0.5.0
 23:15:49 PJSIP 1.0.1
 23:15:49 Init VoIP ...
 23:15:49 Resolve local IP ...
 23:15:49 Use IP: 10.0.0.12
 23:15:49 UDP server listening on port 5061
 23:15:49 Conference bridge created [8000/16/1]
 23:15:49 Allocate 11 connections with 4 RTP/RTCP transports
 23:15:49 RTP/RTCP: 10.0.0.12:4000-4001
 23:15:49 RTP/RTCP: 10.0.0.12:4002-4003
 23:15:49 RTP/RTCP: 10.0.0.12:4004-4005
 23:15:49 RTP/RTCP: 10.0.0.12:4006-4007
 23:15:49 RTP/RTCP media transport created
 23:15:49 Start VoIP listen loop ...
 23:15:49 VoIP initialized!
 23:15:49 Init CAPI ...
 23:15:49 CAPI controller: 4
 23:15:49 Found controller #1 with 2 B-channel(s)
 23:15:49 Found controller #2 with 2 B-channel(s)
 23:15:49 Found controller #3 with 1 B-channel(s)
 23:15:49 Found controller #4 with 2 B-channel(s)
 23:15:49 CAPI registered (ApplID: 5, B-Channels: 7)
 23:15:49 Build a-law/pcm table buffer
 23:15:52 CAPI initialized!
 23:15:52 [plugin.menu] Loading /var/dtmfbox//menu.cfg ...
 23:15:52 [plugin.menu] action:1_ctrl5reject loaded (5 entries)
 23:15:52 [plugin.menu] action:2_action_wrapper loaded (1 entries)
 23:15:52 [plugin.menu] lib:speak loaded (2 entries)
 23:15:52 [plugin.menu] menu:am loaded (2 entries)
 23:15:52 [plugin.menu] menu:am_delete loaded (3 entries)
 23:15:52 [plugin.menu] menu:am_on_off loaded (2 entries)
 23:15:52 [plugin.menu] menu:am_setup loaded (4 entries)
 23:15:52 [plugin.menu] menu:anticallcenter loaded (1 entries)
 23:15:52 [plugin.menu] menu:callthrough_account loaded (13 entries)
 23:15:52 [plugin.menu] menu:callthrough_number loaded (3 entries)
 23:15:52 [plugin.menu] menu:callthrough_pin loaded (3 entries)
 23:15:52 [plugin.menu] menu:dtmf_commands loaded (7 entries)
 23:15:52 [plugin.menu] menu:main loaded (6 entries)
 23:15:52 [plugin.menu] menu:misc loaded (6 entries)
 23:15:52 [plugin.menu] menu:misc_checkmaild loaded (5 entries)
 23:15:52 [plugin.menu] menu:misc_fb loaded (5 entries)
 23:15:52 [plugin.menu] menu:misc_radio loaded (11 entries)
 23:15:52 [plugin.menu] menu:misc_weather loaded (3 entries)
 23:15:52 [plugin.menu] script:action_anticallcenter loaded (1 entries)
 23:15:52 [plugin.menu] script:action_ctrl5 loaded (1 entries)
 23:15:52 [plugin.menu] script:action_wrapper loaded (1 entries)
 23:15:52 [plugin.menu] script:am_admin loaded (1 entries)
 23:15:52 [plugin.menu] script:am_setup loaded (1 entries)
 23:15:52 [plugin.menu] script:callthrough loaded (1 entries)
 23:15:52 [plugin.menu] script:misc_checkmaild loaded (1 entries)
 23:15:52 [plugin.menu] script:misc_fb loaded (1 entries)
 23:15:52 [plugin.menu] script:misc_radio loaded (1 entries)
 23:15:52 [plugin.menu] script:misc_weather loaded (1 entries)
 23:15:52 [plugin.menu] 28 entries loaded!
 23:15:52 [plugin.menu] Initialized!
 23:15:52 #1 - Plugin "libmenu.plugin.so" loaded!
 23:15:52 (0x3ff) - Listen to CAPI controller 1 ...
 23:15:52 (0x3ff) - Listen to CAPI controller 4 ...
 23:15:52 (0x3ff) - Listen to CAPI controller 3 ...
 23:15:52 (0x3ff) - Listen to CAPI controller 5 ...
 23:15:52 Start CAPI listen loop ...
 23:15:52 [ctrl=1] CNF: CAPI_LISTEN
 23:15:52 [ctrl=4] CNF: CAPI_LISTEN
 23:15:52 [ctrl=3] CNF: CAPI_LISTEN
 23:15:52 [ctrl=5] CNF: CAPI_LISTEN
 23:15:52 CAPI 0x2002 - Illegal Controller / PLCI / NCCI
 23:16:01 RX-REQUEST 1113 bytes Request msg INVITE/cseq=1 (rdata0x529604) from UDP 10.0.0.181:12796
 23:16:01
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 10.0.0.181:12796;branch=z9hG4bK-d8754z-ec73281cf606200c-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:[email protected]:12796>
To: "0160xxx61xxx"<sip:[email protected]>
Call-ID: OTQxMmY3Y2VmYzIyZmNhYzhiYzgwMzgzZjA3ODgyNmI.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
Content-Type: application/sdp
User-Agent: X-Lite release 1100l stamp 47546
Content-Length: 567
v=0
o=- 1 2 IN IP4 10.0.0.181
s=CounterPath X-Lite 3.0
c=IN IP4 10.0.0.181
t=0 0
m=audio 54748 RTP/AVP 107 119 100 106 0 105 98 8 3 101
a=alt:1 4 : Y+gbZHXK zyiN1xYR 10.0.0.181 54748
a=alt:2 3 : qiVbgLVs /6vNSfHt 192.168.3.1 54748
a=alt:3 2 : l/R3itn5 1FpfLcee 192.168.204.1 54748
a=alt:4 1 : d4hZKIX+ NFV2Z1+X 192.168.208.1 54748
a=fmtp:101 0-15
a=rtpmap:107 BV32/16000
a=rtpmap:119 BV32-FEC/16000
a=rtpmap:100 SPEEX/16000
a=rtpmap:106 SPEEX-FEC/16000
a=rtpmap:105 SPEEX-FEC/8000
a=rtpmap:98 iLBC/8000
a=rtpmap:101 telephone-event/8000
a=sendrecv
 23:16:01 Incoming call for unknown account [sip:[email protected] -> sip:[email protected]] (ignoring)
 23:16:02 RX-REQUEST 1113 bytes Request msg INVITE/cseq=1 (rdata0x529604) from UDP 10.0.0.181:12796
 23:16:02
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 567
v=0
c=IN IP4 10.0.0.181
t=0 0
a=fmtp:101 0-15
a=sendrecv
 23:16:02 Incoming call for unknown account [sip:[email protected] -> sip:[email protected]] (ignoring)
 23:16:03 RX-REQUEST 1113 bytes Request msg INVITE/cseq=1 (rdata0x529604) from UDP 10.0.0.181:12796
 23:16:03
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 567
v=0
c=IN IP4 10.0.0.181
t=0 0
a=fmtp:101 0-15
a=sendrecv
 23:16:03 Incoming call for unknown account [sip:[email protected] -> sip:[email protected]] (ignoring)
 23:16:05 RX-REQUEST 1113 bytes Request msg INVITE/cseq=1 (rdata0x529604) from UDP 10.0.0.181:12796
 23:16:05
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 567
v=0
c=IN IP4 10.0.0.181
t=0 0
a=fmtp:101 0-15
a=sendrecv
 23:16:05 Incoming call for unknown account [sip:[email protected] -> sip:[email protected]] (ignoring)
 23:16:09 RX-REQUEST 1113 bytes Request msg INVITE/cseq=1 (rdata0x529604) from UDP 10.0.0.181:12796
 23:16:09
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 567
v=0
c=IN IP4 10.0.0.181
t=0 0
a=fmtp:101 0-15
a=sendrecv
 23:16:09 Incoming call for unknown account [sip:[email protected] -> sip:[email protected]] (ignoring)
 23:16:17 RX-REQUEST 1113 bytes Request msg INVITE/cseq=1 (rdata0x529604) from UDP 10.0.0.181:12796
 23:16:17
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 567
v=0
c=IN IP4 10.0.0.181
t=0 0
a=fmtp:101 0-15
a=sendrecv
 23:16:17 Incoming call for unknown account [sip:[email protected] -> sip:[email protected]] (ignoring)
 23:16:33 RX-REQUEST 1113 bytes Request msg INVITE/cseq=1 (rdata0x529604) from UDP 10.0.0.181:12796
 23:16:33
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 567
v=0
c=IN IP4 10.0.0.181
t=0 0
a=fmtp:101 0-15
a=sendrecv
 23:16:33 Incoming call for unknown account [sip:[email protected] -> sip:[email protected]] (ignoring)
Kann mir dort jemand helfen? Die Doku betreffend Bereitstellung von Analog/ISDN per SIP ist ja nun doch leider begrenzt :-)
Vielen Dank!
Hallo MeTRiX,
im Log tauch nur das INVITE auf, aber keine Registrierung (der Client meldet sich anscheinend garnicht an der dtmfbox an). Das sollte im Webinterface unter "Status" eigentlich zu sehen sein (also da dürfte kein Client stehen ;)).
Welchen Registrar hast du in X-Lite eingetragen (10.0.0.12:5061)? Ist "Register with domain and receive incoming calls" aktiviert? Presence auf "Presence Agent" gestellt?
Auch unter "Topology" einen Port-Range fest vorgeben!
jap, genauso ist er eingestellt und auch im Status angemeldet:
Accounts
 (1) [CAPI] unknown         -                 - Pending!
Verbindungen
Clients
 (1) 10.0.0.181:60338                              - 1 account(s), 0 min
Kannst du ein Log von X-Lite posten? Hab die gleiche Version.
Vom Start des Calls bis zum Auflegen nach der Ansage:
Time | Type | Subsystem | Message | Function | Location
09-04-09 20:35:55.878 | Info | USB Devices | "0012DA00" | DBLOGGER
09-04-09 20:35:55.878 | Info | USB Devices | "0012D9F0" | DBLOGGER
09-04-09 20:35:55.878 | Info | USB Devices | "0012D9E8" | DBLOGGER
09-04-09 20:35:55.878 | Info | USB Devices | "0012D9E0" | DBLOGGER
09-04-09 20:35:55.878 | Info | USB Devices | "0012D5E8" | DBLOGGER
09-04-09 20:35:55.882 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.882 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.882 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.882 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.882 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.883 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.888 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.888 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.888 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.888 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.888 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.890 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.895 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.895 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.895 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.895 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.895 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.896 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.900 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.900 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.900 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.900 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.900 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.901 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.906 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.906 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.906 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.906 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.906 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.907 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.911 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.911 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.911 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.911 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.911 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.912 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.915 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.915 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.915 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.915 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.915 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.917 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.920 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.920 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.920 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.920 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.920 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.922 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.925 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.925 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.925 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.925 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.925 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.926 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.927 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.930 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.930 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.930 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.930 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.930 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.931 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.935 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.935 | Info | USB Devices | "0012D5D8" | DBLOGGER
09-04-09 20:35:55.935 | Info | USB Devices | "0012D5D0" | DBLOGGER
09-04-09 20:35:55.935 | Info | USB Devices | "0012D5C8" | DBLOGGER
09-04-09 20:35:55.935 | Info | USB Devices | "0012D5C0" | DBLOGGER
09-04-09 20:35:55.936 | Info | USB Devices | "0012D5E0" | DBLOGGER
09-04-09 20:35:55.936 | Info | USB Devices | "0012D9E8" | DBLOGGER
09-04-09 20:35:55.936 | Info | USB Devices | "0012DA00" | DBLOGGER
09-04-09 20:35:55.936 | Info | USB Devices | "0012D9F8" | DBLOGGER
09-04-09 20:35:57.066 | Info | GUI | "User Action:  (keypad_0)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.066 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:57.290 | Info | Audio | "Device supports 8000 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:35:57.290 | Info | Audio | "Device supports 16000 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:35:57.290 | Info | Audio | "Device supports 22050 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:35:57.290 | Info | Audio | "Device supports 44100 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:35:57.290 | Info | Audio | "Device supports 48000 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:35:57.431 | Info | Audio | "Audio started, where instance ID=361, Out: Lautsprecher / Kopfhörer (Sigma" | sua::CAudioManager::StartAudio
09-04-09 20:35:57.431 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=373 clip={2B3FE630-54CF-47EA-81F6-0C0EB4240FD6}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:57.431 | Info | Audio | "Evaluating audio 0 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.431 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.432 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.433 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.434 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.436 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.449 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.459 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.462 | Info | GUI | "User Action:  (keypad_0)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.462 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:57.462 | Info | GUI | "User Action:  (keypad_1)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.462 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:57.462 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=379 clip={492EA19D-19DE-4478-AFAE-3F950F1FD68A}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:57.464 | Info | GUI | "User Action:  (keypad_1)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.464 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:57.465 | Info | GUI | "User Action:  (keypad_6)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.465 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:57.465 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=383 clip={75799B0A-8B62-4AD5-8A9E-49D48502A7EB}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:57.469 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.474 | Info | GUI | "User Action:  (keypad_6)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.474 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:57.479 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.489 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.499 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.509 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.519 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.529 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.539 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.549 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.554 | Info | GUI | "User Action:  (keypad_0)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.554 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:57.554 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=387 clip={2B3FE630-54CF-47EA-81F6-0C0EB4240FD6}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:57.559 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.569 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.579 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.589 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.599 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.609 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.619 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.629 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.634 | Info | GUI | "User Action:  (keypad_0)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.634 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:57.639 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.649 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.659 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.669 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.679 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.689 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.699 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.709 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.719 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.729 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.739 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.749 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.759 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.769 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.779 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.789 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.799 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.809 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.819 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.829 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.839 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.849 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.850 | Info | GUI | "User Action:  (keypad_9)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.850 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:57.850 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=391 clip={F35CA2C3-21C5-400A-A7D8-01043BFB585C}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:57.859 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.869 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.879 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.889 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.899 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.909 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.914 | Info | GUI | "User Action:  (keypad_9)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:57.914 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:57.919 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.929 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.939 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.949 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.959 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.969 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.979 | Info | Audio | "Evaluating audio 501 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.989 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:57.999 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.009 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.019 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.026 | Info | GUI | "User Action:  (keypad_8)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.026 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:58.026 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=395 clip={6B514821-EC67-402A-BEB8-27DBE5FB957E}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:58.029 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.039 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.049 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.059 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.069 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.079 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.089 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.090 | Info | GUI | "User Action:  (keypad_8)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.090 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:58.099 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.109 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.119 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.129 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.139 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.149 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.159 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.169 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.179 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.189 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.199 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.209 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.219 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.229 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.239 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.249 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.259 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.266 | Info | GUI | "User Action:  (keypad_7)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.266 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:58.266 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=399 clip={03067F5B-083B-4CCF-91EC-A64EC41E918D}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:58.269 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.279 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.289 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.299 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.309 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.319 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.329 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.330 | Info | GUI | "User Action:  (keypad_7)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.330 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:58.339 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.349 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.359 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.369 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.379 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.389 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.399 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.409 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.419 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.429 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.439 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.449 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.459 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.469 | Info | Audio | "Evaluating audio 497 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.475 | Info | GUI | "User Action:  (keypad_6)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.475 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:58.475 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=403 clip={75799B0A-8B62-4AD5-8A9E-49D48502A7EB}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:58.479 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.489 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.499 | Info | Audio | "Evaluating audio 497 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.509 | Info | Audio | "Evaluating audio 498 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.519 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.529 | Info | Audio | "Evaluating audio 499 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.539 | Info | GUI | "User Action:  (keypad_6)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.539 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:58.540 | Info | Audio | "Evaluating audio 493 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.549 | Info | Audio | "Evaluating audio 497 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.559 | Info | Audio | "Evaluating audio 497 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.569 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.579 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.589 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.599 | Info | Audio | "Evaluating audio 500 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.608 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.618 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.628 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.638 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.648 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.658 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.668 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.678 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.688 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.698 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.708 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.718 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.728 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.738 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.748 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.758 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.768 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.778 | Info | GUI | "User Action:  (keypad_1)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.778 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:58.778 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.778 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=407 clip={492EA19D-19DE-4478-AFAE-3F950F1FD68A}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:58.788 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.798 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.808 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.818 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.826 | Info | GUI | "User Action:  (keypad_1)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.826 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:58.828 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.838 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.848 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.858 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.868 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.878 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.888 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.898 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.908 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.914 | Info | GUI | "User Action:  (keypad_1)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.914 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:58.914 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=411 clip={492EA19D-19DE-4478-AFAE-3F950F1FD68A}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:58.918 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.928 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.938 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.948 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.958 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.968 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.978 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.986 | Info | GUI | "User Action:  (keypad_1)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:58.986 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:58.988 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:58.998 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.008 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.018 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.028 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.038 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.048 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.058 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.068 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.078 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.088 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.098 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.108 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.118 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.128 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.138 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.148 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.158 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.168 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.178 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.188 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.198 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.202 | Info | GUI | "User Action:  (keypad_0)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:59.202 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:59.202 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=415 clip={2B3FE630-54CF-47EA-81F6-0C0EB4240FD6}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:59.208 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.218 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.228 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.238 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.248 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.258 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.266 | Info | GUI | "User Action:  (keypad_0)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:59.266 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:59.268 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.278 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.288 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.298 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.308 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.318 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.328 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.338 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.346 | Info | GUI | "User Action:  (keypad_0)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:59.346 | Info | AbstractPhone | "StartDTMFTone" | AbPhone::CAbstractPhone::StartDtmfTone
09-04-09 20:35:59.346 | Info | Audio | "Outgoing stream (363): Playing override clip where instance=419 clip={2B3FE630-54CF-47EA-81F6-0C0EB4240FD6}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:35:59.348 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.358 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.368 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.378 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.388 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.398 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.408 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.418 | Info | GUI | "User Action:  (keypad_0)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:35:59.418 | Info | AbstractPhone | "StopDtmfTone" | AbPhone::CAbstractPhone::StopDtmfTone
09-04-09 20:35:59.418 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.428 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.438 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.448 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.458 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.468 | Info | Audio | "Evaluating audio 516 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.478 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.488 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.498 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.508 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.518 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.528 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.538 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.548 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.558 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.568 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.572 | Info | AbstractPhone | "[[email protected]]::MakeCallRequest : sip:[email protected]" | AbPhone::CAccount::MakeCallRequest
09-04-09 20:35:59.572 | Info | AbstractPhone | "OutgoingCallRequest: Created" | AbPhone::COutgoingCallRequest::COutgoingCallRequest
09-04-09 20:35:59.572 | Info | Media | " [session-ID:429]" | sua::CMediaSession::CMediaSession
09-04-09 20:35:59.575 | Info | Audio | "Not using codec dvi4 due to insufficient upstream bandwidth" | sua::CAudioCodecSelectionManager::LoadAudioCodecList
09-04-09 20:35:59.575 | Info | Audio | "Not using codec dvi4_wb due to insufficient upstream bandwidth" | sua::CAudioCodecSelectionManager::LoadAudioCodecList
09-04-09 20:35:59.575 | Info | Audio | "Not using codec l16_wb due to insufficient upstream bandwidth" | sua::CAudioCodecSelectionManager::LoadAudioCodecList
09-04-09 20:35:59.575 | Info | Audio | "Not using codec speex due to insufficient upstream bandwidth" | sua::CAudioCodecSelectionManager::LoadAudioCodecList
09-04-09 20:35:59.578 | Info | Audio | "Not using codec dvi4 due to insufficient upstream bandwidth" | sua::CAudioCodecSelectionManager::LoadAudioCodecList
09-04-09 20:35:59.578 | Info | Audio | "Not using codec dvi4_wb due to insufficient upstream bandwidth" | sua::CAudioCodecSelectionManager::LoadAudioCodecList
09-04-09 20:35:59.578 | Info | Audio | "Not using codec l16_wb due to insufficient upstream bandwidth" | sua::CAudioCodecSelectionManager::LoadAudioCodecList
09-04-09 20:35:59.578 | Info | Audio | "Not using codec speex due to insufficient upstream bandwidth" | sua::CAudioCodecSelectionManager::LoadAudioCodecList
09-04-09 20:35:59.578 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.580 | Info | STUN | "ICE: Server registration: , username=Hxa5SWbU, password=vCFZtoLS" | sua::CSTUNClient::RegisterForIncomingRequests
09-04-09 20:35:59.580 | Info | STUN | "ICE: Server registration: , username=mOmPIcTD, password=X1Uj3u2o" | sua::CSTUNClient::RegisterForIncomingRequests
09-04-09 20:35:59.580 | Info | STUN | "ICE: Server registration: , username=Ap4r31Hv, password=t6+pEbMP" | sua::CSTUNClient::RegisterForIncomingRequests
09-04-09 20:35:59.580 | Info | STUN | "ICE: Server registration: , username=jJ7s4SR1, password=zYr5eCXH" | sua::CSTUNClient::RegisterForIncomingRequests
09-04-09 20:35:59.580 | Info | RTP | "ICE: The following My Addresses have been collected: Default RTP: 10.0.0.181:59346; Default RTCP: 10.0.0.181:59347; 1. RTP: 10.0.0.181:59346,un=Hxa5SWbU,p= vCFZtoLS; 1. RTCP: 10.0.0.181:59347,un=Hxa5SWbU,p= vCFZtoLS; 2. RTP: 192.168.3.1:59346,un=mOmPIcTD,p= X1Uj3u2o; 2. RTCP: 192.168.3.1:59347,un=mOmPIcTD,p= X1Uj3u2o; 3. RTP: 192.168.204.1:59346,un=Ap4r31Hv,p= t6+pEbMP; 3. RTCP: 192.168.204.1:59347,un=Ap4r31Hv,p= t6+pEbMP; 4. RTP: 192.168.208.1:59346,un=jJ7s4SR1,p= zYr5eCXH; 4. RTCP: 192.168.208.1:59347,un=jJ7s4SR1,p= zYr5eCXH; " | sua::CICEMyAddresses::LogMyAddressesCollection
09-04-09 20:35:59.588 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.598 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.608 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.618 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.628 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.638 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.648 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.656 | Info | RESIP:DUM | "Got: SipResp: 100 tid=a055111cdf45dc43 cseq=INVITE / 1 from(wire)" |
09-04-09 20:35:59.658 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.658 | Info | RESIP:DUM | "Got: SipResp: 180 tid=a055111cdf45dc43 cseq=INVITE [email protected]:5061 / 1 from(wire)" |
09-04-09 20:35:59.659 | Info | RESIP:DUM | "Transition UAC_Start -> UAC_Early" |
09-04-09 20:35:59.659 | Info | CCM | "[UAC][state:ECallState_Initial][sdp-state:ESDPOfferSent] <- [event:onNewSession (UAC)] [[email protected] -> [email protected]]" | sua::CSIPCall::PreProcessIncomingEvent
09-04-09 20:35:59.659 | Info | RESIP:DUM | "UAC_Early: startStaleCallTimer" |
09-04-09 20:35:59.659 | Info | CCM | "[UAC][state:EUACNew_Initial][sdp-state:ESDPOfferSent] <- [event:onProvisional] [[email protected] -> [email protected]]" | sua::CSIPCall::PreProcessIncomingEvent
09-04-09 20:35:59.659 | Info | CCM | "[UAC][state:EUACNew_Initial][sdp-state:ESDPOfferSent] <- [event:AcceptSIPCallCreated] [[email protected] -> [email protected]]" | sua::CSIPCall::PreProcessIncomingEvent
09-04-09 20:35:59.659 | Info | Media | " [session-ID:458]" | sua::CMediaSession::CMediaSession
09-04-09 20:35:59.659 | Info | AbstractPhone | "SetEventSink" | AbPhone::CCall::SetEventSink
09-04-09 20:35:59.668 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.678 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.688 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.698 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.708 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.718 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.728 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.738 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.748 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.758 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.768 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.778 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.788 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.798 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.808 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.818 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.828 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.838 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.848 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.858 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.868 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.878 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.888 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.898 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.908 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.918 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.928 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.938 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.948 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.958 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.968 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.978 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.988 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:35:59.998 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.008 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.018 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.028 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.038 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.048 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.058 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.068 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.078 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.088 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.098 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.108 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.118 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.128 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.138 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.148 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.158 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.168 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.178 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.188 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.198 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.208 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.218 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.228 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.238 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.248 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.258 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.268 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.278 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.288 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.298 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.308 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.318 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.328 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.338 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.348 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.358 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.368 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.378 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.388 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.398 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.408 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.418 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.428 | Info | Audio | "Evaluating audio 515 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.438 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.448 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.458 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.468 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.478 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.488 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.498 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.508 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.518 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.528 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.538 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.548 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.558 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.568 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.578 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.588 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.598 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.608 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.618 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.628 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.638 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.648 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.658 | Info | Audio | "Evaluating audio 514 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.668 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.678 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.688 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.698 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.708 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.718 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.729 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.738 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.748 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.758 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.768 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.778 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.788 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.798 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.808 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.818 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.828 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.838 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.848 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.859 | Info | Audio | "Evaluating audio 506 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.868 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.878 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.888 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.898 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.908 | Info | USB Devices | "First attempt to connect device." | cpsi::CPolycomUSB::Connect
09-04-09 20:36:00.908 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.909 | Info | USB Devices | "Failed to create GobiCtrl object." | cpsi::CPolycomUSB::Connect
09-04-09 20:36:00.918 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.928 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.938 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.948 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.958 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.968 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.978 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.988 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:00.998 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.008 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.018 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.028 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.038 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.048 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.058 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.068 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.079 | Info | Audio | "Evaluating audio 503 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.088 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.098 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.108 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.118 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.128 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.138 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.148 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.158 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.169 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.178 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.188 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.198 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.208 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.218 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.228 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.238 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.248 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.258 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.268 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.278 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.288 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.298 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.309 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.318 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.328 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.338 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.348 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.358 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.368 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.378 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.388 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.399 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.408 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.418 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.428 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.438 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.448 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.459 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.469 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.478 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.489 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.498 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.509 | Info | Audio | "Evaluating audio 506 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.519 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.529 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.539 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.549 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.559 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.568 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.579 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.589 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.599 | Info | Audio | "Evaluating audio 506 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.609 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.619 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.629 | Info | Audio | "Evaluating audio 505 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.639 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.648 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.658 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.668 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.678 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.688 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.698 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.709 | Info | Audio | "Evaluating audio 507 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.719 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.729 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.740 | Info | Audio | "Evaluating audio 493 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.748 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.758 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.768 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.778 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.788 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.800 | Info | Audio | "Evaluating audio 483 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.808 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.818 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.828 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.838 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.848 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.858 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.868 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.878 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.888 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.898 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.908 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.918 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.928 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.939 | Info | Audio | "Evaluating audio 507 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.949 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.959 | Info | Audio | "Evaluating audio 508 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.968 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.978 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.988 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:01.998 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.008 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.018 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.028 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.038 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.048 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.058 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.068 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.078 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.088 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.098 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.108 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.118 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.128 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.138 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.148 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.158 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.168 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.178 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.188 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.198 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.208 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.218 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.228 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.238 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.248 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.258 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.268 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.278 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.288 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.298 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.308 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.318 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.328 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.338 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.348 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.358 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.368 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.378 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.388 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.398 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.408 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.418 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.428 | Info | Audio | "Evaluating audio 513 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.438 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.448 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.458 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.468 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.478 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.488 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.498 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.508 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.518 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.528 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.538 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.548 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.558 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.568 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.578 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.588 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.598 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.608 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.618 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.628 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.638 | Info | Audio | "Evaluating audio 509 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.648 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.658 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.668 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.678 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.688 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.698 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.708 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.718 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.728 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.738 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.748 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.758 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.768 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.778 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.788 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.798 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.808 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.818 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.828 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.838 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.848 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.858 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.868 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.878 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.888 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.898 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.908 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.918 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.928 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.938 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.948 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.958 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.968 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.978 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.988 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:02.998 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.008 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.018 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.028 | Info | Audio | "Evaluating audio 511 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.038 | Info | Audio | "Evaluating audio 510 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.048 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.058 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.068 | Info | Audio | "Evaluating audio 512 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.083 | Info | Audio | "Evaluating audio 430 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.088 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.098 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.108 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.118 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.128 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.138 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.148 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.158 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.168 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.178 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.188 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.198 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.208 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.218 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.228 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.238 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.248 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.258 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.268 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.278 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.288 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.298 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.308 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.318 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.328 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.338 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.348 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.358 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.368 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.378 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.388 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.398 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.408 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.418 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.428 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.438 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.448 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.458 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.468 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.478 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.488 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.498 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.508 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.518 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.528 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.538 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.548 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.558 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.568 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.578 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.588 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.598 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.608 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.618 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.628 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.638 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.648 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.658 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.668 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.678 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.688 | Info | Audio | "Evaluating audio 672 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.698 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.708 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.718 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.728 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.738 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.748 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.758 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.768 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.778 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.788 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.798 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.808 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.818 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.828 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.838 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.848 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.858 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.868 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.878 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.888 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.898 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.908 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.918 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.928 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.938 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.948 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.958 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.968 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.978 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.988 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:03.998 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.008 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.018 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.028 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.038 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.048 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.058 | Info | Audio | "Evaluating audio 671 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.069 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.079 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.089 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.098 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.109 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.119 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.129 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.139 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.149 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.159 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.169 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.178 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.188 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.199 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.209 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.219 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.228 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.239 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.249 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.258 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.269 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.278 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.288 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.299 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.309 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.319 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.329 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.339 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.349 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.359 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.369 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.379 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.389 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.399 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.409 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.419 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.429 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.439 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.449 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.459 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.469 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.479 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.489 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.499 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.509 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.519 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.529 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.539 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.549 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.559 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.569 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.579 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.589 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.599 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.609 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.619 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.629 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.639 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.649 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.659 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.669 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.679 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.689 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.699 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.709 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.719 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.729 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.739 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.749 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.759 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.769 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.779 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.789 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.799 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.809 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.819 | Info | Audio | "Evaluating audio 670 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.829 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.839 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.849 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.859 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.869 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.879 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.889 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.899 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.909 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.919 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.929 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.939 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.949 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.959 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.969 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.979 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.989 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:04.999 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.009 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.019 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.029 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.039 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.049 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.059 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.069 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.079 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.089 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.099 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.109 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.119 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.129 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.139 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.149 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.159 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.169 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.179 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.189 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.199 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.209 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.219 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.229 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.239 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.249 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.259 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.269 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.279 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.289 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.299 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.309 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.319 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.329 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.339 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.349 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.359 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.369 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.379 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.389 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.399 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.409 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.419 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.429 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.439 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.449 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.459 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.469 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.479 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.489 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.499 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.509 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.519 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.529 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.539 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.549 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.559 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.569 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.579 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.589 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.599 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.609 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.619 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.629 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.639 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.649 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.659 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.669 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.679 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.689 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.699 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.709 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.719 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.729 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.739 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.749 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.759 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.769 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.779 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.789 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.799 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.809 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.819 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.829 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.839 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.849 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.859 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.869 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.879 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.889 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.899 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.909 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.919 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.929 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.939 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.949 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.959 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.969 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.979 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.989 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:05.999 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.009 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.019 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.029 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.039 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.049 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.059 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.069 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.079 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.089 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.099 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.109 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.119 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.129 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.139 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.149 | Info | Audio | "Evaluating audio 662 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.159 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.169 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.179 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.189 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.199 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.209 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.219 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.229 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.239 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.249 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.259 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.269 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.279 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.289 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.299 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.309 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.319 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.329 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.339 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.349 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.359 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.369 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.379 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.389 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.399 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.409 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.419 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.429 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.439 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.449 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.459 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.469 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.479 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.489 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.499 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.509 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.519 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.529 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.539 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.549 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.559 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.569 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.579 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.589 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.599 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.609 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.619 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.629 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.639 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.649 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.659 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.669 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.679 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.689 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.699 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.709 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.719 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.729 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.739 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.749 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.759 | Info | Audio | "Evaluating audio 669 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.769 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.779 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.789 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.800 | Info | Audio | "Evaluating audio 653 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.809 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.819 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.829 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.839 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.849 | Info | Audio | "Evaluating audio 659 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.859 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.869 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.879 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.889 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.899 | Info | Audio | "Evaluating audio 659 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.909 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.919 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.929 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.939 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.950 | Info | Audio | "Evaluating audio 652 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.959 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.969 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.979 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.989 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:06.999 | Info | Audio | "Evaluating audio 657 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.009 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.019 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.029 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.039 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.049 | Info | Audio | "Evaluating audio 660 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.059 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.069 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.079 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.089 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.099 | Info | Audio | "Evaluating audio 660 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.109 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.119 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.129 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.139 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.149 | Info | Audio | "Evaluating audio 660 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.159 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.169 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.179 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.189 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.199 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.209 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.219 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.229 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.239 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.249 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.259 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.269 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.279 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.289 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.299 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.309 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.319 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.329 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.339 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.349 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.359 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.369 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.379 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.389 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.399 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.409 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.419 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.429 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.439 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.449 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.459 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.469 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.479 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.489 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.499 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.509 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.519 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.529 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.539 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.549 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.559 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.569 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.579 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.589 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.599 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.609 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.619 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.629 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.639 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.649 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.659 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.669 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.679 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.689 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.699 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.709 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.719 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.729 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.739 | Info | Audio | "Evaluating audio 668 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.749 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.759 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.769 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.779 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.789 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.799 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.809 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.819 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.829 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.839 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.849 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.859 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.869 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.879 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.889 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.899 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.909 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.919 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.929 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.939 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.949 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.959 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.969 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.979 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.989 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:07.999 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.009 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.019 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.029 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.039 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.049 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.059 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.069 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.079 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.089 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.099 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.109 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.119 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.129 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.139 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.149 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.159 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.169 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.179 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.189 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.199 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.209 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.219 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.229 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.239 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.249 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.259 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.269 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.279 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.289 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.299 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.309 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.319 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.329 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.339 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.349 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.359 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.369 | Info | Audio | "Evaluating audio 660 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.379 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.389 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.399 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.409 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.419 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.429 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.439 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.449 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.459 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.469 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.479 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.489 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.499 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.509 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.519 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.529 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.539 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.549 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.559 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.569 | Info | Audio | "Evaluating audio 661 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.579 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.589 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.599 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.609 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.619 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.629 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.639 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.649 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.659 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.669 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.679 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.689 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.699 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.709 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.719 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.729 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.739 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.749 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.759 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.769 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.779 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.789 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.799 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.809 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.819 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.829 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.839 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.849 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.859 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.869 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.879 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.889 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.899 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.909 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.919 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.929 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.939 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.949 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.959 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.969 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.979 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.989 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:08.999 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.009 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.019 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.029 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.039 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.049 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.059 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.069 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.079 | Info | Audio | "Evaluating audio 667 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.089 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.099 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.109 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.119 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.129 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.139 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.149 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.159 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.169 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.179 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.189 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.199 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.209 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.219 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.229 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.239 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.249 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.259 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.269 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.279 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.289 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.299 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.309 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.319 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.329 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.339 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.349 | Info | Audio | "Evaluating audio 664 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.359 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.369 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.379 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.389 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.399 | Info | Audio | "Evaluating audio 665 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.409 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.419 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.429 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.439 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.449 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.459 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.469 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.479 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.489 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.499 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.509 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.519 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.529 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.539 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.549 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.559 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.569 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.579 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.589 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.599 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.609 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.619 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.629 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.639 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.649 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.659 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.669 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.679 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.689 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.699 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.709 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.719 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.729 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.739 | Info | Audio | "Evaluating audio 666 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:09.747 | Info | RESIP:DUM | "Got: SipResp: 603 tid=a055111cdf45dc43 cseq=INVITE / 1 from(wire)" |
09-04-09 20:36:09.747 | Info | RESIP:DUM | "Failure:  error response: SipResp: 603 tid=a055111cdf45dc43 cseq=INVITE / 1 from(wire)" |
09-04-09 20:36:09.747 | Info | RESIP:DUM | "Transition UAC_Early -> InviteSession::Terminated" |
09-04-09 20:36:09.747 | Info | CCM | "[UAC][state:EUACNew_SDPBranched][sdp-state:ESDPOfferSent] <- [event:onFailure] [[email protected] -> [email protected]]" | sua::CSIPCall::PreProcessIncomingEvent
09-04-09 20:36:09.747 | Info | CCM | "[UAC][state:EUACNew_SDPBranched][sdp-state:ESDPOfferSent] <- [event:onTerminated] [[email protected] -> [email protected]]" | sua::CSIPCall::PreProcessIncomingEvent
09-04-09 20:36:09.747 | Info | CCM | "[EUACNew_SDPBranched|ESDPOfferSent|T][containee:T] [[email protected] -> [email protected]]" | sua::CSIPCall::InternalShutdown
09-04-09 20:36:09.747 | Info | CCM | "[ECallHangingUp|ESDPOfferSent|T][containee:T] [[email protected] -> [email protected]]" | sua::CSIPCall::InternalShutdown
09-04-09 20:36:09.747 | Info | Media | " [session-ID:458]" | sua::CMediaSession::~CMediaSession
09-04-09 20:36:09.748 | Info | CCM | "[ECallHungUp|ESDPOfferSent|T][containee:T] [[email protected] -> [email protected]]" | sua::CSIPCall::InternalShutdown
09-04-09 20:36:09.748 | Info | CCM | "Object already shut-down. Waiting for deletion/final unreference only. [[email protected] -> [email protected]]" | sua::CSIPOutgoingCallGroup::OnMediaSessionClosed
09-04-09 20:36:09.748 | Error | AbstractPhone | "OnOutgoingCallRequestTerminated" | AbPhone::COutgoingCallRequest::CInviteSessionSink::BreakCircularReference
09-04-09 20:36:09.748 | Info | Media | " [session-ID:429]" | sua::CMediaSession::~CMediaSession
09-04-09 20:36:09.748 | Info | Audio | "StopAudio entry point, where instance ID=361" | sua::CAudioManager::StopAudio
09-04-09 20:36:09.978 | Info | Audio | "Device supports 8000 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:36:09.978 | Info | Audio | "Device supports 16000 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:36:09.978 | Info | Audio | "Device supports 22050 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:36:09.978 | Info | Audio | "Device supports 44100 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:36:09.979 | Info | Audio | "Device supports 48000 Hz" | sua::CAudioDeviceWaveOutInstance::Open
09-04-09 20:36:10.116 | Info | Audio | "Audio started, where instance ID=473, Out: Lautsprecher / Kopfhörer (Sigma" | sua::CAudioManager::StartAudio
09-04-09 20:36:10.117 | Info | Audio | "Outgoing stream (475): Playing override clip where instance=485 clip={A6316E4D-EF90-4333-84BA-4D5E7D82C4C6}" | sua::CAudioManager::StartOutgoingOverClip
09-04-09 20:36:10.117 | Info | Audio | "Evaluating audio 0 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.117 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.118 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.119 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.121 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.129 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.139 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.149 | Info | Audio | "Evaluating audio 800 0" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.159 | Info | Audio | "Evaluating audio 595 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.169 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.179 | Info | Audio | "Evaluating audio 595 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.189 | Info | Audio | "Evaluating audio 595 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.199 | Info | Audio | "Evaluating audio 595 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.209 | Info | Audio | "Evaluating audio 595 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.219 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.229 | Info | Audio | "Evaluating audio 595 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.239 | Info | Audio | "Evaluating audio 595 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.249 | Info | Audio | "Evaluating audio 595 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.259 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.269 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.279 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.289 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.299 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.309 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.319 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.329 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.339 | Info | Audio | "Evaluating audio 595 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.349 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.359 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.369 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.379 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.389 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.399 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.409 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.419 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.429 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.439 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.449 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.459 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.469 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.479 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.489 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.499 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.509 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.519 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.529 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.539 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.549 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.559 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.569 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.579 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.589 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.599 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.609 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.619 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.629 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.639 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.649 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.659 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.669 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.679 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.689 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.699 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.709 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.719 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.729 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.739 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.749 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.759 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.769 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.779 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.789 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.799 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.809 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.819 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.829 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.839 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.849 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.859 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.869 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.879 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.889 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.899 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.909 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.919 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.929 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.939 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.949 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.959 | Info | Audio | "Evaluating audio 594 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.969 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.979 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.989 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:10.999 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.009 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.019 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.029 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.039 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.049 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.059 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.069 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.079 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.089 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.099 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.109 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.119 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.129 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.139 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.149 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.159 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.169 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.179 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.189 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.199 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.209 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.219 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.229 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.239 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.249 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.259 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.269 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.279 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.289 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.299 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.309 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.319 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.329 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.339 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.349 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.359 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.369 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.379 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.389 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.399 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.409 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.419 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.429 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.439 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.449 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.459 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.469 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.479 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.489 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.499 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.509 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.519 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.529 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.539 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.549 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.559 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.569 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.579 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.589 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.599 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.609 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.619 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.629 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.639 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.649 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.659 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.669 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.679 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.689 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.699 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.709 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.719 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.729 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.739 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.749 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.759 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.769 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.779 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.789 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.799 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.809 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.819 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.829 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.839 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.849 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.859 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.869 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.879 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.889 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.899 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.909 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.919 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.929 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.939 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.949 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.959 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.969 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.979 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.989 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:11.999 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.009 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.019 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.029 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.039 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.049 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.059 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.069 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.079 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.089 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.099 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.109 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.119 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.129 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.139 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.149 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.159 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.169 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.179 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.189 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.199 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.209 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.219 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.229 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.239 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.249 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.259 | Info | Audio | "Evaluating audio 593 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.269 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.279 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.289 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.299 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.309 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.319 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.329 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.339 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.349 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.359 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.369 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.379 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.389 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.399 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.409 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.419 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.429 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.439 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.449 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.459 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.469 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.479 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.489 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.499 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.509 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.519 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.529 | Info | Audio | "Evaluating audio 587 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.539 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.549 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.559 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.569 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.579 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.589 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.599 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.609 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.619 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.629 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.639 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.649 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.659 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.669 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.679 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.689 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.699 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.709 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.719 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.729 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.739 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.749 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.759 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.769 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.779 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.789 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.799 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.809 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.819 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.829 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.839 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.849 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.859 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.869 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.879 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.889 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.899 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.909 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.919 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.929 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.940 | Info | Audio | "Evaluating audio 578 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.949 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.959 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.969 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.979 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.989 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:12.999 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.009 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.019 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.029 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.039 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.049 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.059 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.069 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.079 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.089 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.099 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.109 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.119 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.129 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.137 | Info | GUI | "User Action: Hang Up (cmd_hangup)" | eyeBeam::FunkyControl::DoAction
09-04-09 20:36:13.140 | Info | Audio | "Evaluating audio 577 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.149 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.159 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.169 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.179 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.189 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.199 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.209 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.219 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.229 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.239 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.249 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.259 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.269 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.279 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.289 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.299 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.309 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.319 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.329 | Info | Audio | "Evaluating audio 592 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.339 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.349 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.359 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.369 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.379 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.389 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.399 | Info | Audio | "Evaluating audio 586 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.409 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.419 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.429 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.439 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.449 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.459 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.462 | Info | USB Devices | "First attempt to connect device." | cpsi::CPolycomUSB::Connect
09-04-09 20:36:13.464 | Info | USB Devices | "Failed to create GobiCtrl object." | cpsi::CPolycomUSB::Connect
09-04-09 20:36:13.469 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.479 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.489 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.499 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.509 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.519 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.529 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.539 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.549 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.559 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.569 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.579 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.589 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.599 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.609 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.619 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.629 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.639 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.649 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.659 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.669 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.679 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.689 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.699 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.709 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.719 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.729 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.739 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.749 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.759 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.769 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.779 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.789 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.799 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.809 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.819 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.829 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.839 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.849 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.859 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.869 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.879 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.889 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.899 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.909 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.919 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.929 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.939 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.949 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.959 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.969 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.979 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.989 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:13.999 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.009 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.019 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.029 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.039 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.049 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.059 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.069 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.079 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.089 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.099 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.109 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.119 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.129 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.139 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.149 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.159 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.169 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.179 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.189 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.199 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.209 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.219 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.229 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.239 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.249 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.259 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.269 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.279 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.289 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.299 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.309 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.319 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.329 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.339 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.349 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.359 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.369 | Info | Audio | "Evaluating audio 587 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.379 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.389 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.399 | Info | Audio | "Evaluating audio 586 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.409 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.419 | Info | Audio | "Evaluating audio 589 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.429 | Info | Audio | "Evaluating audio 587 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.439 | Info | Audio | "Evaluating audio 588 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.449 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.460 | Info | Audio | "Evaluating audio 580 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.469 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.479 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.489 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.499 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.509 | Info | Audio | "Evaluating audio 584 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.519 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.529 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.539 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.549 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.559 | Info | Audio | "Evaluating audio 590 1" | sua::CAudioManager::ServiceAudioOut
09-04-09 20:36:14.569 | Info | Audio | "Evaluating audio 591 1" | sua::CAudioManager::ServiceAudioOut
Irgendwie findet bei dir keine Registrierung mit der dtmfbox statt, deswegen muss es etwas mit der Konfiguration von X-Lite zu tun haben. Sagt den X-Lite wirklich "Ready Your username is: XXXXX" ???
Auch gehen die Anfragen an die falsche Adresse, wie mir scheint. Es müsste INVITE fritz.box:5061 lauten.
ja, er sagt brav "Ready Your username is: analog"
Also da ich die FB nicht als DNS nutze, habe ich unter Domain Proxy die 10.0.0.12:5061 eingetragen.
fritz.box kann er sonst bei mir nicht auflösen.
Ich habe nun fritz.box in die Hosts-Datei eingetragen. fritz.box wird nun brav auf die 10.0.0.12 aufgelöst.
Auch wenn ich X-Lite dann auf den Namen umkonfiguriere bringt dies keinen Erfolg :-(
Ich habe mir grad mal den oberen Log angeschaut der ist für mich besser lesbar als der letzte. Da steht doch ganz deutlich das von <sip:[email protected]> der Account <sip:[email protected]> angerufen wird, 0160xxx61xxx aber ein unbekannter Account ist.
ja, kommt mir auch komisch vor obwohl ich nicht weiß ob ich die Meldung korrekt interpretiere. Ich wähle mit der 0160 ja eine externe Handy-Nummer und die soll er ganz normal über das analoge Amt wählen.
Vom direkt an die FB angeschlossenen Analog-Telefon funktioniert das auch problemlos.
Da vorher keine Registrierung statt findet, wird der Anruf als "eingehender Anruf" interpretiert. Ansonsten könnte ja jeder ohne Benutzername und Passwort über die dtmfbox raustelefonieren.
Würde vorher ein Handshake durchgeführt (SIP-Nachricht "REGISTER"), wäre der Client auch zum raustelefonieren authorisiert. Es erfolgt aber lediglich ein "INVITE" und die dtmfbox weist den Anruf ab (0160.. ist nicht als Account hinterlegt, also fehlt das Ziel).
Mich wundert allerdings, dass zwar ein Client im Status auftaucht, aber nichts davon im Log. Weder bei dtmfbox noch X-Lite...
EDIT:
mir ist noch etwas eingefallen: wenn du die dtmfbox neu startest, muss X-Lite ebenfalls neu gestartet werden. X-Lite bekommt vom Neustart der dtmfbox nix mit und registriert sich daher nicht neu.
EDIT:
das habe ich immer gemacht weils mich auch gewundert hat das er nix merkt :-(
Hast du auch mal andere SIP-Clients probiert? Also bei mir geht das problemlos, mit der selben x-lite Version :noidea:
Dumme Frage zwischendurch: Könnte irgendeine Firewall da irgendwas Blocken?
Das sagt er übrigens im Status während ich wähle:
Accounts
(1) [CAPI] unknown - - Pending!
Verbindungen
(0) [USER] OUTGOING - CONNECT - unknown -> 01609xxxxx (1)
(1) [CAPI] OUTGOING - CONNECT - unknown -> 01609xxxxx (0)
Clients
(1) 10.0.0.181:62832 - 1 account(s), 0 min
so, habe nun die FB an meinem Asterisk angemeldet. Selbes Ergebnis. Der Asterisk registriert sich erfolgreich an der FB. Wenn ich dann raustelefoniere erhalte ich dieses Ergebnis im Log vom Asterisk. IP vom Asterisk ist die 10.0.0.6.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2009.04.11 17:58:49 =~=~=~=~=~=~=~=~=~=~=~=
    -- Executing [01609xxxxxxx@standard:1] Answer("SIP/fritzbox1-081d6e80", "") in new stack
[Kasterisk1*CLI>
    -- Executing [01609xxxxxxx@standard:3] Dial("SIP/fritzbox1-081d6e80", "SIP/01609xxxxxxx@o-gsm||tT") in new stack
[Kasterisk1*CLI>
Audio is at 10.0.0.6 port 14668
[Kasterisk1*CLI>
Adding codec 0x4 (ulaw) to SDP
Adding codec 0x2 (gsm) to SDP
Adding codec 0x8 (alaw) to SDP
Adding non-codec 0x1 (telephone-event) to SDP
[Kasterisk1*CLI>
Reliably Transmitting (no NAT) to 10.0.0.12:5061:
INVITE sip:[email protected]:5061 SIP/2.0 Via: SIP/2.0/UDP 10.0.0.6:5060;branch=z9hG4bK2fc96d19;rport From: "fritzbox1" <sip:[email protected]>;tag=as46c3b061 To: <sip:[email protected]:5061> Contact: <sip:[email protected]> Call-ID: [email protected] CSeq: 102 INVITE User-Agent: Asterisk PBX Max-Forwards: 70 Date: Sat, 11 Apr 2009 15:59:04 GMT Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY Supported: replaces Content-Type: application/sdp Content-Length: 279  v=0 o=root 18510 18510 IN IP4 10.0.0.6 s=session c=IN IP4 10.0.0.6 t=0 0 m=audio 14668 RTP/AVP 0 3 8 101 a=rtpmap:0 PCMU/8000 a=rtpmap:3 GSM/8000 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=silenceSupp:off - - - - a=ptime:20 a=sendrecv
[Kasterisk1*CLI>
    -- Called 01609xxxxxxx@o-gsm
[Kasterisk1*CLI>  <--- SIP read from 10.0.0.12:5061 --->
SIP/2.0 100 Trying Via: SIP/2.0/UDP 10.0.0.6:5060;rport=5060;received=10.0.0.6;branch=z9hG4bK2fc96d19 Call-ID: [email protected] From: "fritzbox1" <sip:[email protected]>;tag=as46c3b061 To: <sip:[email protected]> CSeq: 102 INVITE Content-Length:  0
[Kasterisk1*CLI>
--- (7 headers 0 lines) ---
SIP/2.0 180 Ringing Via: SIP/2.0/UDP 10.0.0.6:5060;rport=5060;received=10.0.0.6;branch=z9hG4bK2fc96d19 Call-ID: [email protected] From: "fritzbox1" <sip:[email protected]>;tag=as46c3b061 To: <sip:[email protected]>;tag=WgGCnxhjcq2rztfY6YiubSBzCf9rIh.I CSeq: 102 INVITE Contact: "analog" <sip:[email protected]:5061;transport=UDP> Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, REGISTER Content-Length:  0
[Kasterisk1*CLI>
--- (9 headers 0 lines) ---
[Kasterisk1*CLI>
    -- SIP/o-gsm-081d06c8 is ringing
SIP/2.0 603 Decline Via: SIP/2.0/UDP 10.0.0.6:5060;rport=5060;received=10.0.0.6;branch=z9hG4bK2fc96d19 Call-ID: [email protected] From: "fritzbox1" <sip:[email protected]>;tag=as46c3b061 To: <sip:[email protected]>;tag=WgGCnxhjcq2rztfY6YiubSBzCf9rIh.I CSeq: 102 INVITE Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, REGISTER Content-Length:  0
--- (8 headers 0 lines) ---
[Kasterisk1*CLI>
    -- Got SIP response 603 "Decline" back from 10.0.0.12
ACK sip:[email protected]:5061 SIP/2.0 Via: SIP/2.0/UDP 10.0.0.6:5060;branch=z9hG4bK2fc96d19;rport From: "fritzbox1" <sip:[email protected]>;tag=as46c3b061 To: <sip:[email protected]:5061>;tag=WgGCnxhjcq2rztfY6YiubSBzCf9rIh.I Contact: <sip:[email protected]> Call-ID: [email protected] CSeq: 102 ACK User-Agent: Asterisk PBX Max-Forwards: 70 Content-Length: 0
   -- SIP/o-gsm-081d06c8 is busy
[Kasterisk1*CLI>
  == Everyone is busy/congested at this time (1:1/0/0)
[Kasterisk1*CLI>
    -- Executing [01609xxxxxxx@standard:4] Goto("SIP/fritzbox1-081d6e80", "s-BUSY|1") in new stack
    -- Goto (standard,s-BUSY,1)
    -- Executing [s-BUSY@standard:1] Answer("SIP/fritzbox1-081d6e80", "") in new stack
[Kasterisk1*CLI>
Really destroying SIP dialog '[email protected]' Method: INVITE
[Kasterisk1*CLI>
    -- Executing [s-BUSY@standard:3] Hangup("SIP/fritzbox1-081d6e80", "") in new stack
  == Spawn extension (standard, s-BUSY, 3) exited non-zero on 'SIP/fritzbox1-081d6e80'
[Kasterisk1*CLI>
    -- Executing [h@standard:1] Answer("SIP/fritzbox1-081d6e80", "") in new stack
  == Spawn extension (standard, h, 1) exited non-zero on 'SIP/fritzbox1-081d6e80'
[Kasterisk1*CLI>
So langsam macht es echt keinen Spaß mehr :-(
so, erstmal FROHE OSTERN zusammen :-)
Ich bin mal wieder am basteln. Was ich bisher noch gar nicht probiert habe.
Eingehende Anrufe auf dem analogen Amt werden übrigens brav per SIP signalisiert und können auch am X-Lite Softphone angenommen werden!?!?!
Ich werde hier noch bekloppt :-)
PROBLEM GELÖST!!!:
Der AUSGEHENDE CAPI-Controller für Analog ist bei meiner Fritzbox Fon WLAN (2000 1665) die 3!! Nicht die 4!
figo12
