dtmfbox auf Fritzbox 7270 16MB + USB
Termi11
Gesperrt
4 Jan 2006
hab ein selbstgemachtes Image mit Freetz und dtmfbox gebacken.
Das Image läuft scheinbar auch sehr gut.
Hab jetzt versucht dtmfbox zu configurieren (nur Analog, kein VOIP und ISDN).
Hab jetzt aber diese Fehler:
16:54:04 CAPI 0x3490 - Normal call clearing
16:54:04 [type=capi/inc conid=0 accid=1 src=unknown trg=anonymous] (IND) CAPI_DISCONNECT
16:54:04 [plugin.menu] Action: script:action_wrapper (acc=1 con=0)
16:54:04 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/script/action.sh, "DISCONNECT", "CAPI", "INCOMING", "0", "-1", "unknown", "anonymous", "1", "", "13456") (acc=1 con=0)
16:54:56 [type=capi/inc conid=0 accid=1 src=unknown trg=anonymous] (IND) CAPI_CONNECT
16:54:56 (IND) CAPI_INFO (0x0018) - CHANNEL IDENTIFICATION (0x03)
16:54:56 (IND) CAPI_INFO (0xc000) - UNKNOWN INFO
16:54:56 [ctrl=4, plci=772] CNF: CAPI_ALERT
16:54:56 [plugin.menu] Action: script:action_wrapper (acc=1 con=0)
16:54:56 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/script/action.sh, "CONNECT", "CAPI", "INCOMING", "0", "-1", "unknown", "anonymous", "1", "", "") (acc=1 con=0)
16:55:07 [type=capi/inc conid=0 accid=1 src=unknown trg=anonymous] Hook up
16:55:07 (220181) Unable to open ./play/ansage.wav
16:55:07 [type=capi/inc conid=0 accid=1 src=unknown trg=anonymous] Record /var/dtmfbox/record/1/09-08-13---unknown-anonymous-0.wav (-1)
16:55:08 CAPI 0x3301 - Protocol error layer 1 (broken line or B-channel removed by signalling protocol)
16:55:08 [type=capi/inc conid=0 accid=1 src=unknown trg=anonymous] (IND) CAPI_DISCONNECT
16:55:08 [plugin.menu] Action: script:action_wrapper (acc=1 con=0)
16:55:08 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/script/action.sh, "DISCONNECT", "CAPI", "INCOMING", "0", "-1", "unknown", "anonymous", "1", "", "13057") (acc=1 con=0)
16:55:16 [type=capi/inc conid=0 accid=1 src=unknown trg=anonymous] (IND) CAPI_CONNECT
16:55:16 (IND) CAPI_INFO (0x0018) - CHANNEL IDENTIFICATION (0x03)
16:55:16 (IND) CAPI_INFO (0xc000) - UNKNOWN INFO
16:55:16 [ctrl=4, plci=1284] CNF: CAPI_ALERT
16:55:16 [plugin.menu] Action: script:action_wrapper (acc=1 con=0)
16:55:16 [plugin.menu] Script: /var/dtmfbox/script/action.sh(/var/dtmfbox/script/action.sh, "CONNECT", "CAPI", "INCOMING", "0", "-1", "unknown", "anonymous", "1", "", "") (acc=1 con=0)
Das Erste ist "16:55:07 (220181) Unable to open ./play/ansage.wav"
Datei steht unter "/var/media/ftp/uStor01/dtmfbox/play" bzw. "/var/dtmfbox/play", ist 8khz, 16bit und Mono, und hat alle Rechte.
Der Anrufbeantworter ist eingeschaltet, Nimmt jedoch nicht ab.
**600 Intern Funktioniert.
Das Zweite ist dieser Fehler: "16:55:16 [ctrl=4, plci=1284] CNF: CAPI_ALERT"
und "16:55:08 CAPI 0x3301 - Protocol error layer 1 (broken line or B-channel removed by signalling protocol)"
Wenn ich dtmfbox starte erhalte ich noch als Log:
16:53:03 dtmfbox 0.5.0
16:53:03 PJSIP 1.0.1
16:53:03 Conference bridge created [8000/16/1]
16:53:03 Allocate 11 connections with 4 RTP/RTCP transports
16:53:03 Init CAPI ...
16:53:03 CAPI controller: 5
16:53:03 Found controller #1 with 2 B-channel(s)
16:53:03 Found controller #2 with 2 B-channel(s)
16:53:03 Found controller #3 with 2 B-channel(s)
16:53:03 Found controller #4 with 1 B-channel(s)
16:53:03 Found controller #5 with 3 B-channel(s)
16:53:03 CAPI registered (ApplID: 7, B-Channels: 10)
16:53:03 Build a-law/pcm table buffer
16:53:04 CAPI initialized!
16:53:04 [plugin.menu] Loading /var/dtmfbox//menu.cfg ...
16:53:04 [plugin.menu] action:1_ctrl5reject loaded (5 entries)
16:53:04 [plugin.menu] action:2_action_wrapper loaded (1 entries)
16:53:04 [plugin.menu] lib:speak loaded (2 entries)
16:53:04 [plugin.menu] menu:am loaded (2 entries)
16:53:04 [plugin.menu] menu:am_delete loaded (3 entries)
16:53:04 [plugin.menu] menu:am_on_off loaded (2 entries)
16:53:04 [plugin.menu] menu:am_setup loaded (4 entries)
16:53:04 [plugin.menu] menu:anticallcenter loaded (1 entries)
16:53:04 [plugin.menu] menu:callthrough_account loaded (13 entries)
16:53:04 [plugin.menu] menu:callthrough_number loaded (3 entries)
16:53:04 [plugin.menu] menu:callthrough_pin loaded (3 entries)
16:53:04 [plugin.menu] menu:dtmf_commands loaded (7 entries)
16:53:04 [plugin.menu] menu:main loaded (6 entries)
16:53:04 [plugin.menu] menu:misc loaded (6 entries)
16:53:04 [plugin.menu] menu:misc_checkmaild loaded (5 entries)
16:53:04 [plugin.menu] menu:misc_fb loaded (5 entries)
16:53:04 [plugin.menu] menu:misc_radio loaded (11 entries)
16:53:04 [plugin.menu] menu:misc_weather loaded (3 entries)
16:53:04 [plugin.menu] script:action_anticallcenter loaded (1 entries)
16:53:04 [plugin.menu] script:action_ctrl5 loaded (1 entries)
16:53:04 [plugin.menu] script:action_wrapper loaded (1 entries)
16:53:04 [plugin.menu] script:am_admin loaded (1 entries)
16:53:04 [plugin.menu] script:am_setup loaded (1 entries)
16:53:04 [plugin.menu] script:callthrough loaded (1 entries)
16:53:04 [plugin.menu] script:misc_checkmaild loaded (1 entries)
16:53:04 [plugin.menu] script:misc_fb loaded (1 entries)
16:53:04 [plugin.menu] script:misc_radio loaded (1 entries)
16:53:04 [plugin.menu] script:misc_weather loaded (1 entries)
16:53:04 [plugin.menu] 28 entries loaded!
16:53:04 [plugin.menu] Initialized!
16:53:04 #1 - Plugin "libmenu.plugin.so" loaded!
16:53:04 (0x3ff) - Listen to CAPI controller 1 ...
16:53:04 (0x3ff) - Listen to CAPI controller 4 ...
16:53:04 (0x3ff) - Listen to CAPI controller 3 ...
16:53:04 (0x3ff) - Listen to CAPI controller 5 ...
16:53:04 Start CAPI listen loop ...
16:53:04 [ctrl=1] CNF: CAPI_LISTEN
16:53:04 [ctrl=4] CNF: CAPI_LISTEN
16:53:04 [ctrl=3] CNF: CAPI_LISTEN
16:53:04 [ctrl=5] CNF: CAPI_LISTEN
16:53:14 [type=capi/inc conid=0 accid=1 src=unknown trg=anonymous] (IND) CAPI_CONNECT
Hat Jemand ne Ahnung was das sein kann?
TKS !
Elemir
