Dummysichere Anleitung für Installation ztdummy unter SL 9.2
lsmod gibt das hier aus:
dhcppc11:~ # lsmod
Module                  Size  Used by
ztdummy                 3364  0
zaptel                177924  1 ztdummy
crc_ccitt               2176  1 zaptel
nvram                   8328  0
usbserial              26856  0
parport_pc             37824  1
lp                     10536  0
parport                37960  2 parport_pc,lp
speedstep_lib           4228  0
freq_table              4356  0
processor              25640  0
snd_pcm_oss            57896  0
snd_mixer_oss          19200  1 snd_pcm_oss
snd_seq_midi            9504  0
snd_seq_midi_event      7424  1 snd_seq_midi
snd_trident_synth      12416  1
snd_ainstr_simple       3200  1 snd_trident_synth
snd_seq_instr           8320  1 snd_trident_synth
snd_seq_midi_emul       7936  1 snd_trident_synth
snd_seq                53008  6 snd_seq_midi,snd_seq_midi_event,snd_trident_synt                                              h,snd_seq_instr,snd_seq_midi_emul
snd_trident            43176  1 snd_trident_synth
snd_ac97_codec         69728  1 snd_trident
snd_pcm                96776  3 snd_pcm_oss,snd_trident,snd_ac97_codec
snd_timer              24708  2 snd_seq,snd_pcm
snd_page_alloc         10248  3 snd_trident_synth,snd_trident,snd_pcm
gameport                4608  1 snd_trident
snd_util_mem            4992  1 snd_trident
snd_mpu401_uart         7552  1 snd_trident
snd_rawmidi            24356  2 snd_seq_midi,snd_mpu401_uart
snd_seq_device          8716  5 snd_seq_midi,snd_trident_synth,snd_seq,snd_tride                                              nt,snd_rawmidi
snd                    60164  15 snd_pcm_oss,snd_mixer_oss,snd_seq_midi,snd_seq_                                              midi_event,snd_seq_instr,snd_seq_midi_emul,snd_seq,snd_trident,snd_ac97_codec,sn                                              d_pcm,snd_timer,snd_util_mem,snd_mpu401_uart,snd_rawmidi,snd_seq_device
soundcore               9056  1 snd
ipt_TOS                 2560  14
ip6t_LOG                6656  32
ip6t_limit              2432  32
ipt_LOG                 6912  45
ipt_limit               2432  45
ipt_pkttype             1792  2
edd                    10012  0
af_packet              20872  0
ip6t_state              2048  21
ip6_conntrack          38404  1 ip6t_state
ipt_state               2176  27
ip6t_REJECT             7552  3
ipt_REJECT              6784  3
iptable_mangle          2944  1
iptable_filter          3072  1
ip6table_mangle         2688  0
ip_nat_ftp              5232  0
iptable_nat            23980  1 ip_nat_ftp
ip_conntrack_ftp       72752  1 ip_nat_ftp
ip_conntrack           43128  4 ipt_state,ip_nat_ftp,iptable_nat,ip_conntrack_ft                                              p
ip_tables              17664  9 ipt_TOS,ipt_LOG,ipt_limit,ipt_pkttype,ipt_state,                                              ipt_REJECT,iptable_mangle,iptable_filter,iptable_nat
ip6table_filter         2816  1
ip6_tables             18816  6 ip6t_LOG,ip6t_limit,ip6t_state,ip6t_REJECT,ip6ta                                              ble_mangle,ip6table_filter
ipv6                  237312  17 ip6_conntrack,ip6t_REJECT
fcpci                 500760  2
evdev                   8960  0
joydev                  9664  0
sg                     35872  0
capidrv                28852  1
isdn                  133324  5 capidrv
st                     37404  0
slhc                    7936  1 isdn
sd_mod                 16912  0
sr_mod                 16292  0
scsi_mod              111052  4 sg,st,sd_mod,sr_mod
capi                   17472  4
capifs                  5896  2 capi
ide_cd                 38176  0
cdrom                  36508  2 sr_mod,ide_cd
kernelcapi             45984  3 fcpci,capidrv,capi
ohci_hcd               20228  0
sis_agp                 8068  1
agpgart                32168  1 sis_agp
subfs                   7552  3
dm_mod                 54524  0
usbcore               106724  4 usbserial,ohci_hcd
sis900                 19204  0
reiserfs              242000  1
Miwe
gratuliere. :)
Wie bekomme ich es hin, daß die ztdummy beim linuxboot gestartet wird?
will nicht jedesmal modprobe ztdummy eingeben...
Miwe
weiß nicht, so gut kenn ich mich
mit SuSE nicht aus.
Ich glaube irgendwo unter /etc gibt
es eine rc.local Datei.
britzelfix
Gut, muss ich mal schauen.
Vielen Dank für deine bisherige Hilfe.
Miwe
Year.... Es geht. Alles Paletti.
Danke, Danke, Danke!!!!
Miwe
miwe schrieb:
Also, letzter stand: Zaptel startet beim Linuxstart nicht.
Es gibt sicherlich auch bei SuSE eine Liste mit Modulen, die beim Boot geladen werden sollen. Versuche, diese Liste zu finden und schreibe ztdummy mit rein.
miwe schrieb:
dhcppc11:~ # insmod ztdummy
insmod: can't read 'ztdummy': No such file or directory
Probiers mal mit "insmod ztdummy.ko". insmod braucht immer auch das Suffix (also den kompletten Dateinamen), modprobe nicht.
Ciao, Mike
Hallo....
insmod ztdummy.ko geht auch nicht, das gleiche Ergebniss.
Wo sollte sich die ztdummy.ko befinden? Sicherlich sucht der Befehl in einen bestimmten Pfad, wo die Datei nicht vorhanden ist.
Miwe
Im Zweifelsfall solltest Du den kompletten Pfad zum Modul angeben. Ansonsten beantwortet die manpage zu insmod mit Sicherheit Deine Frage. Soweit ich weiss, sucht insmod nicht, wie modprobe, im zum aktuellen Kernel gehoerenden Modulverzeichnis nach dem Modul, sondern nur im aktuellen Verzeichnis. Bin mir aber nicht sicher.
Hallo...
Hab mir eben mal das Buch "mitp - LPI Level 1" zur Hand genommen und folgendes in Erfahrung gebracht:
Das Buch schreibt, daß sich der Einsatz von modprobe beim Laden von Modulen eher empfiehlt, da sich modprobe im Gegensatz zu insmod um Abhängigkeiten zwischen den Modulen kümmert und konfigurierbar ist.
Genau dieses habe ich ja oben bereits, wenn auch unbewusst :-) getan.
Ich werde das Gefühl nicht los, daß Ihr lieber insmod nehmt. Natürlich kann ich mich auch irren und was falsch verstanden haben. Wiso insmod?
Besondere Gründe? Ich lasse den ztdummy beim Linuxstart per modprobe ztdummy laden, meetme funktioniert.
Wenn es eine bessere Lösung gibt, bin ich für Vorschläge natürlich offen - will ja schließlich dazulernen :-)
Miwe
Ich verwende in der Regel modprobe. insmod nutze ich nur, wenn ich an einem Modul arbeite - dadurch entfaellt die Notwendigkeit, das Teil jedes Mal nach /lib/modules/... zu kopieren und anschliessend depmod -ae aufzurufen.
Ciao, Mike
@miwe
Warscheinlich nur aus Gewöhnung, aber auch weil nicht alle
"module autoload" im Kernel eingeschaltet haben.
Es gibt außerdem ein verändertes Verhalten zwischen dem Kernel 2.4 und 2.6.
2.4 modutils - der insmod ist das Tool, modprobe nur ein Symlink.
2.6 module-init-tools - der insmod ist ein simples Tool, modprobe
enthält die in 2.4 enthaltene Funktionalität.
Um das tzdummy beim Start automatisch zu laden kann man auch
folgende Zeile in modules.conf eintragen:
# /etc/modules.conf
alias char-major-196 ztdummy
britzelfix
hallo zusammen
ich habe eine Frage zu die Konferenzen mit mettme und zwar wie viele Teilnehmer können sich in einem Raum beteiligen oder sich anmelden
mein System schaut so aus Pentium III 1,6 MHz als Prozessor 20GB Festplatte
256 MB RAM Linux SuSE 9.3 als Betriebssystem mit Kernel 2.6.11
Und wie kann ich sehen wie hoch die Last auf dem Rechner ist
Danke im Voraus
realprogrammer
