Eicon Diva und Trixbox - keine ausgehenden Anrufe möglich
Laechler
30 Jul 2005
beim Versuch eine Verbindung nach draussen, Amtsleitung, herzustellen, erhalte ich mit den Einstellungen verbose=10, debug=10 und capi debug:
 -- Executing Dial("SIP/5-2d97", "CAPI/g1/0123456789") in new stack
       > data = g1/0123456789 format=8
       > parsed dialstring: 'g1' 'NULL' '0123456789' ''
       > capi request group = 2
  == ISDN1#02: setting format alaw - 0x8 (alaw)
  == ISDN1#02: Call CAPI/ISDN1/0123456789-9   (pres=0x00, ton=0x00)
CONNECT_REQ ID=001 #0x0013 LEN=0058
  Controller/PLCI/NCCI            = 0x1
  CIPValue                        = 0x1
  CalledPartyNumber               = <80>0123456789
  CallingPartyNumber              = <00 80>200340
  CalledPartySubaddress           = default
  CallingPartySubaddress          = default
  BProtocol
   B1protocol                     = 0x1
   B2protocol                     = 0x1
   B3protocol                     = 0x0
   B1configuration                = default
   B2configuration                = default
   B3configuration                = default
  BC                              = default
  LLC                             = default
  HLC                             = default
  AdditionalInfo
   BChannelinformation            = <00 00>
   Keypadfacility                 = default
   Useruserdata                   = default
   Facilitydataarray              = default
    -- Called g1/0123456789
       > CAPI devicestate requested for ISDN1/0123456789
CONNECT_CONF ID=001 #0x0013 LEN=0014
  Controller/PLCI/NCCI            = 0x301
  Info                            = 0x0
    -- ISDN1#02: received CONNECT_CONF PLCI = 0x301
INFO_IND ID=001 #0x001e LEN=0015
  InfoNumber                      = 0x804d
  InfoElement                     = default
INFO_RESP ID=001 #0x001e LEN=0012
    -- ISDN1#02: info element RELEASE
DISCONNECT_IND ID=001 #0x0020 LEN=0014
  Reason                          = 0x3490
DISCONNECT_RESP ID=001 #0x0020 LEN=0012
       > ISDN1#02: CAPI INFO 0x3490: Normal call clearing
    -- CAPI queue frame: [ TYPE: Control (4) SUBCLASS: Hangup (1) ] [ISDN1#02]
  == ISDN1#02: CAPI Hangingup for PLCI=0x301 in state 4
  == ISDN1#02: Interface cleanup PLCI=0x301
  == No one is available to answer at this time (1:0/0/0)
Die Auswertungen am Webinterface der Karte zeigen an:
(adapter xlog1.cgi)
    0:2130:252 - D-X(008) FE FF 03 0F 00 00 06 01
    0:2131:253 - D-R(008) FE FF 03 0F 00 00 04 01
    0:2131:772 - IPACX: invalid frame
meine capi.conf sieht so aus:
  Reason                          = 0x3490
    -- Executing Goto("SIP/5-2d97", "s-NOANSWER|1") in new stack
    -- Goto (macro-dialout-trunk,s-NOANSWER,1)
    -- Executing NoOp("SIP/5-2d97", "Dial failed due to NOANSWER") in new stack
    -- Executing Macro("SIP/5-2d97", "outisbusy|") in new stack
    -- Executing Playback("SIP/5-2d97", "all-circuits-busy-now") in new stack
       > CAPI devicestate requested for ISDN1/05531990570
    -- Playing 'all-circuits-busy-now' (language 'en')
    -- Executing Playback("SIP/5-2d97", "pls-try-call-later") in new stack
    -- Playing 'pls-try-call-later' (language 'en')
    -- Executing Macro("SIP/5-d269", "dialout-trunk|2|005532983850||") in new stack
    -- Executing GotoIf("SIP/5-d269", "1?3:2") in new stack
    -- Goto (macro-dialout-trunk,s,3)
    -- Executing Macro("SIP/5-d269", "user-callerid") in new stack
    -- Executing Set("SIP/5-d269", "AMPUSER=0") in new stack
    -- Executing Set("SIP/5-d269", "EMERGENCYCID=") in new stack
    -- Executing Set("SIP/5-d269", "AMPUSERCIDNAME=Zentrale") in new stack
    -- Executing GotoIf("SIP/5-d269", "0?6") in new stack
    -- Executing Set("SIP/5-d269", "CALLERID(all)="Zentrale" <0>") in new stack
    -- Executing NoOp("SIP/5-d269", "Using CallerID "Zentrale" <0>") in new stack
    -- Executing Macro("SIP/5-d269", "record-enable|0|OUT") in new stack
    -- Executing GotoIf("SIP/5-d269", "0 > 0?2:4") in new stack
    -- Goto (macro-record-enable,s,4)
    -- Executing AGI("SIP/5-d269", "recordingcheck|20070219-155620|1171896980.21") in new stack
    -- Launched AGI Script /var/lib/asterisk/agi-bin/recordingcheck
  recordingcheck|20070219-155620|1171896980.21: Outbound recording not enabled
    -- AGI Script recordingcheck completed, returning 0
    -- Executing NoOp("SIP/5-d269", "No recording needed") in new stack
    -- Executing Macro("SIP/5-d269", "outbound-callerid|2") in new stack
    -- Executing Set("SIP/5-d269", "USEROUTCID=200340") in new stack
    -- Executing GotoIf("SIP/5-d269", "0?4") in new stack
    -- Executing Set("SIP/5-d269", "CALLERID(all)=Rossmayer Consulting 05564200340") in new stack
    -- Executing Set("SIP/5-d269", "CALLERID(all)=200340") in new stack
    -- Executing GotoIf("SIP/5-d269", "1?8") in new stack
    -- Goto (macro-outbound-callerid,s,8)
    -- Executing NoOp("SIP/5-d269", "CallerID set to "" <200340>") in new stack
    -- Executing Set("SIP/5-d269", "GROUP()=OUT_2") in new stack
    -- Executing GotoIf("SIP/5-d269", "0?108") in new stack
    -- Executing Set("SIP/5-d269", "DIAL_NUMBER=005532983850") in new stack
    -- Executing Set("SIP/5-d269", "DIAL_TRUNK=2") in new stack
    -- Executing AGI("SIP/5-d269", "fixlocalprefix") in new stack
    -- Launched AGI Script /var/lib/asterisk/agi-bin/fixlocalprefix
  fixlocalprefix: Removed prefix. New number: 05532983850
    -- AGI Script fixlocalprefix completed, returning 0
    -- Executing Set("SIP/5-d269", "OUTNUM=05532983850") in new stack
    -- Executing Set("SIP/5-d269", "custom=AMP") in new stack
    -- Executing GotoIf("SIP/5-d269", "1?16") in new stack
    -- Goto (macro-dialout-trunk,s,16)
    -- Executing Set("SIP/5-d269", "pre_num=AMP:CAPI/g1/") in new stack
    -- Executing Set("SIP/5-d269", "the_num=OUTNUM") in new stack
    -- Executing Set("SIP/5-d269", "post_num=") in new stack
    -- Executing GotoIf("SIP/5-d269", "1?20:21") in new stack
    -- Goto (macro-dialout-trunk,s,20)
    -- Executing Set("SIP/5-d269", "the_num=05532983850") in new stack
    -- Executing Dial("SIP/5-d269", "CAPI/g1/05532983850") in new stack
       > data = g1/05532983850 format=8
       > parsed dialstring: 'g1' 'NULL' '05532983850' ''
       > CAPI devicestate requested for ISDN1/05532983850
  == ISDN1#02: Call CAPI/ISDN1/05532983850-a   (pres=0x00, ton=0x00)
CONNECT_REQ ID=001 #0x0014 LEN=0058
  CIPValue                        = 0x1
  CalledPartyNumber               = <80>05532983850
  BProtocol
   B1protocol                     = 0x1
   B2protocol                     = 0x1
   B3protocol                     = 0x0
  BC                              = default
  LLC                             = default
  HLC                             = default
  AdditionalInfo
    -- Called g1/05532983850
CONNECT_CONF ID=001 #0x0014 LEN=0014
  Info                            = 0x0
INFO_IND ID=001 #0x0021 LEN=0015
  InfoNumber                      = 0x804d
INFO_RESP ID=001 #0x0021 LEN=0012
DISCONNECT_IND ID=001 #0x0023 LEN=0014
  Reason                          = 0x3490
DISCONNECT_RESP ID=001 #0x0023 LEN=0012
    -- Executing Goto("SIP/5-d269", "s-NOANSWER|1") in new stack
    -- Executing NoOp("SIP/5-d269", "Dial failed due to NOANSWER") in new stack
    -- Executing Macro("SIP/5-d269", "outisbusy|") in new stack
    -- Executing Playback("SIP/5-d269", "all-circuits-busy-now") in new stack
asterisk1*CLI> CAPI queue frame: [ TYPE: Control (4) SUBCLASS: Hangup (1) ] [ISDN1#02] -- Executing Dial("SIP/5-2d97", "CAPI/g1/05531990570") in new stack
No such command 'CAPI queue' (type 'help' for help)
asterisk1*CLI>        > data = g1/05531990570 format=8
No such command '>' (type 'help' for help)
asterisk1*CLI>        > parsed dialstring: 'g1' 'NULL' '05531990570' ''
asterisk1*CLI>        > capi request group = 2
asterisk1*CLI>   == ISDN1#02: setting format alaw - 0x8 (alaw)
No such command '==' (type 'help' for help)
asterisk1*CLI>   == ISDN1#02: Call CAPI/ISDN1/05531990570-9   (pres=0x00, ton=0x00)
asterisk1*CLI> CONNECT_REQ ID=001 #0x0013 LEN=0058
No such command 'CONNECT_REQ' (type 'help' for help)
asterisk1*CLI>   Controller/PLCI/NCCI            = 0x1
No such command 'Controller/PLCI/NCCI' (type 'help' for help)
asterisk1*CLI>   CIPValue                        = 0x1
No such command 'CIPValue' (type 'help' for help)
asterisk1*CLI>   CalledPartyNumber               = <80>05531990570
No such command 'CalledPartyNumber' (type 'help' for help)
asterisk1*CLI>   CallingPartyNumber              = <00 80>200340
No such command 'CallingPartyNumber' (type 'help' for help)
asterisk1*CLI>   CalledPartySubaddress           = default
No such command 'CalledPartySubaddress' (type 'help' for help)
asterisk1*CLI>   CallingPartySubaddress          = default
No such command 'CallingPartySubaddress' (type 'help' for help)
asterisk1*CLI>   BProtocol
No such command 'BProtocol' (type 'help' for help)
asterisk1*CLI>    B1protocol                     = 0x1
No such command 'B1protocol' (type 'help' for help)
asterisk1*CLI>    B2protocol                     = 0x1
No such command 'B2protocol' (type 'help' for help)
asterisk1*CLI>    B3protocol                     = 0x0
No such command 'B3protocol' (type 'help' for help)
asterisk1*CLI>    B1configuration                = default
No such command 'B1configuration' (type 'help' for help)
asterisk1*CLI>    B2configuration                = default
No such command 'B2configuration' (type 'help' for help)
asterisk1*CLI>    B3configuration                = default
No such command 'B3configuration' (type 'help' for help)
asterisk1*CLI>   BC                              = default
No such command 'BC' (type 'help' for help)
asterisk1*CLI>   LLC                             = default
No such command 'LLC' (type 'help' for help)
asterisk1*CLI>   HLC                             = default
No such command 'HLC' (type 'help' for help)
asterisk1*CLI>   AdditionalInfo
No such command 'AdditionalInfo' (type 'help' for help)
asterisk1*CLI>    BChannelinformation            = <00 00>
No such command 'BChannelinformation' (type 'help' for help)
asterisk1*CLI>    Keypadfacility                 = default
No such command 'Keypadfacility' (type 'help' for help)
asterisk1*CLI>    Useruserdata                   = default
No such command 'Useruserdata' (type 'help' for help)
asterisk1*CLI>    Facilitydataarray              = default
No such command 'Facilitydataarray' (type 'help' for help)
asterisk1*CLI>
asterisk1*CLI>     -- Called g1/05531990570
No such command '--' (type 'help' for help)
asterisk1*CLI>        > CAPI devicestate requested for ISDN1/05531990570
asterisk1*CLI> CONNECT_CONF ID=001 #0x0013 LEN=0014
asterisk1*CLI>   Controller/PLCI/NCCI            = 0x301
asterisk1*CLI>   Info                            = 0x0
asterisk1*CLI>
asterisk1*CLI> INFO_IND ID=001 #0x001e LEN=0015
asterisk1*CLI>   InfoNumber                      = 0x804d
asterisk1*CLI>
asterisk1*CLI>
asterisk1*CLI>
asterisk1*CLI> DISCONNECT_IND ID=001 #0x0020 LEN=0014
asterisk1*CLI>   Reason                          = 0x3490
asterisk1*CLI>
asterisk1*CLI>   == No one is available to answer at this time (1:0/0/0)
asterisk1*CLI>
asterisk1*CLI>        > ISDN1#02: CAPI INFO 0x3490: Normal call clearing
asterisk1*CLI>     -- CAPI queue frame: [ TYPE: Control (4) SUBCLASS: Hangup (1) ] [ISDN1#02]
asterisk1*CLI>   == ISDN1#02: CAPI Hangingup for PLCI=0x301 in state 4
asterisk1*CLI>   == ISDN1#02: Interface cleanup PLCI=0x301
No such command 'CONNECT_CONF' (type 'help' for help)
No such command 'Info' (type 'help' for help)
No such command 'INFO_IND' (type 'help' for help)
No such command 'InfoNumber' (type 'help' for help)
No such command 'InfoElement' (type 'help' for help)
No such command 'INFO_RESP' (type 'help' for help)
No such command 'DISCONNECT_IND' (type 'help' for help)
No such command 'Reason' (type 'help' for help)
No such command 'DISCONNECT_RESP' (type 'help' for help)
asterisk1*CLI> vi capi.conf
No such command 'vi' (type 'help' for help)
asterisk1*CLI> exit
Executing last minute cleanups
[root@asterisk1 asterisk]# vi capi.conf
; CAPI config
; general section
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
language=de      ;set default language
;ulaw=yes        ;set this, if you live in u-law world instead of a-law
; interface sections ...
[ISDN1]          ;this example interface gets name 'ISDN1' and may be any
                 ;name not starting with 'g' or 'contr'.
                 ;Use one interface section for each isdn port!
ntmode=yes       ;if isdn card operates in nt mode, set this to yes
isdnmode=DID     ;when using NT-mode, 'DID' should be set in any case
incomingmsn=*    ;allow incoming calls to this list of MSNs/DIDs, * = any
;defaultcid=123  ;set a default caller id to that interface for dial-out,
                 ;this caller id will be used when dial option 'd' is set.
;controller=0    ;ISDN4BSD default
;controller=7    ;ISDN4BSD USB default
controller=1     ;capi controller number of this interface/port
group=1          ;dialout group
;prefix=0        ;set a prefix to calling number on incoming calls
softdtmf=on      ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=on     ;in addition to softdtmf, you can use relaxed dtmf detection
faxdetect=off    ;enable faxdetection and redirection to EXTEN 'fax' for incoming and/or
                 ;outgoing calls. (default='off', possible values: 'incoming','outgoing','both')
accountcode=     ;PBX accountcode to use in CDRs
;amaflags=default;AMA flags for CDR ('default', 'omit', 'billing', or 'documentation')
context=capi-in  ;context for incoming calls
;holdtype=hold   ;when the PBX puts the call on hold, ISDN HOLD will be used. If
                 ;set to 'local' (default value), no hold is done and the PBX may
                 ;play MOH.
;immediate=yes   ;DID: immediate start of pbx with extension 's' if no digits were
                 ;     received on incoming call (no destination number yet)
                 ;MSN: start pbx on CONNECT_IND and don't wait for SETUP/SENDING-COMPLETE.
                 ;     info like REDIRECTINGNUMBER may be lost, but this is necessary for
                 ;     drivers/pbx/telco which does not send SETUP or SENDING-COMPLETE.
echosquelch=1   ;_VERY_PRIMITIVE_ echo suppression
echocancel=yes  ;EICON DIVA SERVER (CAPI) echo cancelation (yes=g165)
                 ;(possible values: 'no', 'yes', 'force', 'g164', 'g165')
;echocancelold=yes;use facility selector 6 instead of correct 8 (necessary for older eicon drivers)
echotail=64     ;echo cancel tail setting (default=0 for maximum)
;echocancelnlp=1 ;activate non-linear-processing; this improves echo cancel ratio, but might
                 ;incorporate variable gain in the signal path.
bridge=yes      ;native bridging (CAPI line interconnect) if available
;callgroup=1     ;PBX call group
;pickupgroup=1   ;PBX pickup group (which call groups are we allowed to pickup)
;language=de     ;set language for this device (overwrites default language)
;disallow=all    ;RTP codec selection (valid with Eicon DIVA Server only)
"capi.conf" 62L, 3265C
Was kann ich machen? Ich bin für jede Hilfe dankbar.
densen420
