[EN] Skype through FON in Fritz 7270
Majdan
5 Nov 2006
Hi!
I was wondering if it is possible to use Skype with Fritz.
I know Skype protocol is completely different than SIP, but do you know other ways to make it working?
With kind regards!
As fare as I know it is'n posible to use Skype with the FritzBox. And there is also no SIP-Skype-gateway as I know.
It's possible to use skype with Asterisk. There is a beta-version available for a integration in Asterisk. I don't know whether the beta works with the Asterisk-modification for FritzBox. Here you can find the Asterisk for FritzBox Forum.
Gruß Telefonmännchen
