(ERLEDIGT) Trixbox 2.6 - OUT geht - IN nicht errechbar.
mslin
29 Sep 2009
bin neu hier im Forum um bitte euch um eure hilfe.
Habe schon jede Menge über Google gesucht und rumprobiert...
Habe das Problem, daß ich zwar raustelefonieren kann, aber es kommen keine Gespräche rein - da kommt dann immer -dieser Anschluß ist voübergehend nicht erreichbar-.
sip.conf
; Do NOT edit this file as it is auto-generated by FreePBX. All modifications to ;
; this file must be done via the web gui. There are alternative files to make ;
; custom modifications, details at: http://freepbx.org/configuration_files ;
[general]
; These files will all be included in the [general] context
#include sip_general_additional.conf
;sip_general_custom.conf is the proper file location for placing any sip general
;options that you might need set. For example: enable and force the sip jitterbuffer.
;If these settings are desired they should be set the sip_general_custom.conf file.
; jbenable=yes
; jbforce=yes
;It is also the proper place to add the lines needed for sip nat'ing when going
;through a firewall. For nat'ing you'd need to add the following lines:
; nat=yes , externip= , localhost= , and optionally fromdomain= .
#include sip_general_custom.conf
;sip_nat.conf is here for legacy support reasons and for those that upgrade
;from previous versions. If you have this file with lines in it please make
;sure they are not duplicated in sip_general_custom.conf, if so remove them
from sip_nat.conf as sip_general_custom.conf will have precedence.
#include sip_nat.conf
;sip_registrations_custom.conf is for any customizations you might need to do to
;the automatically generated registrations that FreePBX makes.
#include sip_registrations_custom.conf
#include sip_registrations.conf
; These files should all be expected to come after the [general] context
#include sip_custom.conf
#include sip_additional.conf
;sip_custom_post.conf If you have extra parameters that are needed for a
;extension to work to for example, those go here. So you have extension
;1000 defined in your system you start by creating a line [1000](+) in this
;file. Then on the next line add the extra parameter that is needed.
;When the sip.conf is loaded it will append your additions to the end of
;that extension.
#include sip_custom_post.conf
sip_add....conf
[10]
deny=0.0.0.0/0.0.0.0
type=friend
secret=*****
qualify=yes
port=5060
pickupgroup=
permit=0.0.0.0/0.0.0.0
nat=yes
mailbox=10@default
host=dynamic
dtmfmode=rfc2833
dial=SIP/10
context=from-internal
canreinvite=no
callgroup=
callerid=device <10>
accountcode=
call-limit=50
[11]
type=friend
secret=*****
qualify=yes
port=5060
pickupgroup=
nat=yes
mailbox=11@default
host=dynamic
dtmfmode=rfc2833
dial=SIP/11
canreinvite=no
callgroup=
callerid=device <11>
accountcode=
call-limit=50
[SIP-OUT]
allow=gsm
allow=alaw
allow=ulaw
allow=g729
allow=slinear
authuser=56*****
canreinvite=yes
context=ext-did
disable=all
dtmfmode=info
fromdomain=sipgate.de
fromuser=56*****
host=sipgate.de
insecure=port,invite
nat=no
qualify=yes
secret=****
srvlookup=yes
type=friend
username=56*****
Was komme einfach nicht weiter...
mslin
---->> habs hinbekommen - hab hier im Forum nochmal gesucht und anscheinend fündig geworden.... gruß
Schön - aber wie?
Hallo! Wie hast Du das gelöst?
Der Thread hier ist ja leider schon ganz schön alt... Aber ich habe das gleiche (?) Problem und ich hoffe, es gibt hier noch ein paar nützliche Tipps.
Folgende Ausgangssituation:
Meine Trixbox fungiert bei mir als Telefonzentrale für meine Firma.
- Trixbox 2.8.0.4 mit 3xVOIP von 1und1 und 1x FritzCARD-PCI ISDN hinter einer (vom Port her auf 5090 geänderten) Fritzbox 7170
- an der Trixbox hängen 7 Nebenstellen "Hausintern" (3x Grandstraem GXP2020 und 4 analogtelefone über Wandler) und bis zu 10 weitere Netzwerk-Nebenstellen (Softphone) über dyndns deutschlandweit
Alles funktioniert tadellos - ISDN mit Rufnummernblock 0-40 macht keinerlei Probs, interne Verbindungen (auch die über dyndns) klappen super und man kann jederzeit von überallher "raustelefonieren". Die anwahl von Externen Teilnehmern erfolgt NUR über die VOIP-Nummern von 1&1.
Nun kommt es aber häufiger vor, daß sich die VOIP-Nummer(n) offensichtlich "verselbständigen"... Plötzlich und ohne Voranmeldung gibt dann eine nette Stimme bekannt, daß "diese Nummer zur Zeit nicht erreichbar" ist, wenn man die VOIP-Nr. von aussen her anwählt (hat nichts mit "Besetzt" zu tun!).
Der Fehler ist sonst dummerweise nicht bemerkbar - Einwahl über ISDN i.O und interne Gespräche sowie Gespräche nach draussen über VOIP (die selben Nummern!) i.O. Ich merke es immer nur dann, wenn mir wiedermal jemand sagt: "Du Dein Telefon geht nicht" - und das sind die Leute, die mich über VOIP und nicht über ISDN anrufen... :(
Nach einem Reboot der Trixbox (komplettreboot - NICHT einfach mal eben Asterisk neu starten) geht's wieder. Hat auch nichts mit einem 24h-Disconnect und neuer IP zu tun - manchmal gehts 2 Wochen lang und tritt dann auf -manchmal schon nach ein paar Stunden nach dem Reboot.
Ich hab auch schon meine Leitung checken lassen - alle Werte sind aber i.O. (Telekom und 1&1)
Wenn es eine Möglichkeit geben würde, das "Senden der Nummer" zu unterdrücken, wäre mir schon viel geholfen - meine Haupteinwahlnummern sollen ohnehin die ISDN-Nummern sein.
Ein "override" der Outgoing-Nummer läßt 1und1 wohl nicht zu, denn da geht dann gar nix mehr, wenn ich das einstelle...
Kennt jemand dieses Problem - und wenn ja: was kann ich tun?
Mach Dich mal auf die Suche hier im Forum. Da gab's mal was dazu, dass im ankommenden Peer die ganzen Load Balancer von 1&1 als host eingetragen werden müssen, weil sonst die Authentifizierung über insecure nicht greift.
Hey, danke für den Tip - ich hoffe mal, daß mir das hilft... Im Moment hört sich das noch sehr chinesisch an - aber als ich mit der Trixbox angefangen habe, war das Thema VOIP und Asterisk in seiner Gesamtheit noch "Böhmisches Dorf" für mich... Ich taste mich wieder mal ran. Wenn jemand das selbe Prob hat, kann er hier ja nochmal posten - dann such ich nicht allein ^__^ Vielen Dank aber!
viktor1181
