Erneut fehler beim compilieren von 2.6er Kernel DS Mod
Seppl82
14 Okt 2006
Leider ist wieder ein Fehler aufgetreten (und diesmal hab ich die Suchfunktiona auch benutzt und nichts gefunden....
Und zwar ging es so zuende...
libtransmission/ratecontrol.c:98: error: expected ')' before '*' token
libtransmission/ratecontrol.c:109: error: expected ')' before '*' token
libtransmission/ratecontrol.c:136: error: expected ')' before '*' token
libtransmission/ratecontrol.c:147: error: expected ')' before '*' token
libtransmission/ratecontrol.c:163: error: expected ')' before '*' token
/home/frsc/downloads/ds-0.2.9_26-12/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -W -Wall -pipe -Wa,--trap -msoft-float -mips32 -mtune=mips32 -O3 -Ili btransmission -o libtransmission/ratecontrol.o libtransmission/ratecontrol.c
...failed Cc libtransmission/ratecontrol.o...
Cc libtransmission/choking.o
libtransmission/choking.c: In function '__malloc':
libtransmission/choking.c:30: error: 'NULL' undeclared (first use in this functi on)
libtransmission/choking.c:30: error: (Each undeclared identifier is reported onl y once
libtransmission/choking.c:30: error: for each function it appears in.)
libtransmission/choking.c:31: warning: implicit declaration of function 'malloc'
libtransmission/choking.c:31: warning: incompatible implicit declaration of buil t-in function 'malloc'
libtransmission/choking.c: In function '__free':
libtransmission/choking.c:36: warning: implicit declaration of function 'free'
libtransmission/choking.c: At top level:
libtransmission/choking.c:43: error: expected specifier-qualifier-list before 't r_lock_t'
libtransmission/choking.c:48: error: expected '=', ',', ';', 'asm' or '__attribu te__' before '*' token
libtransmission/choking.c:60: error: expected ')' before '*' token
libtransmission/choking.c:78: error: expected ')' before '*' token
libtransmission/choking.c:134: error: expected ')' before '*' token
libtransmission/choking.c:326: error: expected ')' before '*' token
/home/frsc/downloads/ds-0.2.9_26-12/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -W -Wall -pipe -Wa,--trap -msoft-float -mips32 -mtune=mips32 -O3 -Ili btransmission -o libtransmission/choking.o libtransmission/choking.c
...failed Cc libtransmission/choking.o...
...skipped libtransmission.a for lack of libtransmission.a(transmission.o)...
Cc transmissioncli.o
transmissioncli.c: In function 'main':
transmissioncli.c:67: error: 'VERSION_STRING' undeclared (first use in this func tion)
transmissioncli.c:67: error: (Each undeclared identifier is reported only once
transmissioncli.c:67: error: for each function it appears in.)
/home/frsc/downloads/ds-0.2.9_26-12/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -W -Wall -pipe -Wa,--trap -msoft-float -mips32 -mtune=mips32 -O3 -I. -I./libtransmission -o transmissioncli.o transmissioncli.c
...failed Cc transmissioncli.o...
...skipped transmissioncli for lack of transmissioncli.o...
...failed updating 15 targets...
...skipped 2 targets...
...updated 1 target...
make: *** [source/Transmission-0.5/transmissioncli] Error 1
frsc@brainfuck:~/downloads/ds-0.2.9_26-12>
Hm, das Problem hab ich nicht. Mach mal "make transmission-dirclean" und "make transmission-precompiled". Kommt der Fehler wieder?
MfG Oliver
Oh, wenn ich das mache, dann kommen fast nur errors (Hier mal ein Auszug vom Anfang)
tar -C source -v -xzf dl/Transmission-0.5.tar.gz
Transmission-0.5/
Transmission-0.5/AUTHORS
Transmission-0.5/beos/
Transmission-0.5/beos/libPrefs/
Transmission-0.5/beos/libPrefs/libPrefs.a
Transmission-0.5/beos/libPrefs/Prefs.h
Transmission-0.5/beos/makefile
Transmission-0.5/beos/Transmission.rsrc
Transmission-0.5/beos/TRApplication.cpp
Transmission-0.5/beos/TRApplication.h
Transmission-0.5/beos/TRInfoWindow.cpp
Transmission-0.5/beos/TRInfoWindow.h
Transmission-0.5/beos/TRPrefsWindow.cpp
Transmission-0.5/beos/TRPrefsWindow.h
Transmission-0.5/beos/TRTransfer.cpp
Transmission-0.5/beos/TRTransfer.h
Transmission-0.5/beos/TRWindow.cpp
Transmission-0.5/beos/TRWindow.h
Transmission-0.5/configure
Transmission-0.5/gtk/
Transmission-0.5/gtk/conf.c
Transmission-0.5/gtk/conf.h
Transmission-0.5/gtk/dialogs.c
Transmission-0.5/gtk/dialogs.h
Transmission-0.5/gtk/Jamfile
Transmission-0.5/gtk/main.c
Transmission-0.5/gtk/po/
Transmission-0.5/gtk/po/infiles
Transmission-0.5/gtk/po/transmission-gtk.pot
Transmission-0.5/gtk/trcellrenderertorrent.c
Transmission-0.5/gtk/trcellrenderertorrent.h
Transmission-0.5/gtk/util.c
Transmission-0.5/gtk/util.h
Transmission-0.5/Jamfile
Transmission-0.5/Jamrules
Transmission-0.5/libtransmission/
Transmission-0.5/libtransmission/bencode.c
Transmission-0.5/libtransmission/bencode.h
Transmission-0.5/libtransmission/choking.c
Transmission-0.5/libtransmission/choking.h
Transmission-0.5/libtransmission/clients.c
Transmission-0.5/libtransmission/clients.h
Transmission-0.5/libtransmission/completion.c
Transmission-0.5/libtransmission/completion.h
Transmission-0.5/libtransmission/fastresume.h
Transmission-0.5/libtransmission/fdlimit.c
Transmission-0.5/libtransmission/fdlimit.h
Transmission-0.5/libtransmission/inout.c
Transmission-0.5/libtransmission/inout.h
Transmission-0.5/libtransmission/internal.h
Transmission-0.5/libtransmission/Jamfile
Transmission-0.5/libtransmission/metainfo.c
Transmission-0.5/libtransmission/metainfo.h
Transmission-0.5/libtransmission/net.c
Transmission-0.5/libtransmission/net.h
Transmission-0.5/libtransmission/peer.c
Transmission-0.5/libtransmission/peer.h
Transmission-0.5/libtransmission/peermessages.h
Transmission-0.5/libtransmission/peerparse.h
Transmission-0.5/libtransmission/peerutils.h
Transmission-0.5/libtransmission/platform.c
Transmission-0.5/libtransmission/platform.h
Transmission-0.5/libtransmission/ratecontrol.c
Transmission-0.5/libtransmission/ratecontrol.h
Transmission-0.5/libtransmission/sha1.c
Transmission-0.5/libtransmission/sha1.h
Transmission-0.5/libtransmission/tracker.c
Transmission-0.5/libtransmission/tracker.h
Transmission-0.5/libtransmission/transmission.c
Transmission-0.5/libtransmission/transmission.h
Transmission-0.5/libtransmission/utils.c
Transmission-0.5/libtransmission/utils.h
Transmission-0.5/LICENSE
Transmission-0.5/macosx/
Transmission-0.5/macosx/Applescript/
Transmission-0.5/macosx/Applescript/Torrents_folder_action.scpt
Transmission-0.5/macosx/Badger.h
Transmission-0.5/macosx/Badger.m
Transmission-0.5/macosx/Controller.h
Transmission-0.5/macosx/Controller.m
Transmission-0.5/macosx/Defaults.plist
Transmission-0.5/macosx/English.lproj/
Transmission-0.5/macosx/English.lproj/InfoPlist.strings
Transmission-0.5/macosx/English.lproj/MainMenu.nib/
Transmission-0.5/macosx/English.lproj/MainMenu.nib/classes.nib
Transmission-0.5/macosx/English.lproj/MainMenu.nib/info.nib
Transmission-0.5/macosx/English.lproj/MainMenu.nib/keyedobjects.nib
Transmission-0.5/macosx/Images/
Transmission-0.5/macosx/Images/Badge.png
Transmission-0.5/macosx/Images/DownloadBadge.png
Transmission-0.5/macosx/Images/Info.png
Transmission-0.5/macosx/Images/Network.png
Transmission-0.5/macosx/Images/Open.png
Transmission-0.5/macosx/Images/PauseAll.png
Transmission-0.5/macosx/Images/PauseOff.png
Transmission-0.5/macosx/Images/PauseOn.png
Transmission-0.5/macosx/Images/Preferences.png
Transmission-0.5/macosx/Images/Progress.png
Transmission-0.5/macosx/Images/Remove.png
Transmission-0.5/macosx/Images/ResumeAll.png
Transmission-0.5/macosx/Images/ResumeOff.png
Transmission-0.5/macosx/Images/ResumeOn.png
Transmission-0.5/macosx/Images/RevealOff.png
Transmission-0.5/macosx/Images/RevealOn.png
Transmission-0.5/macosx/Images/Transmission.icns
Transmission-0.5/macosx/Images/TransmissionDocument.icns
Transmission-0.5/macosx/Images/UploadBadge.png
Transmission-0.5/macosx/Info.plist.in
Transmission-0.5/macosx/main.m
Transmission-0.5/macosx/NameCell.h
Transmission-0.5/macosx/NameCell.m
Transmission-0.5/macosx/PrefsController.h
Transmission-0.5/macosx/PrefsController.m
Transmission-0.5/macosx/ProgressCell.h
Transmission-0.5/macosx/ProgressCell.m
Transmission-0.5/macosx/StringAdditions.h
Transmission-0.5/macosx/StringAdditions.m
Transmission-0.5/macosx/Torrents_folder_action.scpt
Transmission-0.5/macosx/TorrentTableView.h
Transmission-0.5/macosx/TorrentTableView.m
Transmission-0.5/macosx/Transmission.sdef
Transmission-0.5/macosx/Transmission.xcodeproj/
Transmission-0.5/macosx/Transmission.xcodeproj/project.pbxproj
Transmission-0.5/macosx/Transmission_Prefix.pch
Transmission-0.5/macosx/Utils.h
Transmission-0.5/NEWS
Transmission-0.5/README
Transmission-0.5/transmissioncli.c
for i in make/transmission/patches/*.patch; do \
patch -d source/Transmission-0.5 -p0 < $i; \
done
patching file configure
patching file libtransmission/choking.c
touch source/Transmission-0.5/.unpacked
( cd source/Transmission-0.5; \
PATH="/home/frsc/downloads/ds-0.2.9_26-12/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin" \
CC="/home/frsc/downloads/ds-0.2.9_26-12/toolchain/target/bin/mipsel-linux-uclibc-gcc" \
CFLAGS="-Os -W -Wall -pipe -Wa,--trap -msoft-float -mips32 -mtune=mips32" \
CPPFLAGS="-I/home/frsc/downloads/ds-0.2.9_26-12/toolchain/target/bin/../usr/include" \
LDFLAGS="-static-libgcc -L/home/frsc/downloads/ds-0.2.9_26-12/toolchain/target/bin/../usr/lib" \
./configure \
--prefix=/usr \
--disable-gtk \
System: Linux
OpenSSL: no, using built-in SHA1 implementation
GTK+: no
To build Transmission, run 'jam'.
touch source/Transmission-0.5/.configured
jam \
libtransmission/Jamfile:9: in SubInclude
warning: unknown rule ObjectDefines
Jamfile:60: in module scope
...patience...
...found 200 targets...
...updating 18 targets...
Cc libtransmission/transmission.o
libtransmission/transmission.c: In function 'tr_init':
libtransmission/transmission.c:43: warning: implicit declaration of function 'calloc'
libtransmission/transmission.c:43: warning: incompatible implicit declaration of built-in function 'calloc'
libtransmission/transmission.c:43: error: invalid application of 'sizeof' to incomplete type 'tr_handle_t'
libtransmission/transmission.c:48: warning: implicit declaration of function 'sprintf'
libtransmission/transmission.c:48: warning: incompatible implicit declaration of built-in function 'sprintf'
libtransmission/transmission.c:48: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:48: error: 'VERSION_MAJOR' undeclared (first use in this function)
libtransmission/transmission.c:48: error: (Each undeclared identifier is reported only once
libtransmission/transmission.c:48: error: for each function it appears in.)
libtransmission/transmission.c:48: error: 'VERSION_MINOR' undeclared (first use in this function)
libtransmission/transmission.c:51: warning: implicit declaration of function 'tr_rand'
libtransmission/transmission.c:52: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:59: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:63: warning: implicit declaration of function 'signal'
libtransmission/transmission.c:63: error: 'SIGPIPE' undeclared (first use in this function)
libtransmission/transmission.c:63: error: 'SIG_IGN' undeclared (first use in this function)
libtransmission/transmission.c:66: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:66: warning: implicit declaration of function 'tr_rcInit'
libtransmission/transmission.c:67: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:68: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:68: warning: implicit declaration of function 'tr_fdInit'
libtransmission/transmission.c:69: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:69: warning: implicit declaration of function 'tr_chokingInit'
libtransmission/transmission.c:71: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:72: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:77: warning: implicit declaration of function 'tr_fdSocketWillCreate'
libtransmission/transmission.c:77: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:80: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:80: warning: implicit declaration of function 'tr_netBind'
libtransmission/transmission.c:85: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:86: warning: implicit declaration of function 'tr_lockInit'
libtransmission/transmission.c:86: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:87: warning: implicit declaration of function 'tr_threadCreate'
libtransmission/transmission.c:87: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_setBindPort':
libtransmission/transmission.c:101: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:107: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:116: warning: implicit declaration of function 'tr_lockLock'
libtransmission/transmission.c:116: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:118: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:120: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:122: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:123: error: 'NULL' undeclared (first use in this function)
libtransmission/transmission.c:123: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:125: warning: implicit declaration of function 'tr_trackerChangePort'
libtransmission/transmission.c:125: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:127: warning: implicit declaration of function 'tr_lockUnlock'
libtransmission/transmission.c:127: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:130: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:132: warning: implicit declaration of function 'tr_netClose'
libtransmission/transmission.c:132: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:133: warning: implicit declaration of function 'tr_fdSocketClosed'
libtransmission/transmission.c:133: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:136: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:138: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_setUploadLimit':
libtransmission/transmission.c:148: warning: implicit declaration of function 'tr_rcSetLimit'
libtransmission/transmission.c:148: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:149: warning: implicit declaration of function 'tr_chokingSetLimit'
libtransmission/transmission.c:149: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_torrentRates':
libtransmission/transmission.c:159: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:159: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:164: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:166: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:169: warning: implicit declaration of function 'tr_rcRate'
libtransmission/transmission.c: In function 'tr_torrentInit':
libtransmission/transmission.c:183: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:183: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:188: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:190: warning: implicit declaration of function 'tr_err'
libtransmission/transmission.c:194: warning: incompatible implicit declaration of built-in function 'calloc'
libtransmission/transmission.c:198: warning: implicit declaration of function 'tr_metainfoParse'
libtransmission/transmission.c:200: warning: implicit declaration of function 'free'
libtransmission/transmission.c:205: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:207: warning: implicit declaration of function 'memcmp'
libtransmission/transmission.c:207: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:217: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:218: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:223: warning: implicit declaration of function 'strchr'
libtransmission/transmission.c:223: warning: incompatible implicit declaration of built-in function 'strchr'
libtransmission/transmission.c:229: warning: implicit declaration of function 'strncmp'
libtransmission/transmission.c:232: warning: implicit declaration of function 'strlen'
libtransmission/transmission.c:232: warning: incompatible implicit declaration of built-in function 'strlen'
libtransmission/transmission.c:233: warning: implicit declaration of function 'memcpy'
libtransmission/transmission.c:233: warning: incompatible implicit declaration of built-in function 'memcpy'
libtransmission/transmission.c:234: warning: incompatible implicit declaration of built-in function 'sprintf'
libtransmission/transmission.c:241: warning: incompatible implicit declaration of built-in function 'sprintf'
libtransmission/transmission.c:245: warning: implicit declaration of function 'MIN'
libtransmission/transmission.c:248: warning: implicit declaration of function 'tr_cpInit'
libtransmission/transmission.c:252: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:253: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:254: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:259: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:260: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:261: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:262: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_torrentScrape':
libtransmission/transmission.c:275: warning: implicit declaration of function 'tr_trackerScrape'
libtransmission/transmission.c:275: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_torrentSetFolder':
libtransmission/transmission.c:280: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:280: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:280: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:282: warning: implicit declaration of function 'strdup'
libtransmission/transmission.c:282: warning: incompatible implicit declaration of built-in function 'strdup'
libtransmission/transmission.c: In function 'tr_torrentGetFolder':
libtransmission/transmission.c:287: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:287: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:287: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_torrentStart':
libtransmission/transmission.c:294: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:294: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:294: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:303: warning: implicit declaration of function 'tr_trackerInit'
libtransmission/transmission.c:305: warning: implicit declaration of function 'tr_date'
libtransmission/transmission.c: In function 'tr_torrentStop':
libtransmission/transmission.c:312: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:312: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:312: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:315: warning: implicit declaration of function 'tr_trackerStopped'
libtransmission/transmission.c:316: warning: implicit declaration of function 'tr_rcReset'
libtransmission/transmission.c: In function 'torrentReallyStop':
libtransmission/transmission.c:330: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:330: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:330: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:333: warning: implicit declaration of function 'tr_threadJoin'
libtransmission/transmission.c:334: warning: implicit declaration of function 'tr_dbg'
libtransmission/transmission.c:336: warning: implicit declaration of function 'tr_trackerClose'
libtransmission/transmission.c:340: warning: implicit declaration of function 'tr_peerRem'
libtransmission/transmission.c: In function 'tr_torrentCount':
libtransmission/transmission.c:351: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_getFinished':
libtransmission/transmission.c:356: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_setFinished':
libtransmission/transmission.c:360: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_torrentStat':
libtransmission/transmission.c:366: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:366: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:370: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:372: error: 'NULL' undeclared (first use in this function)
libtransmission/transmission.c:376: warning: implicit declaration of function 'malloc'
libtransmission/transmission.c:376: warning: incompatible implicit declaration of built-in function 'malloc'
libtransmission/transmission.c:376: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:378: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:380: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:393: warning: incompatible implicit declaration of built-in function 'memcpy'
libtransmission/transmission.c:403: warning: implicit declaration of function 'tr_peerIsConnected'
libtransmission/transmission.c:406: warning: implicit declaration of function 'tr_peerIsUploading'
libtransmission/transmission.c:410: warning: implicit declaration of function 'tr_peerIsDownloading'
libtransmission/transmission.c:417: warning: implicit declaration of function 'tr_cpCompletionAsFloat'
libtransmission/transmission.c:428: warning: implicit declaration of function 'tr_trackerSeeders'
libtransmission/transmission.c:429: warning: implicit declaration of function 'tr_trackerLeechers'
libtransmission/transmission.c:449: warning: implicit declaration of function 'tr_cpPieceIsComplete'
libtransmission/transmission.c:459: warning: implicit declaration of function 'tr_peerBitfield'
libtransmission/transmission.c:460: warning: implicit declaration of function 'tr_bitfieldHas'
libtransmission/transmission.c:476: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_torrentClose':
libtransmission/transmission.c:486: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:486: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:486: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:495: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:497: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:499: warning: implicit declaration of function 'tr_lockClose'
libtransmission/transmission.c:500: warning: implicit declaration of function 'tr_cpClose'
libtransmission/transmission.c:502: warning: implicit declaration of function 'tr_rcClose'
libtransmission/transmission.c:513: warning: implicit declaration of function 'memmove'
libtransmission/transmission.c:513: warning: incompatible implicit declaration of built-in function 'memmove'
libtransmission/transmission.c:513: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:514: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:516: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'tr_close':
libtransmission/transmission.c:522: warning: implicit declaration of function 'tr_chokingClose'
libtransmission/transmission.c:522: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:523: warning: implicit declaration of function 'tr_fdClose'
libtransmission/transmission.c:523: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:524: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:525: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'downloadLoop':
libtransmission/transmission.c:534: error: 'tr_torrent_t' undeclared (first use in this function)
libtransmission/transmission.c:534: error: 'tor' undeclared (first use in this function)
libtransmission/transmission.c:547: warning: implicit declaration of function 'tr_cpReset'
libtransmission/transmission.c:548: warning: implicit declaration of function 'tr_ioInit'
libtransmission/transmission.c:549: warning: implicit declaration of function 'tr_cpIsSeeding'
libtransmission/transmission.c:563: warning: implicit declaration of function 'tr_trackerCompleted'
libtransmission/transmission.c:564: warning: implicit declaration of function 'tr_ioSaveResume'
libtransmission/transmission.c:568: warning: implicit declaration of function 'tr_peerPulse'
libtransmission/transmission.c:571: warning: implicit declaration of function 'tr_trackerPulse'
libtransmission/transmission.c:583: warning: implicit declaration of function 'tr_wait'
libtransmission/transmission.c:590: warning: implicit declaration of function 'tr_ioClose'
libtransmission/transmission.c: In function 'acceptLoop':
libtransmission/transmission.c:615: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:617: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:622: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:623: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:623: error: 'TR_MAX_PEER_COUNT' undeclared (first use in this function)
libtransmission/transmission.c:624: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:627: error: storage size of 'addr' isn't known
libtransmission/transmission.c:628: error: 'in_port_t' undeclared (first use in this function)
libtransmission/transmission.c:628: error: expected ';' before 'port'
libtransmission/transmission.c:629: warning: implicit declaration of function 'tr_netAccept'
libtransmission/transmission.c:629: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:629: error: 'port' undeclared (first use in this function)
libtransmission/transmission.c:632: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:632: warning: implicit declaration of function 'tr_peerInit'
libtransmission/transmission.c:636: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:627: warning: unused variable 'addr'
libtransmission/transmission.c:640: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:642: warning: implicit declaration of function 'tr_peerRead'
libtransmission/transmission.c:642: error: 'NULL' undeclared (first use in this function)
libtransmission/transmission.c:642: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:644: warning: implicit declaration of function 'tr_peerDestroy'
libtransmission/transmission.c:644: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:647: warning: implicit declaration of function 'tr_peerHash'
libtransmission/transmission.c:647: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:647: warning: assignment makes pointer from integer without a cast
libtransmission/transmission.c:649: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:651: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:652: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:655: warning: implicit declaration of function 'tr_peerAttach'
libtransmission/transmission.c:655: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:656: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:659: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:661: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:667: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:668: warning: incompatible implicit declaration of built-in function 'memmove'
libtransmission/transmission.c:668: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:669: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:669: error: 'tr_peer_t' undeclared (first use in this function)
libtransmission/transmission.c:669: error: expected expression before ')' token
libtransmission/transmission.c:674: warning: implicit declaration of function 'tr_chokingPulse'
libtransmission/transmission.c:674: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:682: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:684: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:688: error: dereferencing pointer to incomplete type
libtransmission/transmission.c: In function 'acceptStop':
libtransmission/transmission.c:702: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:703: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:704: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:707: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:709: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:712: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:714: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:715: error: dereferencing pointer to incomplete type
libtransmission/transmission.c:477: warning: control reaches end of non-void function
libtransmission/transmission.c:357: warning: control reaches end of non-void function
libtransmission/transmission.c:352: warning: control reaches end of non-void function
libtransmission/transmission.c:290: warning: control reaches end of non-void function
/home/frsc/downloads/ds-0.2.9_26-12/toolchain/target/bin/mipsel-linux-uclibc-gcc -c -Os -W -Wall -pipe -Wa,--trap -msoft-float -mips32 -mtune=mips32 -O3 -Ilibtransmission -o libtransmission/transmission.o libtransmission/transmission.c
Welche Version von jam hast du denn? (jam -v)
Ich hab 2.5.
MfG Oliver
Also ich habe
Boost.Jam Version 3.1.4. OS=LINUX.
Copyright 1993-2002 Christopher Seiwald and Perforce Software, Inc.
Copyright 2001 David Turner.
Copyright 2001-2002 David Abrahams.
Seppl
Ich hab mal gegoogelt. Und es sieht so aus als ob du auf Jam 2.5 downgraden musst...
MfG Oliver
Servus Oli,
also hab jetzt mal auf 2.5 "downgegraded" (irgendwie netter anglizismus, aber upgegraded finde ich irgendwie noch besser ;) ).
Jetzt konnte ich auch
- make transmission-dirclean
- make transmission-precompiled
durchlaufen lassen.
Ob das komplett durchläuft werden wir sehen (das dauert ja immer so lang zum compilieren).
Danke dir für die Hilfe
Seppl82
Robert Raman
