error after building image with ntfs support
Alpamayo
13 Dez 2006
Hi everybody,
Some time ago, with the guidance of Olistudent I managed to configure friboli for building an image with ntfs support for usb disks. These were his instructions:
Olistudent schrieb:
For disks larger then 2GB you have to build the Toolchain with LFS. Sorry for that.
menuconfig->Advanced options->Compiler Options->Build Toolchain and Large Files
But then you will have to build anything from scratch. I don't have another solution. Perhaps it works if you try
make toolchain-distclean
make menuconfig
rm -rf source; mkdir source
make
Since I was lately forced to reinstall, I tried to duplicate the same steps. I managed to make an image but this time I got an error while attempting to mount the partition. The commands that worked in the past are:
mkdir /var/media/ftp/uStor02
modprobe fuse
ntfs-3g /dev/sda1 /var/media/ftp/uStor02
ftpd -D
ftpd -h uStor02
This time though I got the following error after inputting the third command:
~ $ ntfs-3g /dev/sda1 /var/media/ftp/uStor02
Error opening partition device: No such device or address
Failed to startup volume: No such device or address
Failed to mount '/dev/sda1': No such device or address
You seem to have a SoftRAID/FakeRAID hardware and must use an activated,
different device under /dev/mapper/, (e.g. /dev/mapper/nvidia_eahaabcc1)
to mount NTFS. Please see the 'dmraid' documentation for help.
Here is some other info:
BusyBox v1.5.1 (2007-10-13 22:58:07 CEST) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
ermittle die aktuelle TTY
tty is "/dev/pts/0"
Console Ausgaben auf dieses Terminal umgelenkt
~ $ cat /proc/partitions
major minor  #blocks  name
  31     0       8192 mtdblock0
  31     1       6962 mtdblock1
  31     2       7616 mtdblock2
  31     3         64 mtdblock3
  31     4        256 mtdblock4
  31     5        256 mtdblock5
  31     6       2048 mtdblock6
  31     7       5568 mtdblock7
~ $ lsmod
Module                  Size  Used by    Tainted: P
kdsldmod              585648  2
usbahcicore            26064  0
usbcore               113232  2 usbahcicore
isdn_fbox_fon4        905168  0
ubik2                  74848  3 isdn_fbox_fon4
tiatm                 107904  1 ubik2
Piglet                  9312  0
~ $ dmesg
 net_olddevs_init+0x0/0x100()
Calling initcall 0x941fdfe4: tun_init+0x0/0x90()
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Calling initcall 0x941fe0bc: cmdline_parser_init+0x0/0xc()
Calling initcall 0x941fe0c8: init_mtdchar+0x0/0xc0()
Calling initcall 0x941fe188: init_mtdblock+0x0/0xc()
Calling initcall 0x941fe194: cfi_probe_init+0x0/0x24()
Calling initcall 0x941fe1b8: cfi_amdstd_init+0x0/0x30()
Calling initcall 0x941fe1e8: cfi_intelext_init+0x0/0x4c()
Calling initcall 0x941fe234: jedec_probe_init+0x0/0x24()
Calling initcall 0x941fe258: map_ram_init+0x0/0x24()
Calling initcall 0x941fe27c: init_physmap+0x0/0x180()
physmap flash device: 400000 at 10000000
phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank
 Amd/Fujitsu Extended Query Table at 0x0040
phys_mapped_flash: Swapping erase regions for broken CFI table.
number of CFI chips: 1
RedBoot partition parsing not available
Calling initcall 0x941fe3fc: platram_init+0x0/0x30()
Generic platform RAM MTD, (c) 2004 Simtec Electronics
Calling initcall 0x941fe42c: init_ohio_flash+0x0/0x868()
Ohio flash driver (size->0x400000 mem->0x10000000)
flash_size=0x800000
flash_mask=0xffffff
Ohio flash memory: Found 1 x16 devices at 0x0 in 16-bit bank
[genprobe_ident_chips] 4 i 0 j 0
[genprobe_ident_chips] 5 i 0 j 1
Ohio flash memory: Swapping erase regions for broken CFI table.
[mtd]: set to default: jffs2_size = 0x20 * 64KByte (0x200000 Bytes)
[ohio_find_hidden_filesystem]: super block found: bytes_used: 0x41ba6d/4307565
[init_ohio_flash] find hidden filesystem size=0x6ccb00 offset=0xb3500
[mtd] configure jffs2 partition
[mtd] fs_size=0x4c0000 max=0x2b0000 is=0x200000 max jffs2_size value 43
[mtd] ohio_flash_map: name=Ohio flash memory bankwidth=2 virt=0xb0000000 phys=0x10000000 size=0
x800000
Creating 7 MTD partitions on "Ohio flash memory":
0x000b3500-0x00780000 : "filesystem"
        'nor-flash'
        'Bits can be cleared (flash)'
        'Has an erase function'
mtd: partition "filesystem" doesn't start on an erase block boundary -- force read-only
0x00010000-0x00780000 : "kernel"
        'nor-flash'
0x00000000-0x00010000 : "bootloader"
        'nor-flash'
0x00780000-0x007c0000 : "tffs (1)"
        'nor-flash'
0x007c0000-0x00800000 : "tffs (2)"
        'nor-flash'
0x00580000-0x00780000 : "jffs2"
        'nor-flash'
0x00010000-0x00580000 : "Kernel without jffs2"
        'nor-flash'
partition_info[0]: name=filesystem offset=b3500 size=6ccb00
partition_info[0]: 0xb00b3500: 0x73717368 0xa81
partition_info[1]: name=kernel offset=10000 size=770000
partition_info[1]: 0xb0010000: 0xfeed1281 0xa34e1
partition_info[2]: name=bootloader offset=0 size=10000
partition_info[2]: 0xb0000000: 0x40809000 0x40809800
partition_info[3]: name=tffs (1) offset=780000 size=40000
partition_info[3]: 0xb0780000: 0x40001 0xfdffffff
partition_info[4]: name=tffs (2) offset=7c0000 size=40000
partition_info[4]: 0xb07c0000: 0x40001 0xfeffffff
partition_info[5]: name=jffs2 offset=580000 size=200000
partition_info[5]: 0xb0580000: 0xffffffff 0xffffffff
partition_info[6]: name=Kernel without jffs2 offset=10000 size=570000
partition_info[6]: 0xb0010000: 0xfeed1281 0xa34e1
Calling initcall 0x941fee74: kcapi_init+0x0/0x9c()
Calling initcall 0x941fefb8: capi_oslib_init+0x0/0x8()
Calling initcall 0x941ffa98: blackhole_module_init+0x0/0xc()
Calling initcall 0x942007f4: inet_init+0x0/0x504()
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
Calling initcall 0x9420321c: init+0x0/0x8()
Calling initcall 0x94203224: bictcp_register+0x0/0xc()
TCP bic registered
Calling initcall 0x94203230: mcfw_init_module+0x0/0x2c()
mcfw: IGMPv3 fast forwarding
Calling initcall 0x9420325c: af_unix_init+0x0/0xa0()
NET: Registered protocol family 1
Calling initcall 0x942032fc: packet_init+0x0/0x80()
NET: Registered protocol family 17
Calling initcall 0x9420337c: br_init+0x0/0x68()
Calling initcall 0x94203438: atm_init+0x0/0xec()
NET: Registered protocol family 8
NET: Registered protocol family 20
Calling initcall 0x942035dc: br2684_init+0x0/0x54()
Calling initcall 0x94203630: vlan_proto_init+0x0/0xf4()
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
Calling initcall 0x941ee028: ohio_install_dummy_irq_functions+0x0/0x58()
[setup_irq]: irq 1 irqaction->handler 0x94001590 (dummy_timer_irq+0x0/0x14 )
[setup_irq]: irq 6 irqaction->handler 0x940015a4 (dummy_system_irq_2+0x0/0x14 )
Calling initcall 0x940017e4: ohio_late_init+0x0/0x3c()
[ohio_late_init]
Calling initcall 0x941ee164: ohio_clk_switch_init+0x0/0x60()
Calling initcall 0x941ee3e0: speedup_init+0x0/0x3c()
Calling initcall 0x941fb9c0: seqgen_init+0x0/0x20()
Calling initcall 0x940cf760: avm_event_push_button_init+0x0/0x130()
[avm_new] push_button_gpio=8 value=1 enabled
Calling initcall 0x941fc9f0: tffs_init+0x0/0x224()
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
      mount on mtd4 and mtd5 (double buffering)
Adam2 environment variables API installed.
Calling initcall 0x941fd840: early_uart_console_switch+0x0/0xb4()
Calling initcall 0x94123dc8: net_random_reseed+0x0/0x34()
Calling initcall 0x94201d14: ip_auto_config+0x0/0x1130()
[prepare_namespace] new mount root /dev/mtdblock1
use lzma compression
VFS: Mounted root (squashfs filesystem) readonly.
Freeing prom memory: 0kb freed
Freeing unused kernel memory: 116k freed (7579 free)
[setup_irq]: irq 15 irqaction->handler 0x940d951c (serial8250_interrupt+0x0/0x13c )
AR7WDT: System Init UEberwachung 120 Sekunden
TFFS Name Table 9
Piglet: module license '
(C) Copyright 2005 by AVM
' taints kernel.
[avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=8000 key=button_key_3
EMIF: asize=1 ta=3 r_hold=0 w_strobe=6 r_strobe=6 ew=1
registered device TI Avalanche SAR
tiatm driver (patch_annex=0xc0056eec)
[tiatm] Set StrictPriority=0
DSP binary filesize = 326336 bytes
[tiatm] INFO V2U-BRIDGEREGISTER: 0x00000019
[setup_irq]: irq 23 irqaction->handler 0xc003e208 (tn7atm_sar_irq+0x0/0x30 [tiatm] )
[setup_irq]: irq 31 irqaction->handler 0xc003e238 (tn7atm_dsl_irq+0x0/0x28 [tiatm] )
[tiatm]: Powermanagment (States => 1,3,10) supported!
Texas Instruments ATM driver: version:[4.06.04.45]
[avm_power]PowerManagmentActivatePowerMode: cant find powermode: 'atm_profile_on'<3>[avm_power]
PowerManagmentActivatePowerMode: cant find powermode: 'atm_profile_off'ubik2 driver (ubik2 - 0x
10=0xc006ab94)
atm_dsp_register_ubik2: ubik2_ToMIPS_notify=0xc005abfc
atm_dsp_register_ubik2: dsp mem pointer 0xa1c10ab4
ubik2_init_interface: DSP-Link Version v3 8480
driver params overwritten io_addr=0x0 irq_num=0
PowerManagmentActivatePowerMode: cant find powermode: 'atm_profile_off'<6>usbcore: registered n
ew driver usbfs
usbcore: registered new driver hub
        AHCI RevisionID = 0x02, RamSize = 16384, NumPorts= 1
[setup_irq]: irq 9 irqaction->handler 0xc0034490 (ahci_irq+0x0/0x880 [usbahcicore] )
ahci : new USB bus registered, assigned bus number 1
kdsldmod: init start (Jul  2 2007 10:28:23) sizeof(struct sk_buff)=176
kdsldmod: init done
kdsld: PPP led: off (value=0)
[tiatm] DSL in training!
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
PowerManagmentActivatePowerMode: cant find powermode: 'atm_profile_off'<6>usb 1-1: new full spe
ed USB device using ahci and address 2
[avm_power] : ethernet not registered
[ohio_vlynq_init] device 0
[ohio_vlynq_startup_link]
[setup_irq]: irq 29 irqaction->handler 0x9400574c (vlynq_interrupt+0x0/0x34 )
[setup_irq]: irq 79 irqaction->handler 0xc028bfac (tiwlan_ddaSrand+0x8/0x30 [tiap] )
SCSI subsystem initialized
Initializing USB Mass Storage driver...
USB Mass Storage device (0553:0677) detected...
scsi0 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
PowerManagmentActivatePowerMode: cant find powermode: 'atm_profile_off'<3>[avm_power]PowerManag
mentActivatePowerMode: cant find powermode: 'atm_profile_on'<3>[avm_power]PowerManagmentActivat
ePowerMode: cant find powermode: 'atm_profile_off'<3>[cpmac] cpmac_main_ioctl, unknown ioctl 35
142
device eth0 entered promiscuous mode
[setup_irq]: irq 27 irqaction->handler 0x940ea22c (cpmac_main_isr+0x0/0x78 )
lan: port 1(eth0) entering learning state
lan: topology change detected, propagating
lan: port 1(eth0) entering forwarding state
  Vendor: Generic   Model: Mass Storage      Rev: 1.00
  Type:   Direct-Access                      ANSI SCSI revision: 00
SCSI device sda: 256000 512-byte hdwr sectors (131 MB)
device tiwlan0 entered promiscuous mode
lan: port 2(tiwlan0) entering learning state
lan: port 2(tiwlan0) entering forwarding state
device wdsup0 entered promiscuous mode
lan: port 3(wdsup0) entering learning state
lan: port 3(wdsup0) entering forwarding state
device wdsdw0 entered promiscuous mode
lan: port 4(wdsdw0) entering learning state
lan: port 4(wdsdw0) entering forwarding state
device wdsdw1 entered promiscuous mode
lan: port 5(wdsdw1) entering learning state
lan: port 5(wdsdw1) entering forwarding state
device wdsdw2 entered promiscuous mode
lan: port 6(wdsdw2) entering learning state
lan: port 6(wdsdw2) entering forwarding state
device wdsdw3 entered promiscuous mode
lan: port 7(wdsdw3) entering learning state
lan: port 7(wdsdw3) entering forwarding state
AR7WDT: System Init UEberwachung abgeschlossen (87610 ms noch verfuegbar)
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=99
 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=10
0 mul=154 div=10 offset=974 NormP=2514 mW -> SumNormP=2514 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate
=83 mul=65 div=10 offset=1793 NormP=2443 mW -> SumNormP=4957 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=6 mul=
84 div=10 offset=100 NormP=940 mW -> SumNormP=5897 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mu
l=1 div=1 offset=0 NormP=100 mW -> SumNormP=5997 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=200 act_rate=0 mu
l=141 div=10 offset=100 NormP=2920 mW -> SumNormP=8917 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=
0 div=1 offset=0 NormP=0 mW -> SumNormP=8917 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=67 act_rate=0 m
ul=1 div=1 offset=50 NormP=117 mW -> SumNormP=9034 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=0 mul=0
 div=1 offset=0 NormP=0 mW -> SumNormP=9034 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=10
0 mul=55 div=10 offset=50 NormP=2800 mW -> SumNormP=11834 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_client: norm_power_rate=0 act_rate=0
mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=11834 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=91
 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=12107 mW
[avm_power] format error: "MODE = <powermode>"
available powermode:dsl,ata,vdsl,update,fastspeed,normalspeed,slowspeed,telefon_profile_on,tele
fon_profile_off,
SysRq : Changing Loglevel
Loglevel set to 4
ePowerMode: cant find powermode: 'atm_profile_off'[tiatm] DSL in Sync
kdsld: showtime
kdsld: unsetup done.
kdsld: VCC 0: registered (8/35)
kdsld: 0:  VPI/VCI 8/35 PPPoE internet 00:15:0c:fd:82:cb (32,0) mc upstream
kdsld: internet: set_rcv_ipaddr: 169.254.2.1
kdsld: dsl: registered
kdsld: setup done.
kdsld_token_thread: start
kdsld: Channel 0 up (physical outgoing)
kdsld: internet: set_snd_ipaddr: xxx.xxx.xxx.xxx
kdsld: internet: set_snd_mtu: 1492
kdsld: internet: connected
mcfw: forward enabled (vcc0: 00:15:0c:fd:82:cb, vlan 0, pppoe 28190)
kdsld: PPP led: on (value=1)
usb_unlink_urb() is deprecated for synchronous unlinks.  Use usb_kill_urb() instead.
usb 1-1: reset full speed USB device using ahci and address 2
sda: test WP failed, assume Write Enabled
sda: assuming drive cache: write through
 sda:
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
usb-storage: device scan complete
[cpmac] cpmac_main_dev_send, drop short pkt (14)
[cpmac] cpphy_if_tx_complete, 14 bytes dropped (9)
usb 1-1: USB disconnect, address 2
usbcore: deregistering driver usb-storage
[speedup] -> 62.5 MHz
[speedup] -> 125 MHz
[avm_new]push_button 'Wlan-Taster' presses: GPIO=8 time=492633
[avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=500 key=button_key_1
lan: port 2(tiwlan0) entering disabled state
lan: port 3(wdsup0) entering disabled state
lan: port 4(wdsdw0) entering disabled state
lan: port 5(wdsdw1) entering disabled state
lan: port 6(wdsdw2) entering disabled state
lan: port 7(wdsdw3) entering disabled state
Trying to free IRQ79
device tiwlan0 left promiscuous mode
kdsld: kdsld_fastforward_device_gone(tiwlan0): 1 entries invalidated
device wdsup0 left promiscuous mode
device wdsdw0 left promiscuous mode
device wdsdw1 left promiscuous mode
device wdsdw2 left promiscuous mode
device wdsdw3 left promiscuous mode
I'm not a Linux expert so please bear with me.
Thanks for helping.
Alpamayo
Two things:
1. I can't see scsi_mod, sg and sg_mod module in lsmod?
2.
Alpamayo schrieb:
...usb 1-1: USB disconnect, address 2
usbcore: deregistering driver usb-storage...
Are you sure that this firmware is exactely the same as the one from the last try?
Greets Oliver
olistudent schrieb:
Two things:
2.
Greets Oliver
Oli,
I only tried to replicate what I did. Luckily I had our PMs to follow. I just did not patch it with the vfat-fix.patch.bz2 that addressed the bug on the usb port. But since I can read fat disks I don't think that is the issue.
Other instructions you gave me were: apt-get install pkg-config and make fuse-dirclean because I had some errors. But then when you realized I wanted to read ntfs lager than 2GB you made me rebuild the kernel.
And that is it.
Alpamayo
Can you please apply this patch and build a new firmware without "replace kernel"? Just to see if it is working.
Greets Oliver
Ok.
When I applied the patch (as root) it replied as if one of the two changes had already been done, or something.
I made the image by just unflagging the "Replace kernel" and leaving the previous options enabled.
Again this image can read fat disks but not ntfs. It seems to me as if nothing changed from the previous image.
If you ask, I can reinstall friboli all over again and procede from there.
Alpamayo
Ok. I started all over with a new machine.
1. Applied vfat-fix.patch.bz2: OK
2. Created first normal image: OK
3. - Selected Brandings > AVM
- Patch enum
- Patch web menu etc.
- Patch usb storage names
- Package Selections > Testing > NTFS-3G
(and Fuse was auto-selected as well)
- Advanced Options > Verbosity level 2
4. Saved and did "make"
5. Failed with the pkgconfig error. But I knew it. So I created the dir, issued also a make fuse-dirclean and finally under root entered: apt-get install pkg-config.
6. This time the image was created correctly.
Again: FAT support: yes
NTFS support: no.
I did NOT choose Build Toolchain nor Replace kernel.
Please let me know if I'm proceeding well and what you suggest to do next.
Thank you.
Alpamayo
Can you please make a signature. I forgot which box you are creating the image for and I'm to lazy to search for it.
And check your NTFS-Disk if anything is ok with it.
Greets Oliver
Ok. Added signature. The usb ntfs disk is working fine. I just double checked it.
Thanks
But you need to choose it (build toolchain). :confused:
Greets Oliver
Fine. On to the next step. I'll just add "build toolchain" to the previous selections and nothing else?
You have to follow my advice from your first post (LFS).
Greets Oliver
Ok. I'll let you know the outcome. Thank you
Ok. To the previous settings this time I also enabled:
- Build toolchain (requires 4GB diskspace)
- Large file support (LFS) for target toolchain
I did NOT enter the following:
make menuconfig
make
I wasn't sure if I had to, so I decided to try without those commands. Probably I was wrong since I got the following error message on attemping to mount the nfts disk:
Failed to read last sector (39857201): Invalid argument
Perhaps the volume is a RAID/LDM but it wasn't setup yet, or the
wrong device was used, or the partition table is incorrect.
Failed to startup volume: Invalid argument
Failed to mount '/dev/sda1': Invalid argument
The device '/dev/sda1' doesn't have a valid NTFS.
Maybe you selected the wrong device? Or the whole disk instead of a
partition (e.g. /dev/hda, not /dev/hda1)? Or the other way around?
I also did NOT enable Replace Kernel.
What do you think?
Thanks.
Alpamayo
EDIT of october 16
This time I did all of the above INCLUDING "Replace kernel".
I did NOT do:
make menuconfig
make
After many hours' compilation it ended with the following error:
http://img138.imageshack.us/img138/6193/error1ve4.jpg
Thanks.
Perhaps you should start from scratch and select the right menuconfig options right from the start. If this doesn't work you will have to wait for ds26-15.3...
Greets Oliver
Greets Oliver
Thanks Oli. What bugs me is that for some reason I was able to make it work the last time we talked about it (via PM). I'm now struggling to replicate what I did. It's frustrating. :(
I only know that it is working if you do what I said. If not you must have maken a mistake. ;-)
If you build your toolchain, fuse and ntfs with LFS and replace kernel and all necessary modules it should work.
Greets Oliver
Ok. I'm starting over :)
Thanks
Update of oct. 17
The recompilation this time was successful. Thanks for your help and support.
Alpamayo
PS
Just a couple of memos for the next ds-mod release (just in case they escaped you - I'm sure they didn't):
1. don't forget to fix the missing pkgconfig dir creation under /toolchain/target/usr/lib/pkgconfig
2. there is a new fakeroot.181.tar on the remote ftp servers and the fakeroot.171.tar has been removed. As a consequence as soon as ds-mod attempts to download the 171 version it stops with an error.
Thanks again.
Protonator
