"Error in patch-file" beim bauen von Freetz für 7141
ParoX
16 Sep 2010
ich versuche mich gerade beim Bauen einer gefreetzten Firmware für meine FB 7141. Benutze dazu (natürlich) speed-to-fritz in der neusten Version, unter einem (frischen) 32-Bit Ubuntu 10.04. Ohne freetz klappt das Builden der Firmware (7170er 29.04.80) wunderbar.
Wenn ich Freetz aber dazu auswähle, kommt irgendwann nach Auswahl der Pakete (bei denen ich nur OpenVPN ausgewählt habe) folgende Fehlermeldung:
STEP 2: MODIFY
applying symlinks, deleting additional webinterfaces
applying patches
  applying patches (7141-de)
    applying patch file ./patches/110-multid-wait.patch
    patching file etc/init.d/rc.net
    applying patch file ./patches/110-system_status.patch
    patching file usr/bin/system_status
    applying patch file ./patches/130-fstab.patch
    patching file etc/fstab
    applying patch file ./patches/7141/100-rc.net-dnsmasq.patch
    applying patch file ./patches/7141/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    applying patch file ./patches/7141/120-rc.S-dev.patch
    applying patch file ./patches/7141/130-rc.S-logging.patch
    applying patch file ./patches/7141/140-rc.S-no_avm_exit.patch
    Hunk #1 succeeded at 1577 (offset 103 lines).
    applying patch file ./patches/7141/290-replace_websrv-remove_igdd.patch
    applying patch file ./patches/7141/301-remove_smbd.patch
    Hunk #2 succeeded at 314 (offset -11 lines).
    applying patch file ./patches/7141/400_remove_ftpd.patch
    patching file etc/hotplug/storage
    Hunk #1 succeeded at 21 (offset 8 lines).
    Hunk #2 succeeded at 194 (offset 44 lines).
    Hunk #3 succeeded at 211 (offset 44 lines).
    patching file etc/hotplug/run_mount
    applying patch file ./patches/7141/de/130-foncalls.patch
    patching file usr/www/all/html/de/home/foncalls.js
    Hunk #1 FAILED at 301.
    1 out of 1 hunk FAILED -- saving rejects to file usr/www/all/html/de/home/foncalls.js.rej
[COLOR="Yellow"][B]ERROR: modpatch: Error in patch-file ./patches/7141/de/130-foncalls.patch[/B][/COLOR]
make: *** [firmware-nocompile] Fehler 2
Könnt ihr mir sagen, wo das Problem liegt?
Danke und noch einen schönen Sonntag,
ParoX
Häng mal bitte deine .config an. Dann kann ich schauen, ob ich dich an den speed2fritz Support verweisen darf. ;-)
MfG Oliver
Hi olistudent,
Danke für die schnelle Antwort, und das an einem Sonntag... Respekt :)
Anbei meine Freetz .config.
ParoX
FREETZ_TYPE_FON_WLAN_7141=y
FREETZ_DL_SOURCE=FRITZ.Box_Fon_WLAN_7170.29.04.80.image
Wenn du als Box 7141 einstellst und dann eine Firmware der 7170 modden willst, dann kann es schon sein, dass das nicht geht. Also wende dich bitte an den s2f Support, falls das was du vorhast gehen soll.
Oder verwende Freetz und s2f, dann wirst du hier geholfen.
MfG Oliver
Hi olistudent,
Danke. Damit wir uns richtig verstehen:
Im speed2fritz habe ich als Hardware-Box die 7141 und als Zielfirmware die 29.04.80er der 7170 eingestellt. Wenn nun der Freetz-Schritt dran ist und die Config erscheint, stelle ich dort vom Hardware-Type 7170 (was voreingestellt ist) zurück auf 7141 - vielleicht liegt hier mein (!) Fehler!? Soll Freetz davon ausgehen, dass ich eine 7141 oder eine 7170 habe?
ParoX
Da ich nicht weiß was s2f mit der Firmware macht kann ich dir nicht sagen was du einstellen musst. Deshalb mein Verweis auf die s2f Leute...
Oliver
Hi ParoX,
Ich bekomme auch einen Fehler beim 'make', wenn ich ein image für den Speedport W501V auf WLAN 7141 erzeugen will. Hast du zwischenzeitlich eine Lösung bzw. weisst, woran das Problem liegt?
Danke!
Was für ein Fehler? Und wasd nutzt du? speed2fritz? Bitte dort fragen.
Looki_Luzi
