Hello all,
I am trying to connect OsmocomBB project with LCR and SofiaSIP
So i have to install LCR first. I dont need a asterisk and i want to use SofiaSIP.
At LCR
./configure --without-asterisk --with-gsm-ms --with-sip
But i loose when doing the make.
When I do 'make' it it produces following error.
mISDN.cpp:61: error: aggregate ‘mi_ext_fn_s myfn’ has incomplete type and cannot be defined
mISDN.cpp: In function ‘int mISDN_initialize()’:
mISDN.cpp:88: error: ‘mISDN_set_debug_level’ was not declared in this scope
mISDN.cpp:90: error: ‘mISDN_set_debug_level’ was not declared in this scope
make[1]: *** [mISDN.o] Error 1
make[1]: Leaving directory `/root/catchercatcher/lcr-master'
make: *** [all] Error 2
I see that you have come across following error.
Can you kindly provide me some help.
Thanks in advance
Cheers.
Altaf
At LCR
Thanks in advance
Cheers.
Altaf
