Eumex 300IP as Fritz!Box Fon - problem with call rejection
testownik
15 Mai 2010
Hello
I have problem with rejection incoming calls using "red button" on my phone. When the phone starts ringing, pressing button once does nothing, when i press and wait for a while, phone stops ringing, but the other side still have waiting signal. After few seconds the phone starts ringing again. Often in that cases the box just hangs (no ping response, telnet or web login). I tried two different phones, the same result. Another problem, probably related with abovementioned: when someone calls and stop calling without answering by me, the phone rings few seconds after that. When i pick up the phone in this moment - box hungs.
Terminating connection with the red button works ok. Tested with two different voip providers (i have no fixed line), two firmwares based on 15.04.49 english version annex b (modified using "eumex-to-fritz" and "freetz" 1.1.3), different ports (FON1, FON2), wires, settings related with voip (country, DTMF settings). No matter whether box works as a adsl router with external IP, or as a ATA behind NAT and port redirection - problem still exists. I ran syslog on box with remote logging to other pc, but there is nothing useful in log (only this:
Jun  7 17:15:56 eumex user.err kernel: [avm_power] cant find powermode
Jun  7 17:15:56 eumex user.warn kernel: available powermode:dsl,ata,vdsl,update"
but I have this message every time I pick up the phone.
Everything else just works (starting calling, terminating and so on). I have no idea what to do with this :(
Could it be a hardware problem?
regards
testownik
Drödle
