extension.conf
ruby5000
6 Jan 2007
Hallo Forum,
ich sehe wahrscheinlich vor lauter Bäume den Wald nicht mehr und benötige Hilfe.
Ich habe mir eine extension.conf erstellt
AUSZUG davon
[ankommend]
exten => nummer1,1,Dial,SIP/2200|20|r
exten => nummer1,2,Goto,r-${DIALSTATUS}|1
exten => r-BUSY,1,voicemail,b2200
exten => r-BUSY,2,Hangup
exten => r-CHANUNAVAIL,1,voicemail,u2200
exten => r-CHANUNAVAIL,2,Hangup
exten => r-NOANSWER,1,voicemail,u2200
exten => r-NOANSWER,2,Hangup
exten => nummer2,1,Dial,SIP/2202|20|r
exten => nummer2,2,Goto,r-${DIALSTATUS}|1
exten => r-BUSY,1,voicemail,b2202
exten => r-CHANUNAVAIL,1,voicemail,u2202
exten => r-NOANSWER,1,voicemail,u2202
exten => nummer3,1,Dial,SIP/2203|20|r
exten => nummer3,2,Goto,r-${DIALSTATUS}|1
exten => r-BUSY,1,voicemail,b2203
usw.
nach einem reload erscheint folgender Fehler:
    -- Registered extension context 'ankommend'
    -- Added extension 'nummer1' priority 1 to ankommend
    -- Added extension 'nummer1' priority 2 to ankommend
    -- Added extension 'r-BUSY' priority 1 to ankommend
    -- Added extension 'r-BUSY' priority 2 to ankommend
    -- Added extension 'r-CHANUNAVAIL' priority 1 to ankommend
    -- Added extension 'r-CHANUNAVAIL' priority 2 to ankommend
    -- Added extension 'r-NOANSWER' priority 1 to ankommend
    -- Added extension 'r-NOANSWER' priority 2 to ankommend
    -- Added extension '_X.' priority 1 to ankommend
    -- Added extension '_X.' priority 2 to ankommend
    -- Added extension 'h' priority 1 to ankommend
    -- Added extension 'nummer2' priority 1 to ankommend
    -- Added extension 'nummer2' priority 2 to ankommend
[Jul 31 07:09:53] WARNING[6300]: pbx.c:4702 add_pri: Unable to register extension 'r-BUSY', priority 1 in 'ankommend', already in use
[Jul 31 07:09:53] WARNING[6300]: pbx.c:4702 add_pri: Unable to register extension 'r-BUSY', priority 2 in 'ankommend', already in use
[Jul 31 07:09:53] WARNING[6300]: pbx.c:4702 add_pri: Unable to register extension 'r-CHANUNAVAIL', priority 1 in 'ankommend', already in use
[Jul 31 07:09:53] WARNING[6300]: pbx.c:4702 add_pri: Unable to register extension 'r-CHANUNAVAIL', priority 2 in 'ankommend', already in use
[Jul 31 07:09:53] WARNING[6300]: pbx.c:4702 add_pri: Unable to register extension 'r-NOANSWER', priority 1 in 'ankommend', already in use
Alle Anrufe die aufgezeichnet werden landen auf die Mailbox 2200.
Kann mir jemand einen Tipp geben wie ich das am besten hinbekomme oder muss ich diese ganz einfach nur mit r1-BUSY, r2-BUSY durchnummerieren.
Bitte zuerst ohne Macros, das kommt später.
Uwe
was ist denn an den fehlermeldungen nicht verständlich? du hast die gleichen extension/prioritäts-kombinationen in einem kontext doppelt definiert!
grüße,
laureen
itseb
