extensions.conf vermurkst
McRib
27 Jan 2005
2 7940 haengen an meinem asterisk. Aber irgendwie scheint die extension.conf vermurkst. Sachdienliche Hinweise sind willkommen...
[/etc/asterisk] # asterisk -c
Asterisk 1.2.12.1, Copyright (C) 1999 - 2006 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'show license' for details.
[ Booting...Mar  3 15:52:29 NOTICE[4548]: cdr.c:1192 do_reload: CDR simple logging enabled.
.Mar  3 15:52:29 WARNING[4548]: res_musiconhold.c:1221 load_module: No music on hold classes configured, disabling music on hold.......Mar  3 15:52:29 NOTICE[4548]: config.c:863 ast_config_engine_register: Registered Config Engine odbc
.Mar  3 15:52:29 NOTICE[4548]: res_odbc.c:265 load_odbc_config: Adding ENV var: INFORMIXSERVER=my_special_database
Mar  3 15:52:29 NOTICE[4548]: res_odbc.c:265 load_odbc_config: Adding ENV var: INFORMIXDIR=/opt/informix
Mar  3 15:52:29 NOTICE[4548]: res_odbc.c:294 load_odbc_config: registered database handle 'asterisk' dsn->[asterisk]
Mar  3 15:52:29 NOTICE[4548]: res_odbc.c:554 odbc_obj_connect: Connecting asterisk
Mar  3 15:52:29 WARNING[4548]: res_odbc.c:565 odbc_obj_connect: res_odbc: Error SQLConnect=-1 errno=0 [unixODBC][Driver Manager]Data source name not found, and no default driver specified
Mar  3 15:52:29 NOTICE[4548]: res_odbc.c:599 load_module: res_odbc loaded.
..Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 39 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 40 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 41 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 42 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 45 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 46 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 47 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 48 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 50 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 51 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 52 of extensions.conf
Mar  3 15:52:29 WARNING[4548]: config.c:525 process_text_line: No '=' (equal sign) in line 53 of extensions.conf
.....Mar  3 15:52:29 WARNING[4548]: pbx.c:3761 ast_merge_contexts_and_delete: Requested contexts didn't get merged
.....Mar  3 15:52:29 WARNING[4548]: chan_iax2.c:9680 load_module: Unable to open IAX timing interface: No such file or directory
Asterisk Ready.
 [/etc/asterisk] # cat extensions.conf
[general]
autofallthrough=yes
static=yes
[globals]
PHONE-1=SIP/100
PHONE-2=SIP/200
CID=491805729000xxxx
Name=pillepalle
[macro-stdexten]
exten => s,1,Dial(${ARG1},20)
exten => s,2,Goto(s-${DIALSTATUS},1)
exten => s-NOANSWER,1,Voicemail(u${MACRO_EXTEN})
exten => s-NOANSWER,2,Goto(default,s,1)
exten => s-BUSY,1,Voicemail(b${MACRO_EXTEN})
exten => s-BUSY,2,Goto(default,s,1)
exten => s-.,1,Goto(s-NOANSWER,1)
exten => a,1,VoicemailMain(${MACRO_EXTEN})
[inbound]
exten => 104xxx,1,Macro(stdexten,${PHONE-1})
[local]
exten => 100,1,Macro(stdexten,${PHONE-1})
exten => 200,1,Macro(stdexten,${PHONE-2})
[outbound]
_0049.,1,SetCallerID(${CID})
_0049.,2,SetCIDName(${Name})
_0049.,3,Dial(IAX2/0${EXTEN:4}@pbx-network)
_0049.,4,Hangup
_00.,1,SetCallerID(${CID})
_00.,2,SetCIDName(${Name})
_00.,3,Dial(IAX2/${EXTEN}@pbx-network)
_00.,4,Hangup
_0Z.,1,SetCallerID(${CID})
_0Z.,2,SetCIDName(${Name})
_0Z.,3,Dial(IAX2/0041${EXTEN:1}@pbx-network)
_0Z.,4,Hangup
[default]
include => inbound
include => outbound
include => local
[/etc/asterisk] # cat iax.conf
[general]
register => 104xxx:[email protected]
[pbx-network]
type=peer
username=104xxx
secret=xxxxxxxxxx
host=iax.pbx-network.de
qualify=yes
disallow=all
allow=alaw
allow=ulaw
warum lässt du im [outbound] Abschnitt das
exten =>
weg?
Zeit fuer 'ne weitere bloede Frage zur Ergaenzung:
Was soll die Fehlermeldung: "Mar 4 20:08:17 WARNING[4870]: pbx.c:2357 __ast_pbx_run: Channel 'SIP/100-081730d8' sent into invalid extension 's' in context 'default', but no invalid handler" ?
Irgendwie jammert er auch ueber voicemail, aber fuer 100 ist doch ein Eintrag drin - komisch...
Connected to Asterisk 1.2.12.1 currently running on cherry (pid = 4797)[b]
Mar  4 20:08:17 WARNING[4870]: app_voicemail.c:2414 leave_voicemail: No entry in voicemail config file for '100'
Mar  4 20:08:17 WARNING[4870]: pbx.c:2357 __ast_pbx_run: Channel 'SIP/100-081730d8' sent into invalid extension 's' in context 'default', but no invalid handler[/b]
Mar  4 20:08:17 ERROR[4870]: cdr_custom.c:127 custom_log: Unable to re-open master file /var/log/asterisk/cdr-custom/Master.csv : Permission denied
Mar  4 20:08:17 ERROR[4870]: cdr_csv.c:237 csv_log: Unable to re-open master file /var/log/asterisk//cdr-csv//Master.csv : Permission denied
Mar  4 20:08:33 NOTICE[4875]: app_dial.c:1056 dial_exec_full: Unable to create channel of type 'SIP' (cause 3 - No route to destination)
Mar  4 20:08:33 ERROR[4875]: cdr_custom.c:127 custom_log: Unable to re-open master file /var/log/asterisk/cdr-custom/Master.csv : Permission denied
Mar  4 20:08:33 ERROR[4875]: cdr_csv.c:237 csv_log: Unable to re-open master file /var/log/asterisk//cdr-csv//Master.csv : Permission denied
[/etc/asterisk] # cat voicemail.conf
[general]
100 => 1234, blala, [email protected]
200 => 1234, blabla
itseb
