FB 7170: Bekomme Asterisk einfach nicht zum laufen ....
Texel
29 Jun 2009
Hallo, nach Stunden der Fehlersuche gebe ich langsam auf.
habe eine FB 7170 Firmware-Version 29.04.86-19138.
Die Installationsskripte laufen ohne Fehler durch (habe sowohl das cfg_asterisk16 und das 14er probiert).
Beide bringen folgenden Fehler:
# ./cfg_asterisk14 start
'/etc/asterisk/asterisk.conf' is not a regular file, ignoring
'/etc/asterisk/extconfig.conf' is not a regular file, ignoring
asterisk daemon has been started (to open a console use: cfg_asterisk14 start r)
Anscheinend versucht * immer im /etc/asterisk-Verzeichnis die cfgs zu lesen, die liegen da aber nicht drin (sondern in /var/asterisk14/etc/asterisk).
im Konsol mode lässt sich * überhaupt nicht starten:
# ./cfg_asterisk14 start r
Asterisk 1.4.16.2, Copyright (C) 1999 - 2007 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
Unable to connect to remote asterisk (does /var/run/asterisk.ctl exist?)
wenn ich's über folgenden Workaround direkt starte kommt:
# LD_LIBRARY_PATH=/usr/lib /var/chroot /var/asterisk14 asterisk -c
[ Booting...
[ Reading Master Configuration ]
[ Initializing Custom Configuration Options ]
No entry for terminal type "vt102";
using dumb terminal settings.
'/etc/asterisk/logger.conf' is not a regular file, ignoring
Errors detected in logger.conf: see above; default settings will be used.
[Apr 25 18:40:05] WARNING[1549]: config.c:873 config_text_file_load: '/etc/asterisk/modules.conf' is not a regular file, ignoring
[Apr 25 18:40:05] WARNING[1549]: loader.c:762 load_modules: No 'modules.conf' found, no modules will be loaded.
[Apr 25 18:40:05] WARNING[1549]: config.c:873 config_text_file_load: '/etc/asterisk/dnsmgr.conf' is not a regular file, ignoring
[Apr 25 18:40:05] WARNING[1549]: config.c:873 config_text_file_load: '/etc/asterisk/manager.conf' is not a regular file, ignoring
[Apr 25 18:40:05] NOTICE[1549]: manager.c:2850 init_manager: Unable to open management configuration manager.conf. Call management disabled.
[Apr 25 18:40:05] WARNING[1549]: config.c:873 config_text_file_load: '/etc/asterisk/cdr.conf' is not a regular file, ignoring
[Apr 25 18:40:05] NOTICE[1549]: cdr.c:1371 do_reload: CDR simple logging enabled.
[Apr 25 18:40:05] WARNING[1549]: config.c:873 config_text_file_load: '/etc/asterisk/rtp.conf' is not a regular file, ignoring
[Apr 25 18:40:05] WARNING[1549]: db.c:66 dbinit: Unable to open Asterisk database '/var/lib/asterisk/astdb': Illegal seek
[Apr 25 18:40:05] WARNING[1549]: config.c:873 config_text_file_load: '/etc/asterisk/enum.conf' is not a regular file, ignoring
Asterisk Ready.
*CLI>
dann bin ich zwar im ersehnten Console-Mode, allerdings kommen auch ständig die Verzeichnisfehler.
*-14 bzw. *-16 habe ich jeweils direkt auf die Box (nicht auf den USB-Stick) installiert.
Kennt irgendjemand eine Lösung?
viele Grüße,
Texel
ok. neuer Tag. neuer Versuch.
Habe nun die USB-Variante probiert. Siehe da, eine andere Fehlermeldung.
> wgetx: Couldn't download "www.spblinux.de/fbox/26/asterisk16_usb.sqf"
habe dann im folgenden Thread die Lösung gefunden: Es hat sich der Server geändert
... http://spblinux.de/fbox.new
Thread: http://www.ip-phone-forum.de/showthread.php?t=183313&page=1
habe dann von diesem Server auch das neue Script genommen. Installation und Start liefen dann problemlos.
Viele Grüße,
Texel
figo12
