[Gelöst] FB 7570 und Sipgate
Nielsen
23 Mrz 2012
Hallo Ihr Lieben,
seit Tagen versuche ich, einen Sipgate-Account in einer FB 7570 von NetCologne ans Laufen zu bekommen; leider ohne Erfolg.
Vielleicht kann mir hier jemand helfen?
( Die Nummer habe ich für diesen Post ersetzt durch 12345678 )
Die Fehlermeldung der FB lautet: "Anmeldung der Internetrufnummer 12345678 war nicht erfolgreich. Ursache: Gegenstelle antwortet nicht. Zeitüberschreitung."
Die voip.cfg sieht wie folgt aus:
ua6 {
enabled = yes;
username = "$$$$TSKWGXOJ4J5416XVZ6335MCUBXIHA4THKQIGANUHLQJNDN3QFDIZSPGZ54LBZIKMMOIVM4LFKF54GAAA";
authname = "";
passwd = "$$$$I1CDFLLVVSUADPAG4OKU5USLCZHSIZ53FEYOEX4AMUFGY2RK4K3K6SSRVIW3GLYEG3JYRD4M4PNLQAAA";
registrar = "217.10.79.9";
ttl = 1h;
sipping_enabled = no;
sipping_interval = 280s;
name = "12345678";
providername = "";
with_displayname = no;
dtmfcfg = dtmfcfg_rtp_or_inband;
register_failwait = 0w;
register_failwaitmax = 30m;
stunserver = "stun.sipgate.net";
stunserverport =10000;
use_internat_calling_numb = no;
is_nat_aware = no;
localip = 0.0.0.0;
ignore_received_header = no;
always_clir = no;
clirtype = clir_displayname;
colptype = colp_none;
clipnstype = clipns_off;
vad_enabled = no;
only_one_dialog = no;
presence_supported = no;
mwi_supported = no;
ccbs_supported = no;
reg_support = regsupport_auto;
packetization = packetization_fixed;
tx_packetsize_in_ms = 20;
xrtp_periodic = 0;
reject_refer = yes;
no_register_fetch = yes;
do_not_register = no;
only_call_from_registrar = no;
invite_without_register_allowed = no;
outboundproxy = "217.10.79.9";
outboundproxy_without_route_header = no;
dditype = ddi_none;
ddireception = "";
alias_head_number = "";
backup_wanted = no;
use_session_timer = no;
use_rport = yes;
add_rtpmap_for_all_codecs = no;
answer_only_one_codec = no;
without_annexb_no = no;
srtp_supported = no;
use_488_for_no_t38 = no;
g726_via_rfc3551 = no;
no_g726_32_offer_with_pt2 = no;
enable_3xx = yes;
t38_reinvite_from_remote = no;
use_t38version0 = no;
rtcp_xr_media_attribute = no;
read_p_asserted_identity_header = no;
route_always_over_internet = no;
gui_readonly = no;
Schon jetzt herlichen Dank für jeden Tip!
Niels
Bin jetzt nicht alles durchgegangen... mögliche Optionen:
Registrar sipgate.de
Ohne STUN
Frage: Waren die Loesungsvorschlaege IPPF Threads nicht zielfuehrend ?
Sipgate VOIP auf FritzBox 7570 von NetCologne:
http://www.ip-phone-forum.de/showthread.php?t=215889
http://www.ip-phone-forum.de/showthread.php?t=267076
ansonsten gibt es folgende Anleitungen von Sipgate fuer Fritzbox:
siehe http://www.sipgate.de/faq/index.php?do=displayArticle&article=1258&qw=fritzbox
fuer FRITZ!Boxen können im Dual Stack Betrieb (IPv4 und IPv6 gleichzeitig)
siehe https://secure.sipgate.de/user/configreader.php?show_conf=Fritz+Box+#Fritzbox IPv6
bzw. allgemeine VOIP-Geraete-Einstellungen http://www.sipgate.de/faq/index.php?do=displayArticle&article=1225&id=302
Vielen Dank für die angebotenen Hilfen; leider bliebt das Problem bestehen.
In der FB selbst kann ich Sipgate nicht erfolgreich konfigurieren; schalte ich eine andere FB oder ein Endgerät hinter die Box, funktioniertbes tadellos.
@ andiling: Wenn ich als registrar statt der IP "sipgate.de" eintrage, bringt die FB einen DNS-Fehler; daher hatte die IP-Adresse verwendet.
@ splenditnet: Die Forensuche hatte ich natürlich vorab verwendet; in Deinem ersten Link wird auf eine Anleitung im NetCologne-Forum verwiesen; leider gibt es dieses Forum nicht mehr (-:
Guten Abend,
das Probem ist gelöst:
In der GUI den Account entsprechend den Angaben von Sipgate einrichten; anschließend in der voip.cfg "route_always_over_internet" von "no" auf "yes" umstellen, rebooten und fertig.
Vielen Dank!
Ich glaube das (route_always_over_internet = yes;) kann man in der GUI auch direkt einstellen. (Anmeldung immer über eine Internetverbindung)
Der Vollständigkeit halber ein screenshot meiner Konfiguration.
PS: kannst ja das Thema als gelöst markieren.
Wenn der DNS nicht aufgelöst werden kann, liegt das eben am 2. PVC (Telefonica Anschluss).
Mit einer Signatur Deinerseits wäre das Problem schneller erkannt worden. ;)
@ Ecki-No1: Bei der von Sipgate vorgeschlagenen Konfigurationsweise gibt es diese Option nicht in meiner Box (s. screenshot)
@ andiling: Es ist ein NetCologne Glasfaser-DSL-Anschluss. Auf den Hilfeseiten von hatte ich den Hinweis auf Eintrag der IP-Adresse gefunden..
Hezrlichen Dank!
Ist es denn ein Team Konto? (die haben glaube ich einen anderen Proxy)
McBebe1
