FBF 7140 fax reception
binary_dreamer
24 Jul 2009
Hi.
i do have a FBF 7140 and it has the latest firmware.
i have enabled the fax reception and it works fine to receive faxes through the PSTN line.
I do have a sip account on the FBF that the number is reachable directly from any pstn number around the globe.
my question is, how do i setup the fax reception on FBF to receive faxes to the sip account number?
i would like to have the sip to receive faxes.
Sry, but that is not an Answer to my Question. :(
You have to assign a MSN to the internal Faxfuction of the 7140, therefore take the Sip-MSN and see what happend...
OK.
i will give it a try and let you know.
atrora
