Fbf 7390 int downgrade to 5. Firmware?
ruprechtek
19 Mai 2019
Greetings,
Apologies for writing in English, but my German is too weak to communicate in tech matters... i read german well, but write in english
Pls hint me, how to do downgrade my latest fw to ver5?
Where i found archived (old) restore utility pls? for eng version of 7390.
Many Thx.
Dann mach eben keinen unnötigen Downgrade.
Then how to run autoexec after fbf start with stock firmware higher than 6? On older fw run debug.cfg i think
And better DSLAM settng
https://github.com/Freetz/freetz
All other of your approaches to get (aka download) an image with extensions are at least a copyright violation.
Your other thread and the question regarding the SoftCAM server are usually a taboo in this board, too.
Why? One of the main purposes of such a SoftCAM is the violation of German law (https://heise.de/-4049040), violators are usually accused under §202a StGB - and in Germany exists another paragraph in criminal laws (§ 202c Abs. 1 Zf. 2 StGB) regarding such software and any helpers, who are involved in the "delivery chain".
If you want to make it as easy as possible to you, you're (at least in my opinion) in the wrong board.
If you're ready to build your own image (no-one will ask, which customized extensions you're using within, as long as you limit the usage to your own home), you're probably in the right place - but you're asking the wrong questions.
Den anderen Thread habe ich entsorgt, die Info wo man ältere Firmware oder Recoverys bekommen kann, sind genannt worden.
Somit ist das Thema geschlossen (ggf. ein neues/passendes/erlaubtes Thema auf machen)
Nik320
