FBF in Argentinien
kino69
2 Okt 2006
I have installed a FBF 7050 in Buenos Aires
I want to collect/share the requested modifications:
My configuation is:
FBF 7050
FirmwareVersion=14.04.31
CONFIG_INSTALL_TYPE=ar7_ubik2_4MB_2eth_3ab_isdn_nt_te_pots_wlan_50494
OEM=1und1
Country=049
Changes:
1) from Annex B to Annex A (with env variable change)
2) timezone
2.1) read the ar7.cfg file thanks to FBEditor
2.2) change the timezone to
timezone_manual {
enabled = yes;
offset = 3;
dst_enabled = yes;
TZ_string = "CET3CEST,M10.5.0/1,M3.5.0/1";
Be carefull on the other side of the world the SOmmezeit is from Octobet to March (viceversa compared to Europe) => the order is importa in the TZ string
2.3 write the new settings.
Everithing is working
Ciao
fusionK
