- Mitglied seit
- 27 Okt 2007
- Beiträge
- 127
- Punkte für Reaktionen
- 0
- Punkte
- 0
Hallo all,
here are some points which i figured out when using speed2fritz
My test bed is: Speedport w701, Linux Ubuntu 9.x, Jpasher script 30.5
1- When setting a different Branding -> Router gets in continuous reboot
2- When Freetz script starts, it asks to update from svn source:-
a- This must be answered with "y", otherwise you may get long file name if you run the script more than once
3- Replace kernel does not function or i did not find a way to get it working correctly. may be it was correlated with Branding set above
4- In the html files, after extraction, it would be nice to give a pause so that one can make fine editing on the html files
5- USB Devices apear in my front page GUI, however i don't have usb devices
6- It would be nice to change the word Fritz!Box in the html files to some other brand (set in sp-to-fritz GUI). I tested it as follow
sed -i 's/Fritz!Box/yourbrand/g' *.html
But it gets into a continuous reboot (please confirm)
any comments in English or German would be appreciated
regards,
Sherif
regards,
Sherif
