freetz@freetz-linux:~/freetz-trunk$ make
touch -c /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.5.3_uClibc-0.9.31.1/mipsel-linux-uclibc/usr/lib/libc.a
for i in ld-uClibc-0.9.31.1.so ld-uClibc.so.0 libc.so libc.so.0 libcrypt-0.9.31.1.so libcrypt.so libcrypt.so.0 libdl-0.9.31.1.so libdl.so libdl.so.0 libm-0.9.31.1.so libm.so libm.so.0 libnsl-0.9.31.1.so libnsl.so libnsl.so.0 libpthread-0.9.31.1.so libpthread.so libpthread.so.0 libresolv-0.9.31.1.so libresolv.so libresolv.so.0 librt-0.9.31.1.so librt.so librt.so.0 libthread_db-0.9.31.1.so libthread_db.so libthread_db.so.1 libuClibc-0.9.31.1.so libutil-0.9.31.1.so libutil.so libutil.so.0; do \
cp -a /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.5.3_uClibc-0.9.31.1/mipsel-linux-uclibc/lib/$i packages/target-mipsel_uClibc-0.9.31.1/root/lib/$i; \
done
ln -sf libuClibc-0.9.31.1.so packages/target-mipsel_uClibc-0.9.31.1/root/lib/libc.so
touch -c packages/target-mipsel_uClibc-0.9.31.1/root/lib/libc.so.0
---> library/freetype: configuring... (conf_cmd() { ./configure "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; cd source/target-mipsel_uClibc-0.9.31.1/freetype-2.3.12; rm -f config.{cache,status} ; PATH=""/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.5.3_uClibc-0.9.31.1/mipsel-linux-uclibc/bin:/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.4.6/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games"" CC="/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.5.3_uClibc-0.9.31.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" CXX="/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.5.3_uClibc-0.9.31.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper" CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" PKG_CONFIG_PATH="/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.5.3_uClibc-0.9.31.1/mipsel-linux-uclibc/bin/../lib/pkgconfig" PKG_CONFIG_LIBDIR="/home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.5.3_uClibc-0.9.31.1/mipsel-linux-uclibc/bin/../lib/pkgconfig" FREETZ_TARGET_LFS="y" CONFIG_SITE=/home/freetz/freetz-trunk/include/site/mipsel-linux-uclibc conf_cmd --cache-file=/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.31.1/config.cache --target=mipsel-linux --host=mipsel-linux --build=i386-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls --enable-shared --enable-static )
make[1]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.31.1/freetype-2.3.12'
FreeType build system -- automatic system detection
The following settings are used:
platform unix
compiler /home/freetz/freetz-trunk/toolchain/build/mipsel_gcc-4.5.3_uClibc-0.9.31.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc
configuration directory ./builds/unix
configuration rules ./builds/unix/unix.mk
If this does not correspond to your system or settings please remove the file
`config.mk' from this directory then read the INSTALL file for help.
Otherwise, simply type `make' again to build the library,
or `make refdoc' to build the API reference (the latter needs python).
cd builds/unix; ./configure '--cache-file=/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.31.1/config.cache' '--target=mipsel-linux' '--host=mipsel-linux' '--build=i386-pc-linux-gnu' '--program-prefix=' '--program-suffix=' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--datadir=/usr/share' '--includedir=/usr/include' '--infodir=/usr/share/info' '--libdir=/usr/lib' '--libexecdir=/usr/lib' '--localstatedir=/var' '--mandir=/usr/share/man' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--with-gnu-ld' '--disable-nls' '--enable-shared' '--enable-static'
configure: WARNING: unrecognized options: --disable-nls
configure: loading site script /home/freetz/freetz-trunk/include/site/mipsel-linux-uclibc
configure: loading cache /home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.31.1/config.cache
configure: error: `CFLAGS' has changed since the previous run:
configure: former value: `-march=4kc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64'
configure: current value: `-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64'
configure: error: in `/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.31.1/freetype-2.3.12/builds/unix':
configure: error: changes in the environment can compromise the build
configure: error: run `make distclean' and/or `rm /home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.31.1/config.cache' and start over
make[1]: *** [setup] Fehler 1
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.31.1/freetype-2.3.12'
make: *** [source/target-mipsel_uClibc-0.9.31.1/freetype-2.3.12/.configured] Fehler 1
