Fehler bei Freetz Aura Labor
proview2008
6 Feb 2008
Hallo kommme nicht mehr weiter, wollte mit gerade mit dem aktuellen trunk Rev.3262eine neue Firmware für die 7270 erstellen, jedoch kommt bei mir folgende Fehlermeldung nach make siehe Auszug
creating symlinks /tmp, /mod and /home
setting freetz-version 'freetz-devel-3262M'
setting subversion 'freetz-devel-3262M'
applying patch file ./patches/100-3170_7170.sh
applying patch file ./patches/100-7140_7170.sh
applying patch file ./patches/100-7141_7170.sh
applying patch file ./patches/100-getcons.sh
removing /bin/getcons
rm build/modified/filesystem/bin/getcons
applying patch file ./patches/100-profile_term_password.sh
applying patch file ./patches/100-rename_ctlmgr.sh
applying patch file ./patches/100-w701v_7170.sh
applying patch file ./patches/100-w900v_7170.sh
applying patch file ./patches/101-libfreetz.sh
patching /etc/init.d/rc.s
applying patch file ./patches/105-onlinechanged.sh
Patching /bin/onlinechanged
applying patch file ./patches/115-7270_16MB.sh
applying 16MB patch
applying patch file ./patches/170-rename_ar7login.sh
renaming ar7login to make way for wrapper script
applying patch file ./patches/180-printk.sh
applying patch file ./patches/191-webmenu_wol.sh
applying wol patch
applying patch file ./patches/cond/de/webmenu-wol-7270_labor_aura.patch
patching file usr/www/all/html/de/menus/menu2_homehome.html
patching file usr/www/all/html/de/menus/menu2_konfig.html
Hunk #1 succeeded at 80 (offset 5 lines).
Reversed (or previously applied) patch detected! Assume -R? [n]
Apply anyway? [n]
Skipping patch.
1 out of 1 hunk ignored -- saving rejects to file usr/www/all/html/de/menus/menu2_homehome.html.rej
Apply anyway? [n]
Skipping patch.
1 out of 1 hunk ignored -- saving rejects to file usr/www/all/html/de/menus/menu2_konfig.html.rej
ERROR: modpatch: Error in patch-file ./patches/cond/de/webmenu-wol-7270_labor_aura.patch
make: *** [firmware-nocompile] Fehler 2
slightly@StinkyLinux:~/freetz/trunk$
wenn ich mir z. b. ein image mit der neuen DSL Labor baue läuft es einwandfrei durch, wäre suprer wenn mir jemand helfen könnte.
Als erstes mal: Nutze einen unmodifizierten trunk. Tritt der Fehler dann immer noch auf?
fusionK
